Previous in Forum: Why is Infrared (IR) Used in Remote Control?   Next in Forum: 32-Channel Codec
41 comments
Why are Negative Voltages Used in Telephones?
11/07/2007 1:11 AM
& why -ve voltage is used in ringer ckts in telephones
Re: wat do u mean by negative voltage like -48volts
11/07/2007 8:26 AM
Negative to what?
48 volts was chosen due to it being a nice round number of lead acid batteries used for backup of the telephone network.
High enough not to cause problems with resistance of the wires and loads, but low enough not to cause a hazard for consumers.
John.
Safety - Hazmat - Environmental, Safety & Health Manager Hobbies - Musician - Theremin (That about says it all...)
Good Answers: 19
11/07/2007 10:28 AM
Electroman,
Your statement that the voltage is "low enough not to cause a hazard for consumers" is a relative one...
It is true that the supervisory voltage present on the phone line is 48v nominal D.C., but you are forgetting about the ringing signal. Here in the US, the ringing signal consists of an 88v 20Hz A.C. signal superimposed on the supervisory voltage.
While 88v may not sound like a lot, I vividly recall an unfortunate experience I had nearly 35 years ago, as a youth...
I was adding on an extension phone in my parent's house, and was without a mechanical wire stripper – I'd always used my front teeth to strip wires anywhere from 16 down to 30 AWG – certainly no problem with some bell wire. But I didn't think about the possibility that someone would call while I had the wire in my mouth.
All I can say is that 88v across the tongue and lips is not something you will soon forget...
11/07/2007 10:41 AM
This explains your membership to the Safety forum then! When I was young, my mate cut a standard light flex with his pen knife! Blew some big chunks out of the blade! He wondered why it happened as the light was turned off! It was turned of at the switch, but that was closer to the light! Sorry, went off at a tangent on that one! Nothing to do with telephones or telephone circuits! Just thought I would share it with you anyway!
11/07/2007 12:25 PM
Jman, I agree 88 volts is a bit much to swallow (pun intended) but in the UK the ringing voltage is 50 volts (ok 48volts but whose counting!) and the ringing signal is 48 volts to 0 volts, relative to the other wire.
Still not a good idea to have it in your mouth though!!!
I'm not sure whether any side of the twisted pair is earthed or floating, the isolation requirements and load reguirements are pretty stringent though...
John.
Good Answers: 50
11/07/2007 11:11 PM
vi has a point. I do a lot with networking, and ISPs almost always want their equipment powered by 48 Volts instead of 110V or 220V. However, they always want it powered by -48 Volts. I have yet to get a good answer why.
Good Answers: 39
11/07/2007 11:40 PM
Vermin wrote: they always want it powered by -48 Volts. I have yet to get a good answer why.
Stray current corrosion! is why.
When you impress a DC voltage on two electrodes immersed or in contact with an electrolyte ( read wet earth) the positive electrode wil suffer material loss. The negative electrode will either gain some or show little corrosion effect.
By having the phone lines negative relative to earth ( return of fault current) they minimize damage to equipment from corrosion until the problem is reported and cleared.
This also explains why the early british cars had such horrendous electrical problems until they also switched to a negative chassis wiring system. The return current literally ate up the ground wire connections to the chassis. Lucas might be the "Prince of Darkness" but he was aided and abetted by British practice. <grin>
Elnav
Re: Why are Negative Voltages Used in Telephones?
11/07/2007 10:13 AM
Change the probes round on your circuit tester!!
Ireland - Member - New Member Engineering Fields - Energy Engineering - New Member
11/08/2007 12:07 AM
Funny thing, someone asked me this same thing a few weeks ago!
48 volts is used for reasons stated - 50-60 volts is regarded as "touch potential". Having had a 55 volt dc shock while at University from a string of submarine batteries I can verify that this can be surprisingly painful!
The positive terminal is grounded because in the early days of the telegraph bare copper wires were used (beloved of Western movies, being shot from the hip at 50 yards by a 4" barrel Colt....Mythbusted anyone?). Making the wire negative prevented or at least reduced corrosion.
Actually in Exchanges the charging voltage is 54.1 volts. The extra margin allows for volt drop and battery regulation. It's quite unsettling seeing 4000amp dc busbars painted red and blue just running along naked and free, open to touch.
I love deadlines; I love the whooshing sound they make as they pass by. - Douglas Adams
Good Answers: 50
11/08/2007 12:19 AM
Woof!!! Both you and elnav just gave me great answers! Thanks! The best I can do is give both of you a + point on your posts.
Also, I read a story about a guy that go electrocuted by 50V AC and full line current. So, guess it doesn't take a lot of volts as long as the Amps are there!
11/08/2007 12:46 AM
Actually no. The interior of the body is an excellent conductor, and our nervous system works on microamps. A few milliamps is fatal. It's accepted that 30mA is the limit, but of course people with bad hearts or epilepsy etc may be more susceptible.
Our protection is our skin, body geometry and location. So if your skin is wet (or sweaty or cut) you're in trouble as the skin resistance gets very small. Which is why you never mix water and electricity. Or put wires in your mouth.... ;-)
Thus you can get a shock at 50 volts as I did. But I'm still here! If you get the shock across your chest, however (this is where geometry comes in), it could stall your heart (fibrilation). This does not normally work out well.
So experienced people (a) don't poke at things and (b) poke carefully with one hand in your pocket. If they survive, young engineers at University become experienced ;-)
The location factor is all about how well you are grounded. Rubber shoes, nylon carpet, tall buildings etc all work in your favour. But don't try and find out where the limit is!!
Because a.c. can conduct through a capacitance, a.c. can be more dangerous than d.c. But there's not much in it (Google "The Current Wars" between Edison and Westinghouse) - d.c. charges capacitance too. Note also that a.c. voltages are quoted as RMS so the peak is 1.4 times, nearly 50% more.
Amps can be dangerous for a different reason. If you get jewellery across the terminals of a 12 volt car battery for example, several hundred amps will flow and it will melt. Not good if it's around your neck at the time!
Good Answers: 50
11/08/2007 12:52 AM
But isn't it the case that DC shocks immediately drop to ground voltage, while AC shocks do not, thus making them deadlier? Or is this just a myth/misunderstanding.
Good Answers: 39
11/08/2007 2:25 AM
Depends on how you look at it. Most working electricians with experience in both DC and AC systems are more vary of DC because once it shocks you, the muscles contract and the "grip" doesn't let go. AC has zero crossing and as such goes through a zero potential every cycle. This typically means there is a better chance of gravity dragging your body point of contact away from the live conductor. ( Assuming your hand doesn't have a "death grip" on the live wire. )
Voltage potential is dangerous because it breaks down the insulation of protective gear, clothes, skin etc. But like someone else said, the killer is the current flow through the body because it induces cardiac arrest. And 30 - 50 mA will kill. With two pins and a D cell I could electrocute someone.
When I worked for a power utility company we had monthly safety meetings. Every so often the hipot tester was brought out to show how various current flow levels felt like. (never close to lethal levels)
The macho linemen bragged about how much current (in milliamps) they could tolerate before the pain got to be too much. I think the record was around 20mA.
My job routinely involved hipot testing 27.6kV distribution cable for underground use. My tester ran at 70,000 volts but a safety circuit tripped if the leakage current exceeded 10 milliamps.
One time I accidentally got too close to the test cable. The current went in my knee cap and out my steel toed boot planted firmly on the steel deck of the truck. Thankfully the current path never got anywhere close to my chest. Even so, it took an hour and a half before my leg muscles stopped cramping enough for me to stand up. It kept hurting like hell for a day afterwards.
When I am wiring 24V DC power circuits in steel hulled vessels on a hot summer day I see flashes of light in my eyes and and get a distinct headache from repeated contact with the battery posts. Doing the same work on a cool winter day with no sweat, I dont feel a thing. The difference being the lowered skin resistance as I sweat. Working on metal hulled vessels means you can't avoid being grounded. Same work in fibreglass hulls is never a problem. Its like doing bucket truck work on high voltage lines.
Personally I'm more vary of DC powe than AC. DC burns tend to go deeper into the skin and take much longer to heal. I have survived 45 years of this stuff but it still scares me. Maybe that's why I'm still alive. Too scared to get too close!
elnav.
Elnav
11/08/2007 4:37 AM
I have been working in the electrical field for over thirty years and experienced three serious electrical contacts. One at 500VDC (+ to -), one at 600VAC (phase to phase), and the last at 13,800VAC (30 amps phase to ground with the entry at left hand and exit point at lower left leg). All of them induced a very high level of pain but nothing can aproach the level of pain and destruction that my body experienced during the 13,800VAC contact. Funny thing is; all three times I was assisting others on a consulting and/or technical application level and all were a result of unwisely trusting other people and existing safety programs.
The point?
ALL ELECTRICAL CONTACTS HAVE THE POTENTIAL FOR PAIN, CELL DESTRUCTION, AND/OR (IF YOU ARE LUCKY) DEATH.
LOWER VOLTAGE CONTACTS CAN DO DAMAGE THAT IS NOT VISIBLE BUT HAVE LASTING SIDE EFFECTS.
DO NOT TRUST ANYONE, ANYTIME, OR ANYWHERE.
VERIFY THERE IS NO POTENTIAL PRESENT AND MAKE SURE THAT IT IS DEAD AND GROUNDED BEFORE YOU TOUCH IT AND IF YOU CANNOT DO SO, DO NOT GET NEAR IT WITHOUT THE PROPER TRAINING AND PERSONAL PROTECTIVE EQUIPMENT AND SAFEGUARDS.
TAKE CARE, STAY SAFE AND BE HAPPY!
cordially,
SHOCKHISCAN - (My new Indian name-"he who danced with the devil and lived")
Arizona
11/08/2007 5:07 AM
WOW and thanks.
Wise words oh SHOCKHISCAN !
Popular Science - Weaponology - Greets to all who travel this road! Safety - ESD - Ground Strapped and Unafraid
11/08/2007 5:49 AM
Your comments have resurfaced my not so fond memories of taking hits from floating ground avionics.
Most notable was the 450VDC hit I took as a young airman in the navy testing a gun control unit. I was testing the unit when the ship rolled and the unit slid across the work bench and headed for the deck. It was under power and when I used my hand to steady it I took all 450VDC and pretty much 50+ amps current through my palm to my wrist across some exposed filters. It vapor locked my arm gave me a case of stars and burst my skin on exit point - Needless to say when I get around avionics ( as I do in my profession now ) I always look to my wrist and remember. Many avionic controls are 28vdc but can pack a wallop of 50 or so amps. This has been burned in my mind forever as a result of my experience.
We had a kid in the lab on my last cruise repairing large display units. Some of us here will remember the old Simpson meters. well he took a pair of regular leads across a circuit on a display and it kicked him like a mule 35KV off the tube the Simpson never worked again ( they are really hard to kill ) I remember he was shaking as he came to me as I was the Senior tech asking me in halted speech why it happened. As I looked at the schematic I noted he was on the bleeder network for the tube. He was expecting 15vdc. he had poked at it on the wrong side of the circuit and it left a mark. He ended up fine but we had him in the sick bay for a few days while they watched his ticker. He had acquired the moniker of "35KV kid" and we framed and mounted his Simpson and gave it to him as a farewell gift at the end of the cruise.
Heads up, never underestimate a piece of equipment and understand what your poking at before you even move. Some of us remember the first time we reached into an old tube circuit TV without a grounding strap already applied. ( I did at the ripe old age of 8 as I wanted to help my dad)
more slower is often mo better . . .
the good news is after all the pops I have taken haven't affected me a bit .. bit bit.. bit.. uh yeah thats it.
If there was smoke it may be broke!
11/08/2007 8:24 PM
RF burns are worst, they don't always heal. Just a black hole in the skin
Out Of The Inner Circle
11/09/2007 5:59 AM
Quite....
This is the origin of ANY Black hole, it starts small and never heals.....
11/08/2007 4:03 AM
You demonstrate clearly a proper and full understanding of electricity as regards to its dangers, few people do (even some engineers have areas they do not understand fully, though they think they do!).
My compliments.
11/08/2007 1:34 PM
I was once told by a very experienced field motion control engineer that DC is far more dangerous as it is similar to the kind of electricity your body works with in the nerves and the muscles. This did make sense as biologically your body does work with dc voltages to operate muscles and for nerves to signal. I never actually looked it up in detail so it could be wrong.
11/08/2007 2:24 PM
I have read this time and time again from real experts that DC is more dangerous than AC.
All I can say is that my experiences in the RN a great many years ago were the opposite!
Older ships (WWII and a bit later) were still around and were 220volt DC, with an open faced switchboard that you could (and occasionally did accidentally) touch all the bus bars and cabling. I am sure that a few people died over the years, but I never heard of anyone actually dying. I knew a few stupid people who got bad burns, but lived to talk about it afterwards....we even searched for earths with our fingers bridging where a fuse had been, got a jolt, that was the earth!!!!
Later Ring main carriers closed the DC off mostly, but not completely....
With NATO, RN ships went to 440 AC 3 phase, the first ship built with an open plan switchboard (early 50s at a guess!), people really started to get killed immediately, ship was removed from service and closed face switchboards only from that moment on.....
So my experiences were in total opposition to the Guru trends.....sorry....
11/08/2007 9:31 AM
Quite. In the absence of any test indications or test equipment a 48VDC power supply can be affirmed running by touching the terminals with a dry finger. Once is usually enough for this game; does anyone want this T-shirt?
11/08/2007 3:13 AM
Modern telephones don`t matter for -ve or +ve voltage as they have polarity corrector like bridge diode ckt to ringer ckt also, they were meant for those old antique telephones with vibrator bells for transient locks in the coils switching from ringing mode to online / offhook mode , in simple terms proper grounding path to DC , next electronics telephone continued with this .
11/08/2007 9:59 AM
On the issue of safety:
I understand that under the skin, the chest cavity has a resistance of approximately 200 ohms. So loss of skin resistance could results in lethal current levels at 48 volts (30-50 mA can kill, and it is possible at even lower levels).
Good Answers: 39
11/08/2007 3:48 PM
I think we strayed away from the original question.
Why is telephone power -48V as opposed to +48V.
this potential is obviously measured relative to earth potential.
The reason for the negative potential is for corrosion protection when wet outdoor cable and or equipment sees a low resistance to earth. If the telephone wires were positive with respect to earth, far greater corrosion damage would take place.
Pipelines and other underground structures are also protected in a similar way by impressing a negative potential with respect to earth.
Elnav
11/09/2007 5:58 AM
You wrote:-
Isn't that what CR4 is all about and why we (I am not so sure about you personally though on this point!) have so much fun!!!
Please mark me as off topic whenever and where ever you wish!!
I have even marked myself as being "Off topic" on this answer to you!!! I even enjoy doing that before anyone else gets a chance!!!!
11/09/2007 8:48 AM
Anyway I thought it was he who answered correctly in the first place isn't it? That indicates, via the use of dc or ac voltage to some led on a control panel, that this thread has officially stalled so we are now in free for all
11/09/2007 8:57 AM
Others had mentioned it already, its fairly common knowledge also....
I agree, now is a "Free for All".....
Whats up Doc?
11/09/2007 9:01 AM
Dunno, I was kinda scrolling through the daily stories when you butted in so now I am replying to you instead of looking at new threads.
How about you?
11/09/2007 4:41 PM
I was at the Chiropractor today with dreadful backache, it seems that several of my vertebrae have welded themselves together, he broke them up, but the pain will take a few days to disappear. At least I am not getting the "lightning strikes of pain" when I reach for something!!
He X-rayed me and pronounce that I am now fit for anything!!!! (Or did he say nothing???)
Good Answers: 39
11/09/2007 10:28 AM
I had not seen any sign the original questioner had actually seen the actual reply to the question but the thread morphed so rapidly ( like a virus) that the original intent vanished. Yes I do enjoy these serendipitous discussions. <grin> Sorry; my thread subject discipline was acquired elsewhere. It probably doesn't suit this forum.
Now I realize why some comments are in compressed form.
Elnav
11/09/2007 10:36 AM
This is one of the most annoying things with forums. I alwasy make a point of answering back my own threads just to be polite. Wish more people did. Sometimes you get a nice guy come past and that makes it all worthwhile
11/09/2007 4:43 PM
I would too if I ever start one, its just simple good manners, you were well brought up!!
11/09/2007 8:03 PM
After all this negativity, I must reply.
"Why are Negative Voltages Used in Telephones?"
Because talking on the telephone is a negative thing to do!
11/10/2007 9:19 PM
You mean why Ground the Station Battery?
EletroChemical-- Cathodic Protection of cable sheaths.
11/11/2007 9:03 AM
I think your post would have been better if you had written instead:-
You mean why Ground the Station positive Battery terminal? (and not the negative)
11/16/2007 2:43 PM
Here in Pakistan it is 60VDC & 25Hz Pulsating DC; NOT Mounted on DC [Modulated] for Community Telephones & 48VDC for PABXs [Private Automatic Branch Exchange].Both the wires are well insulated from earth [ground].Lines are marked as "A" & "B" & when any of the wire leaks to Ground it is marked as Wire "A" or "B" Ground-fault.
For information its ZO [Characteristic Impedance is 260 Ohms [Normally talked about 300 Ohm line]Telephone cable, Fig "8" [Parallel] called "Drop-Wire" is a good 300 Ohms TV Feeder.
What in rest of the World?
11/21/2007 8:18 PM
case491 #20
" I was once told by a very experienced field motion control engineer that DC is far more dangerous as it is similar to the kind of electricity your body works with in the nerves and the muscles. This did make sense as biologically your body does work with dc voltages to operate muscles and for nerves to signal. "
Of course it is correct.
DC has no zero at all when in contact, while AC has a zero @ every zero-crossing
[twice every cycle].
We the Engineers & Techs are told & have HABBIT to sense a live line or surface by touching it with back of fingers.
Reason the skin at back is more sensitive than the front-skin
*** MORE IMPORTANT ***
The fingers close inside the Paw by sub-conscience
SO the fingers will naturally go out of contact of wire or surface
IF a leakage of LIVE line is present
I am a retired Bio-Medical Engineer had been looking after all type of
Electro-medical [we call it so] from Cardiac-Systems , X-Ray Units, Patient monitoring & Diagnostic [Pathology Labs], Dental-Units; phys-therapy-equipment etc etc
Except Cardiac-graphs [ECG] & Encephalographic which work on regular wave-forms specific to Heart & brain; almost all the "muscles and nerves " function on DC-Pulses; e.g. If you shift your eyes to left or right side Polarity of Voltage across your sides of eyes [left & right] changes.
In swallowing of diet the food-tract produces Dc signals progressively squeezing from top to bottom and all the valves in the tract function in harmony to shift the in-take smoothly to stomach.
Electrical-Signals from upper valve sent to lower valve to open & feed-back of the lower to the upper to squeeze downward till it reaches the stomach. A fool-proof sequence of operation.
Lower-Valves opening & upper valves squeezing to shift step-by-step to stomach smoothly.
etc etc.
Good Answers: 50
11/22/2007 12:21 AM
What's all this talk about DC being used in the body?! My nervous system is composed of optical fiber! Isn't everyone's?
11/22/2007 4:01 AM
If your comments were as any sort of reply to what I wrote earlier, I can only say that you are basing your thoughts on opinions from other people, eg only opinions....not facts......no matter how good the source feels he is on this matter, opinions only....
I was basing my comments on facts that I have assembled from personal and sometimes quite painful experience(s). There is a world of knowledge and difference between this and the "opinions" you base your knowledge on!!!
If there are any other "Old Greenies" from the RN online, that also saw service on older DC destroyers/Aircraft carriers in the 50s and 60s, they may be able to back up what I have written for you....
I would also like to say that it is a huge failure in this life to take the opinion of other so called "experts" who have themselves no actual practical experience and promote this as fact!!!
No "expert" that I have ever met, has actually had physical experience in such areas, it is always what they "feel should" happen.....!
BIG FAILURE GUYS, YOU ARE ALL WRONG IN THIS AREA !!! The difference between theory and practise!!!!
If you are unwilling to get a few shocks and learn what really happens in real life, then at least learn to listen to someone who has, even if I did not ever do it intentionally...... except when earth chasing on 220vott DC ring main aircraft carriers....
I had my first 230v AC shocks as a 2 year old on the old British round pin system.......I am still here......surprisingly....and definitely more by luck than judgement at that age and on that voltage!!
I will say it once and once only for anyone who would like to really learn something, generally speaking AC kills more people than DC prportionally. It always did and it always will.....
Of course voltage plays a role, which is why in many countries only 110volt AC is used, but healthy people STILL die every day on that too.....
I have never heard of anyone dying on 110V DC. It is used daily in many dockyards around the world for lighting on dry docked ships...for example........why is DC used and not AC - because its safer!
Go and experiment using your OWN fingers first, you still have a lot to learn in this world! You are not alone either, many many people promote this failure in books and encyclopedias etc., so many believe it!! That does not make it true....
"Must be true, its written in this book !"
Good Answers: 50
11/22/2007 11:15 PM
So how many years were you in the institution after that first shock before they were willing to let you out?
Woof!!! Andy!!! What is your resting blood pressure? I'm guessing higher than healthy?! Relax! I guarantee, you're definitely not responsible for the rest of the world - and try to take comfort in the fact that you're not!!!
11/27/2007 6:28 AM
Ok Andy hold still . . .
Poke!
Anyone that has ever tangled with high voltage dc knows they can usually get away with a lot more than tangling with high voltage ac. What with all the smokin hair and stuff. While I'm not a greenie i have been working on military birds for too many years to admit and have been bit by all varieties of dc. I prefer it to getting bit by the lousy 220vac I ran into in the Mideast after the Brits messed them up and gave them the horrid 220vac vice 110vac system - oh and lets not talk about them lousy roundabouts.
I still have one vivid memory of electrical engineering in Kuwait. The day a "Kuwaiti Engineer" came to my house with a light bulb with two wires attached to it to" verify the house voltage" I had complained after seeing a variance of about 118vac moment to moment because they didn't have the area properly balanced after the invasion and subsequent liberation. My electronic controlled servo transformers STAC's were trying to commit suicide trying to keep up, anyway I remember him smiling and in the best English he could muster he looked at me as if I was stupid and said look the light is lit so your voltage is good Mr John. At which point I pulled out my DMM and showed him. he was mildly irritated and reconnected his light bulb to the circuit and it lit again. Apparently he had been told the opinion that if the light lit it was good. Well the fact was it wasn't so much for opinions. I decided he wasn't the first in class in his engineering program ( I have met excellent Kuwaiti engineers) and later that night I jimmied the local load center building's door and adjusted my voltage up a bit and took a look across the rest of the homes on my block and suddenly everything was working better (after a few well placed adjustments over the course of the week ) The light still lit but now at or near 220vac. my STAC's breathed a sigh of relief and I didn't have to listen to them servos drive the wiper over such a vast area of transformer windings.
Also on the point of the touching circuits by hand to check the "Live" factor - Dumb. Assume its live until verified otherwise using a meter. I understand back in the day we could do all that but man a cheap meter that can handle a pretty good dose of voltage is cheap anymore why risk your limbs . In fact I remember grabbing a feed horn on an airborne radar in an F4 to see if my hand got warm - " yep its working " or climbing up on the nose of a bird and "kicking the package". Ever put a fluorescent light bulb in an RF field?
Young and dumb, now I use field strength meter and a DMM. As far as voltage I will never forget the time I was on the turtle back of a F14 Tomcat in California and it had been raining a while when a lightening bolt hit the flight line about 800 yards to my left i felt it charge up my arm into the avionic box I had in my hand and back to the airframe. I decided the bird was up and it was time to call it a day.
Your mileage may vary . . .
Remember opinions are like butt holes, everyone has one.
Now Andy take your meds. . . after all I have taken mine.
Register to Reply 41 comments
Andy Germany (10); Anonymous Poster (1); BabyGuinness (2); case491 (4); Electroman (2); elnav (4); Haajee (2); Hap (1); Mr. Truman Brain (2); MUKULMAHANT (1); PWSlack (1); RickRS (1); StandardsGuy (1); The JMAN (1); vermin (5); vikas (1); Zap (2)
