Previous in Forum: Is EtherCAT High Speed Over TTCAN?   Next in Forum: Ametek 5402 Current Amplifier 1GV/A 100kHz
9 comments
Using VFDs at Home
04/18/2019 2:30 AM
I just want to ask about the possibility of using VFDs at home
Will it reduce the cost of my bill.
But my power supply is a single phase power supply and my motors as well
So for my water lefting pumps, I have to covert to a three phase motor
Will it be sufficient to do so.
Abenr,
Pathfinder Tags: VFD
Re: Using VFDs at home
04/18/2019 3:02 AM
Until:
  • Nagging to unplug
  • Thermostats
  • Time-switches
  • Draught exclusion
  • Loft insulation
  • Substitute high efficiency lighting
  • Multiple glazing
  • Supplier switching
have taken place, forget it.
Anyway, most homes are single phase.
What on earth is sufficiently large at home that needs a 3-phase motor to turn it (rhetorical question - NNTR)?
04/18/2019 12:50 PM
here is a device that would benefit from a 3 phase motor
https://www.youtube.com/watch?v=qMsObwqD788
04/18/2019 5:35 AM
If you like 50-year ROI, go for it.
Re: Using VFDs at Home
04/18/2019 8:47 AM
I would try another approach, maybe a water tower...
04/18/2019 9:43 AM
This is certainly possible. It will be far from practical and efficiency improvements will be dubious, at best. To say for certain will require knowing a lot more about your system.
Now if the old motor fails and needs something to replace it then I might consider switching to a three-phase motor and driver system. Most of the efficiency improvements will be due to improvements in the magnetic properties of the newer motor but don't expect significant improvements.
04/18/2019 11:01 PM
​_https://www.ato.com/single-phase-vfd
There are inexpensive VFDs for typical single phase motors, mostly split capacitor types, running plus starting winding energized at all times. HVAC people use them on blowers for some designs to get your 16 SEER. For pumps and fans you will save some electric cost if the impeller is not matched to the service, I.e. if your pump pressure only needs to be 40 psi and your pump produces 60 psi at normal run. Or your fan is blowing hard against partially closed dampers.
most of your kw go to flow, either CFM or GPM, so if you can reduce those, then you might have some savings worth investigating a new add-on VFDS. To convert to 3 phase motors is unlikely to be achievable, let alone economical.
04/19/2019 1:42 AM
Thank you very much for your reply, which is very helpful to me
Good Answers: 117
04/19/2019 7:26 AM
try this
https://www.youtube.com/watch?v=ZqnfLHhuuUQ
04/30/2019 11:05 AM
I think almost any washing machine one buys today (for normal home use) has a three phase motor supplied by a VFD and operated from single phase. No gearing or crank for agitator. Just reverse motor to agitate and increase frequency to spin.
Register to Reply 9 comments
Abenr (1); brich (1); hoo8975 (1); LG_Dave (1); PWSlack (1); redfred (1); rwilliams (1); SolarEagle (1); Tornado (1)
