Previous in Forum: AVR   Next in Forum: Courses
21 comments
hub and wheel motor
11/10/2007 5:03 AM
what is hub motor? what is wheel motor? what are the differences between them? which one of them has good performance? if you help me I will be very happy
Re: hub and wheel motor
11/10/2007 7:31 AM
A hub motor to me means a motor which is at the hub of the wheel, so the wheel is the rotor of the motor, maybe through gearing etc...
A wheel motor is... errrmmmm a motor driving a gearbox/shaft with the wheel attached, I guess?
John.
11/10/2007 8:13 AM
Are you talking about powered bicycles? If so, I'd say a hub motor is fitted to the hub, and a wheel motor mounts up behind the saddle, with a roller which bears against the top of the tire to transfer the power.
Can you put you question in context?
11/10/2007 5:31 PM
I take a hub motor and wheel motor to be the same thing....
11/11/2007 12:13 AM
From Wikipedia:
A hub motor is an electric motor built directly into the hub of a wheel. A purported advantage of this design is that no additional transmission system is needed, thereby increasing the efficiency of the drive system. However, because electric motors are most efficient at high rates of revolution, direct drive hub motors tend to be inefficient. Integrated planetary gear drivetrains are sometimes included, but re-introduce transmission losses. They are commonly found on motorized bicycles. Hub Motor Electromagnetic fields are supplied to the stationary windings of the motor. The outer part of the motor follows, or tries to follow, those fields, turning the wheel to which it is attached. Energy is transferred to a brushed motor through physical contact of brushes to the rotating shaft of the motor. Energy is transferred to a brushless motor electronically, requiring no physical contact between stationary and moving parts. Brushless motor technology is more expensive, but most are more efficient and longer-lasting than brushed motor systems. Most of the hub motors made in China are designed for bikes with Chinese dimensions but these conversion kits are made to suit western bike dimensions. Hub motors are not a new idea. In 1902 Ferdinand Porsche at age 27 working for Lohner developed hub motors which initially ran on lead acid batteries and soon after had a petrol generator to charge the batteries: the first Hybrid vehicles. [2] Hub motors can also be found on buses.
The proposed Zap-X Electric Vehicle envisioned to enter the market in 2010 "would use high-tech electric hub motors at all four wheels, delivering 644 horsepower to the ground from a lithium-ion battery pack. The hub motors would eliminate the need for transmission, axles and conventional brakes, opening up space beneath the floor for a giant battery pack."[1]
Nothing is wrong, everything is true!
Canada - Member - New Member
Good Answers: 11
11/11/2007 12:22 AM
Can you tell where these two types are quoted?
Do do seem the same, unless:
Wheel motor: the stator is the inner part (axel), the rotor is the outer part (rim).
Hub motor: The stator is the outer part (chasis), the rotor is the inner part (axel).
11/11/2007 3:49 AM
thanks a lot for your helping
Engineering Fields - Piping Design Engineering - New Member Australia - Member - New Member
11/11/2007 4:58 AM
If you are talking with regards to heavy earthmoving plant then there may be a difference.
A hydraulic hub motor is a normal hydraulic motor with beefed up nose (shaft) bearings (usually taper bearings). This enables the motor to act as the axle of the machine.
A hydraulic wheel motor can be as above BUT may be designed to fit behind a planetary reduction box and brake cardon shaft. The reduction box, in this case, takes the load of the machine and the hydraulic motor gets its name cos' it's driving the wheel (albeit indirectly)!
"A common mistake people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools!" Douglas Adams 1952-2001. E&OE!
11/11/2007 5:14 AM
I remember In the old days we had a moped calles solex. These had a 2 stroke single cylinder engine sitting under the handlebars with a lever poking up. You could "engage" this engine to touch the front tyre of the moped with its rubberized drive wheel.
This is what I would call a wheel motor. This is not to say that there are no different versions or interpretations elsewhere.
Hub motors are explained above in great detail, they just sit in, or are, the hub of your wheel.
11/11/2007 5:27 AM
That's the kind of think I was talking about. When I was about 7, my brother (then 11) got hold of an engine that could be bolted on the back of an ordinary bike. He fitted it on my 20" Rayleigh.
He used to sit me on the crossbar, and we'd go hurtling around the local footpaths. Used to scare the s**t out of me!
When the bike got written off, he cut the frame up to make pipe bombs.
11/11/2007 5:35 AM
You imagine sitting on that hot running 2 stroke which, in case you had not noticed, is driving the front wheel. These vehicles, if you want to call them that, were notoriously dangerous as anybody knows, when you drive the steering front wheel of a 2 wheeld thing, it becomes very unstable.
Also you had to take your hand of the handlebars to stop the engine driving the wheel, nice in emergencies.
11/11/2007 5:40 AM
Ah, the good old days! Then along comes the HSE & spoils all the fun !
11/11/2007 5:58 AM
I'm sure you and your brother completed the appropriate risk assesment, and HSE paperwork, before hand . Ah those heady days of childhood .
11/11/2007 6:34 AM
Berkshire, You were 7 and your brother 11, that is near enough heathrow airport.....Did they not have some terrorist atack on a plane once and they never found the culprits, ........oops
Sorry
11/12/2007 7:27 AM
I believe I had the same motor at one time......it was fun, but I registered mine as a moped....
By the way, is your brother still alive or did the pipe bombs finsih him off?
11/12/2007 10:03 AM
By some miracle, he survived, intact. I seem to remember that part of the process involved hammering the end of the (charged) pipe over to seal it! I keep well clear.
11/14/2007 7:55 AM
Sorry, but you must be very brave to own up to owning a Velo-solex they were sooooo unkool, I think the French built them which explains a lot I'm afraid I have to agree with you on the rest. Have a great day in sunny England
11/14/2007 12:32 PM
I must be indeed, I also owned up to owning a harley with a problem, you should have seen the flack I got for that
http://cr4.globalspec.com/thread/13928#newcomments
11/16/2007 1:17 AM
Good to see you've moved on to better things
11/11/2007 9:08 AM
Hub motor has direct electronics embeded for controls of RPM , applicable in electric vehicles and other were compactness is desired , wheel motor .......hmm... is same , it is just other name for non technical simplifications , they have in built precise electronic control plus planetery gear system for better control over all RPM range and specially represent automobile only and not other applications say industrial , i remember when certain service manuals in computers for CD ,FDD ,HDD refered wheeled motor directing for media drives instead of hub motors or just motors some 12 years ago
11/11/2007 11:47 AM
There are several companies that develop wheel motors for the mining industry GE is one of them, try this link www.mining-technology.com/contractors/transportation/getrans
Jim
11/12/2007 1:33 PM
Please See somewhere in CR4:
http://cr4.globalspec.com/thread/9944/RPMs-and-Hub-Motors
Hub Motor for Electric Vehicles(Rotor on the outside) http://globalspec.ip09.com/rd/9z1z2hg1opmkd54retqto1o022g6d5ncje587prjbc0
(Electrical Engineering)
> 27 Postings
Register to Reply 21 comments
Andy Germany (1); Anonymous Poster (1); Beej50 (1); bravelon (1); case491 (4); Dumitru (1); Electroman (1); facilitator (2); gigaconcept.com (1); Haajee (1); JohnDG (4); user-deleted-1105 (2); vikas (1)
