Previous in Forum: would wax improve the flow of low melt index plastics?   Next in Forum: Source of Mysterious Antimatter Found
Engineering Fields - Electrical Engineering - New Member Engineering Fields - Power Engineering - New Member Technical Fields - Technical Writing - New Member Engineering Fields - Construction Engineering - New Member India - Member - New Member Engineering Fields - Nanoengineering - New Member Safety - Hazmat - New Member
Solid waste disposal from Petroleum Refinery
01/12/2008 12:33 PM
Landfill is often recommended as an option for disposal of solid waste, generated in Petroleum Refinery. When land availability is a constraint, please advise what are the other options for Solid waste disposal,to meet environmental standards?
nvmani
Good Answers: 15
Re: Solid waste disposal from Petroleum Refinery
01/12/2008 6:09 PM
Something that has been mentioned in science fiction novels is getting it into the Earth's mantle. Melting everything and having a volcano spit it back up
downhill slide to 112 (damn memor.)
01/12/2008 11:19 PM
Every Refinery should already have been forced to run a Gasifier(Oxygen-not air).
Now they are killing all of India's waters/waterlife by dumping onto rivers what they do not know how to get rid of.
India's Central /State Pollution Control Boards are farce!Their Standards!!!
01/12/2008 11:53 PM
All of what are called solid wastes, from the refining of petroleum, are actually now able to be used, in making industrial building or road building products of enormous value. Therefore,I recommend that you write to dr.manly@international-planners.com and ask him to assist your company in the development of the more than 20 products, which can be made, from the solid and gasious wastes, common to petroleum refining.
01/13/2008 12:07 PM
First you must characterize the waste--what is it, which unit(s) generate it, does it come from tank cleaning, is it always the same composition, or does it vary a lot,etc. The actual composition and variability thereof are key parameters in determining ultimate utilization potential.
Disposal of catalyst fines from the FCCU is much easier than sludge from tank cleaning.
Nothing need go to haz waste landfill.
Keith E Bowers, PMP
Good Answers: 18
01/13/2008 2:51 PM
I agree. Not all wastes are the same, but virtually all can be disposed of cost effectively without going the landfill route. Please be more specific which waste products you are trying to dispose of.
APIX Pilot Plant Design Project - Member - New Member
01/13/2008 2:00 PM
Try high pressure steam reforming, it converts the carbon to carbon dioxide and releases the hydrogen from water. It can also produce methane and with right catalysts make methanol, ethanol, and other useful carbon compounds. There is also a similar method, too, given already, pyrolysis, but producing only CO2.
chtank
01/14/2008 4:30 AM
What is its calorific value: could it be used as fuel?
Register to Reply 7 comments
agua_doc (1); chtank (1); ddk (1); Hugo Manly (1); Keith E Bowers (1); MUKULMAHANT (1); PWSlack (1)
