Previous in Forum: Primary Variable Chilled Water system   Next in Forum: 4 Cylinder Diesel Engine Turbocharged-Blow by
V Belts
11/14/2007 12:16 AM
Why do V and Timing belts have a 'limited' center distance?
Good Answers: 97
Re: V Belts
11/14/2007 1:33 AM
A small centre distance will imply a smaller arc of contact on the smaller pulley.
Reduced power transfer and slip.
Limited in the sense that the pulleys are touching?
Good Answers: 183
Re: V Belts
11/14/2007 7:03 AM
The maximal distance between the pulleys is function of the own frequency of the belt working as a "cord" under tension. The higher the length the lower the frequency so that a resonnace could occur. The distance depends on the type (section), compound and inbeded es or fibers.
Good Answers: 120
Re: V Belts
11/14/2007 11:13 PM
the main reason is heating due to the change from straight to curved as it goes around the pully. The smaller the radius = more heat = early failure
Per Ardua Ad Astra
Re: V Belts
11/15/2007 10:09 AM
I assume this discussion applies only to "solid" V belts. Not to...what could I call it--"castellated" belts. Where the belt need not flex, only a small thickness of the outer diameter. Failure rate on these seems no worse, maybe better than solids on large pulleys...now 15 years with no apparent degradation and no loss of tension in my case.
Anonymous Poster (1); aurizon (1); Hendrik (1); nick name (1)
