Hi all,
The problem I want to discuss concerns
unequal active and particularly reactive load sharing between two generator
sets. Abnormalities are shortly described below:
1). During generators (G1 and G2)
parallel operation load swing can be observed for both units (currents are
terribly swinging both, on analog and digital displays). This is particularly
noticeable when there is significant load increase. It looks like machines are
"competing" with each other to take more load and causing load swings.
2). Active load sharing is not
balanced. There is always difference by 30 – 50 kW of active load between
generators (in most cases G2 takes more load).
3). Reactive load sharing is not
balanced as well. But in this case the difference is dramatic. I have noticed
that, G2 delivers 1.5 – 3.2 times more reactive power than G1.
4). Voltages are slightly more than
normal for both units and slight asymmetry can be observed. Voltages vary from
401 to 405 Volts. These changes are not abrupt and no voltage surge is observed.
The same can be said about frequency – it varies between 49.9 and 50.1 Hz.
Shortly saying - voltages and frequency look much more stable.
In my opinion the reason of
unequal sharing of active load can be load sharing devices improper operation
and they might need readjustment. Similarly, for equal sharing of reactive load
we might need to check automatic voltage regulators and they might need
readjustment as well.
Question: what is the
likelihood that G2 will gradually take all reactive loads and G1 will not be
delivering reactive power and even more, it might start consuming reactive power?
If it is a case, what kind of abnormal mode can develop generation system?
Some technical details
regarding plant equipment:
1). Alternator SGS9C04O,
1430 kVA, cosφ = 0.8, 3Ph 400/230 V, 50 Hz by Hitzinger
2). Load Sharing Module LSM
201 (for active load, there is no reactive load sharing module) by GAC
3). Automatic Voltage
Regulator AVC125-10.
Thanks in advance
