Previous in Forum: question about centrifugal pump   Next in Forum: pressure vessel
pump efficiency
12/30/2007 5:43 AM
I have to check the efficiency of a centrifugal pump, please help me how can do this job?
Good Answers: 19
Re: pump efficiency
12/30/2007 8:21 AM
Fit a flow meter, a pressure gauge, a temperature meter, a electrical meter, a hour meter, a timer. Sit and check out each data every 15 min . restart . stop. restart. After 100 tests you graph the pump flow n efficiency.
Re: pump efficiency
12/30/2007 8:40 AM
Thank you,
I will make graph against discharge pressure Vs Flow rate, Power Vs Flow rate. Now how to calculate head in order to calculaate efficiency?
Re: pump efficiency
12/31/2007 12:32 AM
Efficiency is output power/input power.Calculate the Hydraulic Power of pump using head,flow rate ( refer text books for formula).Delivery Head is the height from center of the pump to the top of the tank where it is pumped.Record Input power using power analyser.Take motor efficeincy also to consideration.
THE ENGINEERS MOVE THE WORLD,IDEAS RULE THE WORLD
Re: pump efficiency
01/02/2008 4:34 AM
Pump efficiency = pressure gain x volumetric flowrate x 100% / electrical power input
all expressed in compatible units.
Register to Reply 4 comments
ducon (1); KOTIAN (1); meshri (1); PWSlack (1)
