Inspired by the water shortage blog entry... Isn't it about time someone designed a low water usage toilet pan* that really does removes the offending material? It must be difficult to design/make a traditional ceramic pan , but with modern flow simulation software it should be possible (Is there a computer model of a floater?
The last toilet I installed had a low volume flush but doesn't do the job (even after tinkering to get the maximum water level in the cistern)
You can hardly try before you buy!
Ok I'm sure we'll get some toilet humour, but it's a serious question.
*(This assumes that the dry soil closet just isn't going to be acceptable to the masses)
