Are there any good tables charts etc. that would describe the weight, thermal conductivity of seawater pipes. What the flow rate in gallons for a given diameter. I would like to set up a system where the seawater pipes would be at a downward angle to prevent the need to use pumps to pump it up. During the day I would like to preheat the seawater pipes to the maxium possible. All this I realize depends on the size of the steam turbines being used. I know there are steam tables are there no halogen gas tables? Also I need to know for a given optical magnification what is the joules per square centimeter delivered by the sun.
