Previous in Forum: Plate Heat Exchanger leaking during hydrotest   Next in Forum: Reducing a metal plate thickness
23 comments
Good Answers: 204
Abrasion Resistance Comparison
07/05/2022 6:36 PM
In today's age of supply chain shortages, I am looking at Polyurethane as a coating or casting of a liner for a Cyclone in a Hydrovac truck (I work as a designer), rather than a rolled steel insert. (with goop for sealing)
I'm having difficulty comparing things that would have been traditionally used like AR400, (now a long lead time and expensive material) which uses Rockwell or Brinell hardness testing, or a sliding surface abrasion test, with the Shore D hardness test used for the resin based systems.
As Hardness is not a direct indicator of abrasion resistance, I'm looking for some basis of comparison to evaluate materials for this cyclone application. (I've requested quotes for Hardox steel inserts, Cast ceramic inserts, etc. but I have installation constraints too.)
with several other constraints I'm facing, some help on this particular issue would help a lot.
Thanks in advance for any information you may have.
(example material)
https://www.astm.org/g0133-05r16.html
Re: Abrasion Resistance Comparison
07/05/2022 9:21 PM
I would go with impact resistance testing....
07/05/2022 9:56 PM
Good Answers: 204
07/05/2022 10:40 PM
yes
Good Answers: 204
07/05/2022 11:13 PM
Good Answers: 204
07/05/2022 10:43 PM
I believe the shore system uses an impact. https://en.wikipedia.org/wiki/Shore_durometer
What I need is some way to compare apples.. Shore to Rockwell, Brinnel etc.
07/05/2022 10:55 PM
Good Answers: 204
07/05/2022 11:09 PM
Excellent, thank you!
07/06/2022 12:04 AM
07/06/2022 5:02 AM
Check out the specs on UHMW Polyethylene.It is used as liners in mower decks,snow blades, chain tensioners,conveyor wear strips,even artificial joints etc.Higher resistance to abrasion and impact than most hardened metals. Hardness does not always mean wear or impact resistance.The stencils for engraving granite tombstones are made of rubber,the sand from the sand blaster simply bounces off of the rubber.
07/06/2022 5:56 AM
Here is a link that will help inform your decision.
http://www.linktech-inc.com/comparison-chart.html
The impact resistance is superior to steel,and the friction coefficient is second only to Tefllon.This will make all parts easier to clean.
Note:It is very hard to bond UHMW with adhesives,but it can be done by heating the surface before applying adhesive.Consult the manufacturer for more details,if you decide to go with this.Also must allow for thermal expansion if temperature extremes are to be encountered.Mounting in strips with a gap between is preferred to a single large piece in large application.
07/06/2022 7:59 AM
Welcome back!
Good Answers: 204
07/06/2022 9:00 AM
Thank you. It has been a while. I was struggling with the problem, and said to myself, “Who can I ask? I wish there was a community of brilliant experienced people I could turn to, to ask… and then I remembered CR4…
07/06/2022 10:31 AM
With hardness, your fractureability may increase. But… I did a large cyclone, that was made out of 304ss stainless, it did wear, product was sawdust, had to replace it after 10 years of constant use, it had patches. I replaced it with 310ss, which is supposable more abrasion resistance. Something to think about.
Some funky posting/punctuation structure going on here at cr4
07/07/2022 10:15 AM
In the paper industry in New England area, we used Plasma Coatings, Inc (Middlebury, CT), now merged with American Roller Company, to do on site spray coating of various metals, tungsten & Teflon traction-release compound, traction compounds and others. All of the items were exterior sprays on machine cylinders and rollers, so interior application could be tricky, but probably doable.
Good Answers: 204
07/07/2022 1:14 PM
Thank you.I imagine it would be very difficult. There is an 18” hole for access in the top., and the reach would be 4ft.
07/07/2022 2:11 PM
Perhaps a skinny employee?
Good Answers: 204
07/07/2022 9:36 PM
Drop a dwarf? Not pc.. lol
07/07/2022 11:04 PM
Sounds like a job for a robot ....
07/12/2022 7:19 AM
I would never stoop so low.
07/07/2022 2:26 PM
Wear resistance and impact resistance does not directly correlate with hardness of the material.An aluminum piston will wear out a hardened steel wrist pin,even though the pin is much harder. Chain tensioner blocks on Motocross chains are made of UHMW.They are exposed to hard grit,impact,and mechanical stresses probably similar or worse than your application. Timing chain tensioners on many vehicles are made from UHMW. The lubricant it not necessary,but is part of the environment.UHMW blocks are used in mining conveyors,and resist terrible wear and impact.
A consultation with a UHMW manufacturer might result in the best method of attachment for your application.
Good luck!
07/13/2022 4:20 AM
Here is a very informative article that outlines the pluses and minuses of various anti-abrasive,impact resistant materials. https://www.biomassengineeringequipment.com/wear-resistant-materials-conveyors-stainless-ar-steel-galvanized-uhmw/ For some reason,the add-link option does not appear on this page,so just copy and paste.
Good Answers: 204
07/27/2022 5:28 PM
Thank you for the article. I contacted a plastics mfg company. They said first, that the UHMWPE is more abrasion resistant than HDPE. I need to make a cone from sheet material between 1/4" and 1/2" thick. They said this would be difficult. I have to send an RFQ with drawing.. but expecting it to be exorbitant.
I know that UHMW can be step-bent into a cone, but maybe not at the 1/2" thickness. I'm not sure about adding heat to improve the forming. I agree that the UHMW would be very resistant.. but I need to make something, and then do some testing on it, before we offer it as an insert solution for the cyclones.
08/20/2022 8:31 AM
UHMW is practically indestructible in an abrasive wear application.It is used in motorcycle dirt bikes as a chain tensioner, dirt,sand mud,no lube required.
It will outlast bearings in such applications.It is also used in automotive applications as a timing chain tensioner,immersed in hot oil,and in conveyor as guides.
I have seen UHMW pillow block bearings supporting 400 lb loads on a 25mm steel shaft,slow speed, run for years with no visible signs of wear.UHMW is not suitable for high surface-speed applications,such as forestry mulcher bearings,etc.,but you cant beat it for abrasion and impact resistance.
If you can get your machines to incorporate this,it will definitely reduce downtime.
I have suggestions on some ways to do this if you PM me.
Register to Reply 23 comments
chrisg288 (8); HiTekRedNek (7); phoenix911 (1); Randall (1); rwilliams (1); SolarEagle (5)
