Previous in Forum: Wiring 3 phase transformers   Next in Forum: Circuit diagram for single phase to 3 phase supply
8 comments
Home Owner
12/06/2007 10:42 PM
I was just watching Wheel Of Fortune. The directors had Pat change his tie because the colors of his tie were clashing or causing some can of problem when displayed on the monitor. Pat mentioned HD. Does HD have problems with colors clashing?
Pathfinder Tags: HD
Good Answers: 230
Re: Home Owner
12/06/2007 10:46 PM
Hello pgcoop,
  1. To be able to answer your question, please advise what HD stands for.
  2. Also advise which Country the "Wheel of Fortune" show you watched was showing in.
Thank you....
Re: Home Owner
12/07/2007 1:45 PM
In the good USA and HD TV is high definition TV
Good Answers: 97
Re: Home Owner
12/07/2007 12:31 AM
I don't know about HD etc.
The tie must have interfered with the light intensity meter on the system. Probably reflecting too much light of a particular frequency and thereby resulting in an unbalanced setting.
Re: Home Owner
12/07/2007 2:15 AM
HD aside, they may have been using 'blue screen' superimposition techniques (as used for filming 'Superman' etc.) where everything of a specific colour is treated as transparent, allowing a background image to show through. This would probably have animated the tie on screen.
Good Answers: 230
Re: Home Owner
12/07/2007 3:44 AM
Hello again, pgcoop,
I've just had a further think about this question.
HD evidently stands for High Definition TV.
In the context of the "clashing tie", it may well have been a tie with a striped or herringbone pattern on the front.
Ties with some colour/stripe combinations, have in the past caused odd effects at the receiver, after the signal processing in the Studio, transmitter, and receiver.
Kind Regards.....
Re: Home Owner
12/07/2007 4:58 AM
The problem is usually stripes causing Moiré fringes with the line scan. Thes fringes are the broad shadow like lines you can see sometimes when looking at a mesh or through near parallel railings.
Re: Home Owner
12/08/2007 5:15 PM
Commonly referred to as strobing.
Nothing exceeds like excess.
Re: Home Owner
12/07/2007 1:48 PM
Thanks for all your imput about the colors in HD TV and the tie. I just found this web site the other day and in two days its been more useful than others that I've contact for years. Thanks again for all the discussion.
Register to Reply 8 comments
Hendrik (1); Jaguar (1); JohnDG (1); pgcoop (2); Sparkstation (2); user-deleted-1105 (1)
You might be interested in: Tie Down Straps, Hydraulic Cylinders, Air Cylinders
