Previous in Forum: thermocouple checking methods   Next in Forum: X Proof GC/TCD for Monitoring NH3 in Methanol, On-Line
dp transmitter
12/29/2007 4:55 PM
Dear sir,
My question is that.
if i am calibrating a Dp transmitter of range 0--100mmH20
1-For zero calibration i will apply pressure(ommH20) to the high side of the transmitter and leave low side open to atomsphere and adjust 4mA
2-For span calibration i will apply pressure(100mmH20)to the high side of the
transmitter and leave the low side to atomsphere and adjust 20mA
If my calibration procedure is correct then please tell me why do we open low side open to atosphere as a refrence and what is the use of isolating and equalizing valves?
Thank you
Technical Fields - Technical Writing - Validation Specialist-Medical Devices United States - Member - From the Big Apple! Hobbies - Model Rocketry - Rockets should go nuclear! Fans of Old Computers - PDP 11 - Studied computers at W.H.Taft H.S., Bronx, NY. Popular Science - Cosmology - Radio Science Observing
Re: dp transmitter
12/29/2007 11:59 PM
From what I gather, you will be using your DPCell for metering flow? In that case the low side is connected to the downstream side of the Orifice plate during actual operation. The low side is only open during calibration. The manifold is used during maintenance in the field for zeroing the XMTR.
WARNING! All suggestions are informative only. It is the prerogative of the user to implement under his sole responsibility. This commentator will not be liable for any damages or injuries incurred.
Re: dp transmitter
12/30/2007 12:01 AM
It would have been better if you said whatever it is that Dp stands for...
Since you talk about high and low side, I assume that Dp stands for Differential Pressure.
For zero pressure difference,you can either leave both sides of the transmitter open to the atmosphere, or connect the two together with a tube. Either way ensures no difference in pressure.
For span, you must ensure that the 100mm H2O pressure applied is measured with respect to the same pressure (atmospheric or other) that the low side 'sees'.
You need to tell us more about your specific application: then we can give you a more specific answer!
Good Answers: 54
Re: dp transmitter
12/30/2007 4:16 AM
1-For zero calibration i will apply pressure(0mmH20) to the high side of the transmitter and leave low side open to atmosphere and adjust 4mA
Not necessarily. You can opt to leave both sides open to atmosphere. That way both sides will have the same pressure (zero difference).
2-For span calibration i will apply pressure(100mmH20)to the high side of the transmitter and leave the low side to atmosphere and adjust 20mA
Usually, yes. Make sure, however, that your reference is reading gauge pressure.
why do we open low side open to atmosphere as a refrence...
If you're measuring level for an open tank, you open the low side. If you're measuring level for a closed tank (under positive or negative pressure), you connect the low side to the top of the tank. The low side compensates for the pressure in the tank so that your level reading is correct.
...and what is the use of isolating and equalizing valves?
You've answered your own question.
Isolation valves isolate or disconnects the transmitter from the process. For what reason? To take it out of service usually.
The equalizing valve serves to equalize the pressures of the low and high sides to check the zero.
Re: dp transmitter
12/31/2007 9:57 AM
I have found connecting the high and low sides of a DP transmitter is essential to a steady, proper zero calibration and is a "best practice" to follow all the time. Applying 100 mmwc to high side is part of a complete calibration, but to know if the transmitter is operating properly, I usually apply (-) 100mmwc to low side, while continuing to apply (+)100mmwc to high side. One can watch the output signal return to a zero signal, and linearity is easily checked also by stopping at 25%, 50% 75% or any other points desired. Low sides of some transmitters can be damaged without effect to high side, once initial zero was corrected to the damaged low side. You never know what the last person who calibrated before you did to complete the calibration! Hope this helps.
...If you can fill the unforgiving minute with 60 seconds worth of distance run...
Good Answers: 54
Re: dp transmitter
12/31/2007 10:33 PM
agree
disagree...if you apply -100mmwc to the low side and +100mmwc to the high side at the same time, you'd get 200mmwc pressure difference (high minus low).
If you had said that you applied +100mmwc to the high side, and then removed it, and then applied -100mmwc to the low side (as a way of checking perhaps), I would have agreed. The pressure difference would still be 100mmwc for both instances.
Re: dp transmitter
01/01/2008 12:02 AM
I agree with you 100%! No need for the extra 100 on the low side. The force balance system of the xmtr along with the pilot (or relay) takes care of the rest. Thats why it's called a "Force Balanced System" at least on pneumatic types.
Re: dp transmitter
01/02/2008 4:08 AM
<....why do we open low side open to atosphere as a refrence....>
Because it is a differential pressure transmitter, and atmospheric pressure changes over time due to local weather characteristics; a differential pressure transmitter is used instead of an absolute pressure transmitter to cater for these changes. The atmospheric changes are only slight, though they are very significant in comparison with a full scale range of 100mmH2O.
<....what is the use of isolating and equalizing valves....>
These enable calibration and testing to be carried out with a goal of obtaining the correct calibration of the instrument in view of the above.
Register to Reply 7 comments
Barncat (1); dkwarner (1); PWSlack (1); ronald (2); Vulcan (2)
