Previous in Forum: bookbinding machinery   Next in Forum: CNG engine use in India
27 comments
Tongue Weight Adjustment
10/17/2007 5:24 AM
I have recently purchased a used boat and trailer (single axle) that has a major case of the 'tail wagging the dog.' at highway speeds. The problem appears to simply be not enough tongue weight on the hitch.
Scanning the net seems to have a consensus that simply moving the wheels aft will increase the tongue weight and solve the problem. Sounds simple enough but how much?
My question:
What formula would be applicable to calculate the effect of moving the wheels aft on the amount of tongue weight resulting from the change in wheel location?
The boat, motor and fuel weigh approx. 2800 lbs. with the trailer weighing in at about 750 lbs. and currently there is about 10 lbs of tongue weight. Total trailer lenght is approx. 25 ft.
I know trial and error can solve the problem but that's no fun. I always liked math but it didn't always like me!
Thanks
Brian
Re: Tongue Weight Adjustment
10/17/2007 5:46 AM
Just a thought: to increase the weight on the tow hook it might be easier to move the boat forward on the trailer, or failing that take off the outboard and place it in the bows during the road journey. Or failing that fill the bows up with supplies.
"A statistician uses mathematics in the same way as a drunk uses a lamp-post - for support rather than illumination."
It might be worth checking with the original equipment manufacturer that the rear suspension of the towing vehicle is stiff enough for the application and whether the correct grade tyres are in use, at the correct pressures.
10/17/2007 6:16 AM
If buying a four wheel trailer is out of the question then try a tow-hitch damper. We found that to be effective with a two-wheel car trailer. I've towed all sorts of things with all sorts of weight distribution and conclude that loading the tow hitch isn't very effective in stoppong the tail wagging the dog.
What are you towing with? The inertias of the vehicle and trailer must be the main factors. I like the suggestion of moving the motor and the stowed equipment around, it'll affect the inertia, never mind the weight on the hitch.
Wish I was here more often.
10/17/2007 7:52 AM
Neglecting wind resistance for the moment, if the trailer were to be perfectly balanced, then only a minor disturbance to the alignment of the trailer by some pot-hole or roadkill for example would cause its direction to change. This would carry on until all the slack in the mechanical doobries have been used up. The towing vehicle then tries to correct the alignment by applying a restoring force, changing the alignment again, and again, and again, and again (the tail wagging the dog). and if the tail is heavier than the dog, then the tail will win........
The problem is that the trailer cannot align itself along the same axis as the towing vehicle unless the centre of gravity is well forward of the axle, in which case the 'system' can be said to be 'damped', by observation. Such an arrangement places a significant part of the trailer's weight upon the tow hook of the towing vehicle. 10/3550ths is way too small! However, too much weight can cause the nose of the towing vehicle to lift, adversely affecting steering and stability.
There is some mathematics one can use to sort it out from a theoretical standpoint. Its called S-plane algebra. Good luck with it!
On a more practical basis there's a load of stuff on the 'net about towing, vehicle weights, tongue weights, etc., which is well worth reading.
[Background info: there are 'grandparent rights' on some driving licences in the UK that permit the longer-licensed driver to tow a trailer legally without taking an additional test and upon the basis of driving experience; someone who passed a car driving test after 1st January 1997 needs a separate practical assessment and licensing for some trailer towing as the regulations have been tightened since then with a view to reducing road accidents. The weight of the trailer and load stated above is way over the non-assessment criteria for UK roads and, were such a combination to be considered here, training and practical assessment would be the only legal route available.]
Good Answers: 18
10/17/2007 11:52 AM
Tail wagging the dog is often caused by misalignment of trailer wheels. Have you checked that?
10/17/2007 6:46 PM
I have the solution.
I had the same problem for years on a piece of equipment and tried all the above mentioned ideas.
The way to fix it is very simple drop the height of the hitch,trust me it will work.
If you have a receiver it is easy to get different drops or get an adjustable type.
Or simply try a different vehicle with a lower hitch to prove the theory.
Lighten up
Good Answers: 19
10/18/2007 9:35 AM
There are many benefits to propber hitch height. For farm vehicles, the advice was to never have a hitch higher than 13", due to stability and potential rollover issues. A lower hitch point lowers the force lines closer to the ground to promote stability.
10/17/2007 11:31 PM
I'm wondering if your tires are radial type? I've had problems with those type tires with a heavy weight like your pulling. They can start the fish-tailing and wind up getting worst as the tires flex back and forth. Something with a 4 ply sidewall won't do this as bad. Also 10 lbs. is not enough on the hitch. I would go to at least 50-75 lbs. and like another fellow mentioned keep the front down a little if possible. I built my own trailer for a steamboat that is over 2000lbs. and it trailers just fine. I have a construction article on my website as to how I built the trailer and also how I placed the single axle under it for the correct balance. Just hit trailer in the sidebar and it will bring you there.
http://www.mysidewheeler.com
Ken Brockway
10/18/2007 11:21 AM
I like your style and the tips & weights, they fit in with my experiences of towing both caravans and trailers over the last 40 odd years. But nothing that heavy except once a car on a trailer....
Having a boat of that weight on a 2 wheel trailer is to my mind tantamount to suicide....I would suggest following your tips for now (plus a much higher air pressure in the tires, so that the walls do not bulge too much and investing in a proper tandem axle trailer as soon as possible....
They give better stability and braking under all conditions.
How heavy is the tow car?
I would also suggest one of those special trailer hitches for the boat that have those built in brake pads to help damp down any problems.
Remember, if the trailer starts to zig zag, strong braking (not violent!), especially with a tow car with ESP will get that trailer behaving again. I know, I have been there and got the T-shirt and the extra skid marks that were NOT on the road!!! IT WORKS!!
Never try accelerating to fix that problem......
10/19/2007 4:21 AM
Don't necessarily agree, the problem usually manifests itself slowing down. Strong braking isn't going to help if the towing vehicle is doing more braking than the trailer - sometihng which most people wouldn't know. Trailer brakes are more often there for looks than effect in my experience, exacerbated by the lack of use and maintenance suffered by many.
10/19/2007 7:20 AM
If you belong to either the RAC or AA (as you live in the UK) may I strongly recommend asap that you contact them and query what I have said....?
About 5 years ago, I got into my worst situation of a caravan swinging from side to side, it was so bad, my wife could not speak she was so terrified....she just "squeaked!"
Usual story - going too fast for the conditions, downhill, strong wind from the left, A1 going north in northern England, trees suddenly peter out on the left, a strong gust starts the motion. The whole car was being wrenched from side to side by the caravan. There was a loud "whooshing" sound as the caravan was trying its best to overtake the car either side with each swing, the whoosh being from the whole side of the caravan being presented to the apparent wind of driving!!.....
I was more than 25% UNDER the maximum tow weight for that car a 1.9 ton, VW Sharan, I had a Tandem axle Caravan (the best to usually NOT get into such trouble usually!), the nose weight was correct, weighty things were directly over the axles, not in the front or back etc etc....I actually have had on all my trailers and caravans one of those "Anti-sway" tow hitches with mini brake pads that grip the tow ball, I do believe they help also....
Remembering the advice from MANY caravan magazines read over the years both from the UK and Germany and the ADAC and the AA, I braked fairly firmly, remembering that emergency type heavy braking may cause a jack knife.
The caravan just IMMEDIATELY stopped swinging and followed the car as it should, it was like magic!! David Copperfield could not have surprised me more with a trick of his!!
I thought about the physics of the situation and I believe that the fix lies partly in the fact that the caravan (or better said the wheels of the caravan) are traveling a different distance to the car on each swoop and at a slightly different speed for each wheel of the caravan, by braking, you sort of start to "lock up" those 4 wheels, like a cheap ABS on the caravan, you also reduce the speed of the whole combination at the same time.....
Remember, the caravan is actually shoving the car forward as it travels from one side to the other, particularly (or at its most) when it is approximately in a line behind the car!! and this of course forces the caravan brakes on slightly more EACH TIME IT PASSES BEHIND THE CAR...
All I know is that it works almost INSTANTLY, AND it is a recommended action by some Motoring organizations that should know.......which is how I found out, I would never have thought of doing this alone, never in a million years.....
I am sure that the car's ABS and ESP contributed as well, but according to the motoring organizations, this is NOT a requirement to find that proper braking, properly applied fixes this problem.
I also did not waste much time between it starting and me braking, my wife said that it only swayed like 3 or 4 times, but very drastically and then I applied the brakes. It was also difficult to stay in a straight line because of the "tail wagging the dog!" till the brakes went on...
In Germany our Caravans (something that the UK needs to do asap. I do not know what the regs are in the USA) all go through a German version of the MOT (TÜV) and I adjust my own brakes on the caravan using advice that I obtained from the TÜV many years ago. My brakes are good on the caravan and are regularly adjusted and checked before any travelling is done. Therefore they work and are as balanced (left and right as well as front to back) as good as I can get them......I have never failed the testing on that score (or any other!!).
Although with just taking the foot off the accelerator pedal does not cause my brakes on the caravan to go on (unless going downhill in a lower gear), as soon as I start using the brake pedal in the slightest manner, the caravan brakes also start to apply, exactly how the TÜV Germany told me to set them up. I personally believe that this may have been part of the saving of the situation.
Some owners have the caravan brakes set to practically ONLY apply with emergency braking. I have tried that a long time ago (the man at the TÜV told me it was legal but dangerous!), I personally also do not like the feel it gives to the car....or the jerk as they start to take effect.....or the "shove-on" until they start working.....
I have never been in such a dangerous situation again, but when big lorries overtake or it is very windy, it can feel as though it wants to start again, a light dab on the brakes always stops it immediately before it can get dangerous....
Maybe I was just lucky, but I would do the same again if I was in a similar situation.... getting the amount of brake pressure right the first time was of course sheer luck as well....but now I am not panicked or upset in the slightest if a sway starts....neither is my wife!!!
It would probably be even better, if towing a trailer with electric brakes (USA only I believe), if one could JUST apply the trailer brakes alone......that is only a personal thought as I have no way of trying this out myself....
10/19/2007 7:37 AM
I guess several things are happening, one of which is that weight tranfer will place more weight on the tow hitch, like others have been advocating - though I still don't see just what good this does in itself but Maybe I'm having a mental block so far as this is concerned.
I have a horror of towing, it's always got me in a sweat as I've seldom tried towing anything that hasn't immediately got into a 'wag' on a downhill stretch but I've not had anything quite like the person I followed many years ago with a Rice trailer (with a least one Nag in it, poor thing. It started a sway on a (pretty) level 'B' road. The next thing I saw was the whole rig facing the other way on the other side of the road, just as if it had always been going that way!!
10/17/2007 11:38 PM
I forgot to mention that the normal tongue weight should be between 10-15 percent of the gross weight making yours well over 300 lbs. I found mine was fine at about 60lbs according to a scale used to measure it. I also make sure I load everything forward of the axle.
Ken Brockway
10/18/2007 11:22 AM
300 lbs tongue weight would be highly illegal in Europe.....50-75 Kgs or between 100 and 150Lbs is normal.....
10/18/2007 11:48 AM
Thats interesting because 300lbs on a 3000lb trailer is safe assuming the hitch and vehicle are rated for such. Low tongue weight or overloading vehicles can create unsafe situations. Check this out for a laugh.
http://www.youtube.com/watch?v=Tx0xzqQyMUY
10/18/2007 12:00 PM
A ball hitch in Europe is seldom allowed to have more than 100 KG or 200 lbs on it....no matter how beefy the tow car is......
Generally 75 kg is max.....
But Europe is not America......so I am not certain that 300 lbs is necessarily wrong in the USA as I don't know that....
10/18/2007 12:18 PM
Also, most of the cars in Europe probably aren't rated to tow more than 2000lbs (I'd imagine) so those tongue weights make sense.
I'm from Boston, however today I'm in Rome getting reminded of how small the cars people drive are. No F350 Superdutys here! When's the USA going to wake up and realize that small can be practical! Small cars such as the "Smart" would be perfect for major cities. They can park perpendicular to streets the same way cycles do!
10/19/2007 7:22 AM
A UK motoring organization recommends 4% or 25 kg, whichever is the greater as a possible starting point for nose weight.
I tend to agree using my own experiences over many years...
10/18/2007 3:11 AM
I would think bolting extra weight to the tongue would be easier than moving the axle, springs, mounts etc. Spare tire holder, water can, anvil, rebars, 1ft square by 2"-4" thick steel step would also keep your feet dry when hooking the tow cable. The math is alot easier, 1 water can + 1 gal H2o + 1gal H2o + ...
Ditto on lowering the hitch, worked for my skidsteer.
10/18/2007 4:48 AM
Assuming you are towing the trailer level. You mentioned, "highway speed," and that is most likely the answer to your problem. Far to many folks these days are no longer aware that non-commercial combinations should never be driven more than 45 mph, 55 max.--as the thousand of accidents will attest to. When a trailer starts to fish tail simply ease of the gas (never brake) until the trailer gets in line and maintain that speed or lower and your problem should go away. It is doubtful that you would be able to gain any significant difference (assuming the load in the boat is trimmed) moving the trailer axle...and you could impair steering of the tow vehicle. Safest to assume that the trailer is balanced correctly if it's not home made. Further word: if you are towing in California, better be on guard for Highway Patrol to pull you over. Seems that just a few days ago an entire family was wiped out trying another common trailer pulling stunt: trying to tow a loaded car tailer with a car...always a no-no. So now the highway patrol is really cracking down.
Good Answers: 15
10/18/2007 6:32 AM
I'm aways amazed at what i see people towing with their cars.
I have a 3/4 ton truck and would tow some of the stuff I see being towed with the small trucks they sell these days.
Aways check your allowed weights before hauling anything. Cars & truck are only deigned to carry so much weight. And secure the loads properly. I've seen boats come off trailers because the idiot towing it did not bother to tie it down to the trailer.
I'm not saying this is your problem with the boat. Just that this thought popped into my head when I read this post.
scotchdrnkr
10/18/2007 11:29 AM
Dear Guest, if you look at the recommendations from such services as the British AA or the German ADAC (if you can read German) plus many magazines who cater for people who tow, you will find that what you said was and is completely wrong:-
You should brake firmly. I know it takes guts the first time, but it works INSTANTLY!!! I know I have been there several times and it just works. Tow cars with ABS and ESP work even better....
No matter how well setup your rig is and no matter how well you drive, this will happen to you occasionally, so be prepared to brake firmly.....not violently. Hard, but not hard enough to cause any squealing (except maybe from your passenger(s)!!! from tires or brakes....
10/19/2007 8:00 AM
Thanks Andy. British AA???
I would certainly hope to see the guidelines you recommend. But, let us assume...that the brake firm advise is the way to go. Better still...that it is preferable but that either way done competently will result in curtailing of a "wild trailer" hazard. That being the case, I would be very hesitant to advise anyone to brake firmly in such a situation...for fear that they might apply the advise when, say, towing down a steep mountain road, and/or in icy or wet conditions...where the trailer could lose traction and pass the tow vehicle in a jack knife maneuver. But again, as I said, I would hope to see the guidelines you mention in order to get the entire story about how the braking maneuver accomplishes the result you speak of with no chance of unexpected loss of control.
10/19/2007 5:45 PM
If you are ever in the situation, do not forget my advice.....as you really do not have much time to play about testing what will work and what does not.
The general advice of just taking your foot off the gas and steer a straight line (impossible to do!) will only work if :-
a) you are not on a downhill stretch of any sort (in fact you need to be going uphill with the wind in your face!)
b) You do not have a strong following wind
c) you are not say clocking 20mph or more, MORE than your trailer should be doing, as just taking your foot off will not bring a good result before you and the trailer are upside down in the ditch!
I was in a a) + c) situation with a strong side wind.......!!!!
I hope none of you ever get in the situation, but if you do, you MUST stop the oscillation within probably 4 - 8 seconds max......or you are Toast!!
10/18/2007 10:03 AM
Tail wagging the dog is not enough tongue weight or hitch too high.
*** Rule of Thumb is 10% of trailer weight on the hitch.
*** The trailer should also be level when towing.
Adjust the ball height, use a bathroom scale under the trailer jack.
I have been towing trailers for over 40 years with everything from a motorcycle to a tractor-trailer rig rated for 500,000#
I have a couple of a adjustable ball mounts so I can tow a motorcycle trailer, a log splitter, a small boat trailer, a dump trailer or any one's trailer that needs to be moved.
Most of the time I see guys with "High Rise" trucks trying to haul a small trailer at about a 15-20 degree angle and they are all over the road.
Or the trailer is so heavy that their rear bumper is almost dragging on the ground and they are all over the road.
Get your hitch weight right, make it level and maybe you can top the ticket I got in Texas once while towing a 32' camp trailer. 115mph! No wagging though.
10/18/2007 11:22 AM
10lbs of tongue weight! HOLY COW MAN! That is your problem. When accelerating or going up hills you will have negative tongue weight when your CG shifts back.
You probably want 5-15% depending on your trailer and hitch rating. You only have 0.3%!!! Yes, move the boat forward or the axle back. Your problem will stop.
10/18/2007 10:41 PM
Thanks everyone for your responses. They are much appreciated and I will move ahead and tackle the problem.
Since I do have room to move the axle aft that will be the first modification. In order to move the boat forward it would mean some changes to the roller setup at the bow due to the Load Rite trailer having a centre tongue that would hit the bottom of the bow of the boat if the boat were simply moved ahead. Guess I'll jack the trailer and loosen the axle clamps then use the 5 lb persuader to inch back the wheels about 6 inches.
In answer to some of your questions:
The tow vehicle is a Chevy Tahoe 4x4.
Boat is an 18ft Boston Whaler Outrage with a 135 HP Merc (450 lbs on the stern)
No gear stowed in the boat to offset the balance.
I'll report back on the new tongue weight and the 'success.'
Thanks
Brian
10/19/2007 6:14 PM
Those are awesome boats. I had a 17 Montauk. I felt safer in rough seas in that then I do in my 26ft runabout. Just be gentle as a good whack can damage the hull quite easily. Those boats are like hard boiled eggs. Foam wrapped in fiberglass so a good tap from a rock can cause a soft spot.
Feel free to play around with the trailer, they are very adjustable. Your Tahoe can tow way more boat than that and probably has a class 3 or 4 hitch that can carry a 500lb TW. Never use an OEM bumper hitch.
Reply to Forum Thread 27 comments
Andy Germany (7); Anonymous Poster (4); Bill (1); prbarry (1); Pretendgineer (4); PWSlack (2); Ried (1); scotchdrnkr (1); traditional (1); wb2tdg (2); Wrenched (3)
You might be interested in: Chuck Jaws, Industrial and Commercial Trailers, Pliers
