hello.
we have fire hydrant system with Jockey pump maintaining the pressure in the sytem while the fire system in hot stand by..the jockey pump maintains the system pressure to 125 psi.But we are noticing there is increase of pressure 0.5 bar every two hour in the sytem despite of jockey pump in off position.The pressure increased to 180 psi some times..The sytem is provided with pressure accumulator of 125 psi..why the pressure is increasing when jocky pump was not running..is there a need to provide pressure relief valve in the system
