Previous in Forum: mck alternators   Next in Forum: Applications of Tin plating & silver plating.
question
12/15/2007 7:05 AM
what is form factor?
Re: question
12/15/2007 7:45 AM
Please clarify your question.
John.
India - Member - Electrical Energy
Re: question
12/16/2007 12:27 AM
This is the ratio of RMS and Average Value of electrical quantity.
Re: question
12/18/2007 6:42 PM
Shape of a coil. (diameter/length)
James
" adapt, improvise, overcome "
Re: question
12/19/2007 12:51 AM
Form factor : The ratio of RMS current to average current. This number is a measure of the current ripple in a SCR or other switch-mode type of drive. Since motor heating is a function of RMS current while motor torque is a function of average current, a form factor greater than 1.00 means some fraction of motor current is producing heat but not torque
BNDas
Re: question
12/19/2007 12:54 AM
Form factor
The ratio of RMS current to average current. This number is a measure of the current ripple in a SCR or other switch-mode type of drive. Since motor heating is a function of RMS current while motor torque is a function of average current, a form factor greater than 1.00 means some fraction of motor current is producing heat but not torque.
BNDas
biswanath.das (2); Electroman (1); G.Swaminathan (1); hastingselectric (1)
