Previous in Forum: Fusion of Silicium   Next in Forum: Tetrakaidecahedral @ Kelvin structure
21 comments
Inert Gas That Will Not Impact Metal Alloys in Coins
01/02/2008 2:31 PM
Hi:
I am interested in finding if anyone is aware of chemical gas that could be injected into a PVC free plastic encapsulation container that would ensure that a coins condition would not be subject to any further damage.
obliviously the other are a number of metal and alloyw that would have to be unaffected by this gas? Any leads or thoughts would be greatly appreciated.
Good Answers: 247
Re: Inert Gas That Will Not Impact Metal Alloys in Coins
01/02/2008 6:56 PM
I am not an expert in coin preservation, by any means, but helium is easily obtained and non-reactive. Argon is another possibility, also widely available. For ordinary uses in which you want to avoid oxidation, nitrogen is used, and that may be fine for coins, too. Helium and argon are both used as shielding gases in welding, so are non reactive with metals even at elevated temperatures.
01/02/2008 11:52 PM
Helium is too small a molecule - extremely difficult to seal for any significant time. Argon or Nitrogen would be much better. Another possibility would be CO2. With a molecular weight of 44, it is much easier to seal than the other smaller molecules.
Good Answers: 247
01/03/2008 1:46 AM
Yes, helium is leaky sneaky stuff!
Good Answers: 18
01/04/2008 8:15 PM
I agree. Sealing a plastic container containing Helium would be tricky. Virtually any gas or gas mixture that doesnt react with either the metal or the PVC would be practical. The cheaper the better.
01/02/2008 7:27 PM
Nitrogen gas is readily available and fairly cheap. Since the main thing that would cause tarnishing (oxidation) of the coins is oxygen, most gases with low reactivity would work. Nitrogen is the most common.
The other thing I would make sure of is that you have a good tight seal on the chamber/case and that you make sure that you displace all of the air when filling.
Best Regards,
Mike
01/03/2008 2:29 AM
Argon is used when seals could leak do to its larger physical size. Look for the inert gases on the periodic chart and see what is biggest vs. what is cheap.
depending on the value of your Numismatic collection what is appropriate.
ps. design a low cost system and sell it to your niche market.
or not
good luck on your Numismatic venture
Brad
01/03/2008 4:20 AM
The thing to do is to exclude water vapour and oxygen from the container, so the gas needs to be low in H2O and chemically inert.
Among the possibilities: bottled
  • Nitrogen
  • Neon
  • Argon
  • Xenon
None of these will have any significant chemistry with the materials listed, at ambient temperatures and pressures, and coming from cylinders will be low in water vapour.
Nitrogen is perhaps the easiest to obtain, and probably the least value to purchase.
Special precautions are necessary for handling gases other than air. All of the above have the potential to asphyxiate the handler, and ventilation arrangements in the area need careful and rigorous consideration. It is common for personal gas monitors to be required for those working with these materials in industry, so that an alarm is raised if the local oxygen concentration in the surrounding air becomes lowered to hazardous levels by its displacement with other gases.
DON'T FOOL ABOUT WITH NITROGEN!
Engineering Fields - Automotive Engineering - New Member APIX Pilot Plant Design Project - Member - New Member
01/03/2008 8:32 AM
Excellent answer PW!
i personally would not use CO2 -- if there is any moisture left or diffusing into the bag - the CO2 will form carbonic acid
Duct tape is like 'The Force'. It has a light side and a dark side and holds the world together.
01/03/2008 12:33 PM
I agree that some care should be taken, but I am not as excited as Mr Slack. Having worked in industry for a decade or so I am a bit more - well - just take practical care.
I also am a coin collector. I am curious as to why you want to fill the container. There is no such thing as a leak proof container, so over time (especially a plastic, accessible container) the inert atmosphere will need to be re-established. Since there is no way easy way to monitor the environment within the container you will just have to establish some sort of PM program.
However, the evacuation of the atmosphere by vacuum is more achievable. Also a simple pop-up indicator will assure the negative bar atmosphere exists.
As stated O2 and H2O and to some degree UV are your enemies for an un-handled coin.
There are a number of gas dryers available and five 9 purity inerts too (99.999% pure) but the practicality is questionable from my perspective.
Review the products in magazines such as CoinWorld and CoinAge or Coin Collector or read any of the work of Scott Travers for what is on the market.
Perhaps a better product would include the packaging of five 9 inert gas into a small container such is used for air rifles, a bulb pump and a proprietary container. This gas can be 'pulled through' your container via a proprietary connection fixed to the container by means of a bulb pump vacuum. So that a negative bar atmosphere of dry five 9 inert exists within the container with a pop-up monitor device as a visual indicator of the internal environment.
I will sketch up something in a bit.
Hope this helps,
cr3
Popular Science - Weaponology - Scapolie, new member.
01/03/2008 8:29 AM
Hi gewoodfo.
By far, the best inert gas for protecting nonferrous metals is Argon! It is relatively cheap and easily available.
Spencer.
Good Answers: 58
01/03/2008 8:51 AM
Determining a satisfactory gas environment is the easy part. Maintaining that environment in a plastic container over a long period of time is the challenge. I suggest you look at ASTM E595 (Volatile Condensable Materials) and NASA STD 6001 TEST 6 (Determination of Offgassed Products). Once you find plastic materials that don't outgas very much, you will find they are expensive and exhibit other undesirable properties. Glass and metals are easier to deal with and even they have significant problems. There is a web site that describes recent efforts to conserve the declaration of independence. I believe the work was done by NIST.
01/03/2008 9:09 AM
The idea is to be sure. An Argon filled 9mil mylar bag that will be heat sealed. For final storage put the coin/argon filled bag in a can or other sealed container to protect the bag and its' contents from UV radiation.
Don't worry about which gas is cheaper, you are seeking reliable performance not, "well this should work". Put the bag, coins and, heat sealer device in a homemade plywood box and reach through slits in the plastic sheet lid to seal the bag. The plywood box will be flooded with the argon. I know it seems like a waste but it actually isn't when you comare it to the future value of the coins. This box idea works for critical welding jobs too.
h2om@hotmail.com
United States - Member - Technical Fields - Education - Hobbies - Hunting - Popular Science - Weaponology -
01/03/2008 9:11 AM
Could you pull a vacuum on your encapsulation container? This might be simpler than injecting an inert gas...Just a thought.
David A Goodman
01/03/2008 9:51 AM
I was reading through this thread and thinking to myself "Why use a gas?"
Most coin collections I've seen are sealed in a vacuum bag similar to vacuum packed food...
Just use a standard vacuum packing machine with heat sealing done! no hazardous gases or anything...
John.
01/03/2008 10:00 AM
Hi all: Thanks for the the great info!
A couple of you mentioned ensuring a seal. I am looking to use Sonic welders. That is what the current manufacturers of coin slabs are using.
01/03/2008 11:56 AM
Another issue with gas is when you expand it the new volume has the same relative heat in relationship to absolute zero. People have died from frost bite of the lungs just from trying to correct a leak in a room. If you open the door and there is fog (ice crystals) get out and take appropriate measures. Non recirculating refrigeration.
You wouldn't need much gas so something like a small sandblasting cabinet would work.
Argon is heavy so vent it high and purge the case to open it low, both to outside where it can disperse.
The chances of a problem are very slim but understanding the dynamics of a situation gives you options.
2bits
Brad
Good Answers: 266
01/03/2008 4:18 PM
Argon is a inert gas that can be used. If the container is flooded with Argon. Some type of desiccant is placed inside to remove moisture. Then sealed should protect them for your life time.
01/08/2008 3:56 AM
Nitrogen is silent killer.Better use Hellium for this pupose.
Thanks!
Ramdas
01/08/2008 11:12 AM
What are you referring to? You breathe in more nitrogen with each standard breath than the amount required for several coin cases. Nitrogen is only dangerous if it reaches concentrations to exclude oxygen,
01/08/2008 12:25 PM
Thank you. Having worked with gaseous chemicals of the very worst type, I find it fascinating the fear some seem to have over a little N2.
Again, use practical safety precautions.
I keep waiting for one of these guys to try and sell me an N2 monitor for my basement.
cr3
01/09/2008 9:42 PM
Actually, with a molecular weight of 28, N2 is slightly lighter than air (avg Mol Wt about 29), so with O2 at 32, you may have to 'worry' about excess O2 and diminished N2 in the basement! So you really should watch for excess oxidation down there - maybe they will sell you a strip of iron encased in a fancy box with a photoemitter-detector pair connected to an alarm!
Dick
Register to Reply 21 comments
agua_doc (1); Anonymous Poster (1); Blink (2); cbs (1); DAG (1); dkwarner (3); Electroman (1); gewoodfo (1); Mikerho (1); ozzb (1); PWSlack (1); ramdasyedave (1); Scapolie (1); TexasCharley (2); U V (2); welderman (1)
