Previous in Forum: DG power factor   Next in Forum: Risk of operation in power plant
Earth Leakage relays & their use in AC system
11/25/2007 4:28 AM
How does Earth leakage relay for 415 v AC works ? Is it really necessary to have them or is their any way to by pass them safely ?
Good Answers: 230
Re: Earth Leakage relays & their use in AC system
11/25/2007 4:59 AM
Hello Ritesh,
It appears that you have entered your entire Homework assignments in these several almost simultaneous questions.
You could also research your subjects via Internet Search Engines.
The reason I say that, is that your questions are ones not well formulated, and look as if your teacher has given you several questions as a Homework assignment.
If you just Copy/Paste answers from here, you are never going to actually remember them, when you are going to need those answers most...in an examination, or later in a Professional situation.
If you do a bit of effort, and actually research the answers (remember to formulate the questions in a more complete way), you are likely to retain the information for life.
If this is not so, please advise here, formulate your questions so they can actually be answered, and I'm sure you should be helped......
11/26/2007 7:41 AM
Ritesh Chander
why do you ask your childish questions so many times on CR4?????
Even the same questions twice on the same day????
Register to Reply 2 comments
