Previous in Forum: Aid in using AutoCAD   Next in Forum: SSE2 set of instructions
19 comments
AutoCad-2007 3D Polyline
10/10/2007 8:18 PM
I use the AutoCad-2007 to extrude multi-plane 3D Polyline to the piping and ducts systems. But... I cannot find a way to arrange the elbows on the piping turns.
Please, give me an advice not just your guess.
apcco@verizon.net
Re: AutoCad-2007 3D Polyline
10/10/2007 9:25 PM
Though I dont understand what your meaning exactly, I havnt seen 2007 version Im still using 2000 occationally,
I guess you try to link a region constructed by a ployline surrounding to a pipe type smoothly.
try to sue spline or loft command. that will do the trick.
08/31/2008 11:50 PM
you can convert any line into a ploy line or go to help that will give you step by step
larry Ostrander
10/11/2007 4:37 AM
Assuming that you are using a library of standard components, and adding the piping to join them, use a workplane on the centre line of the elbow. This can then be angled in each direction from the reference plane as required.
Where several pipes need arranged to run together, align by their workplanes.
Madness is all in the mind
Good Answers: 97
10/11/2007 8:12 AM
I assume you are doing a spline or smoothing opp on the line and that an elbow / bend is straightened out.
In that case you should do smoothing on lines between elbows.
What is needed is that arcs should be added as unmovable fixed points.
I haven't used AutoCad lately and I don't know the current limitations and features.
10/12/2007 12:51 AM
then the poly line is not contiguous that is it has a gap make shure you window the extence then it should prompt connect it should then extrude as a single entaty
post the graphic for trial
larry Ostrander
10/12/2007 6:44 AM
I guess he want to connect the two entities smoothly.
10/12/2007 8:23 PM
nobody can link thesee two entity smoothly?
10/16/2007 6:59 AM
I try to draw to refer to. but i find the loft command is in other software. sorry for it. I almost forget for not long time use this cad. you can also bend it as you like shape.
10/16/2007 10:43 PM
you can use path extude method to form bend link like bellow illustration.
I reply I learn.
10/14/2007 9:42 PM
1. This is 2D Polyline (in one plane)
2. The line with fillets and circle
3. The line is extruded
3D polyline does not accept Fillet (elbow). This is the problem.
Engineering Fields - Automotive Engineering - Auto+Motor=Sport
10/12/2007 5:33 AM
Try this:
Set up a new 3-point UCS with the origin at the bend/ corner point and the x and y axis aligned with the contigous pipe centerlines.
Put in your elbows in form of circular curves (circle tan tan rad), then trim accordingly.
Once you have all bends in place, highlight your pipe centerlines and convert those to a pipe-path.
On one end, make a perpendicular circle or donut as your pipe profile.
Extrude as a sweep along pathline.
Voila, you gotst a pipeline!
Hope this helps....... good luck!
If you can't dig it, get a backhoe!
Fans of Old Computers - PDP 11 - New Member
Location: In a mushroom field somewhere in Canada. Kept in the dark and fed sh--, well you know.
10/12/2007 8:25 AM
STOP USING AUTOCRAP AND USE SOLIDWORKS!!!!!!!!!!!!!!!!!!!
Dirt is for vegetables. Pavement is for racing.
10/12/2007 5:38 PM
I agree.... solid works is the way to go when it comes to this sort of thing. I work on the mechanical systems for a mega yacht builder in the Pacific North West. We model just about everything. My responsibilities are mostly from the engine room aft.
For simple piping all you have to do is construct a 3d sketch and extrude the pipe. Adding the fittings then could not be easier.
I also do independent modeling for other companies and will often receive reference work as 3d Auto Cad... soooo painful to work with.
Bite the bullet and learn Solid Works and you won't regret it.
Travis
10/12/2007 8:30 AM
If you allready have the elbows drawn in a library you can place the elbow near where you want it, then do the align command. it will prompt for what points you want to align. I use the centerpoints of the pipe and elbows and after you identify the point to align, it does it for you.
10/12/2007 10:45 AM
Hi!.
If Autocad 2007 runs as 2005 wich I´m almost sure, all you need to do is to invoque the revsur or revolving surface comand which will ask you for the object you want to define the seccion of the elbow (it can be a circle, a saquare, a poligon etc.) and then select a line (wich have to be previously provided and perpendicular to the plan containig the objet which will define the sección of the elbow) as the axis of revolution, then define the starting angle of the elbow, then the angle described by this and at last enter.
It's not that difficult but you will have to practice a little.
Good luck!.
10/13/2007 3:30 AM
HI
I HAVE SEND YOU 2 DRAWINGS OF ELBOW ON YOUR EMAIL ADDRESS 'apcco@verizon.net'
IS IT OK FOR YOU PL. REPLY.
THANK YOU
V.D.DEODHAR.
10/13/2007 4:13 AM
why not post out here to show us all to learn?
10/15/2007 8:56 AM
Call or e-mail Autocad Technical Support for help. That should be the best resource for help of that sort.
06/04/2008 9:34 AM
The best way is to use the new sweep command in acad 2007 which works perfectly!
G.Palmieri
Canada
Register to Reply 19 comments
Anonymous Poster (2); apcco (1); cnpower (6); Faustfix (1); GM1964 (1); Hendrik (1); Hunter_dg (1); larry16 (2); Mario Gasca (1); unclefastguy (1); vidyadhar deodhar (1)
You might be interested in: Piping Services, Piping Systems, Pipe Fittings
