Previous in Forum: package heat pump head pressure issues   Next in Forum: alignment gap and sag
8 comments
strainer
01/13/2008 1:54 AM
Dear All,
can we install y-type strainer in vertical pipe?if not then what will be affect on fluid filtraton.
regards,
malik
Good Answers: 19
Re: strainer
01/13/2008 2:36 PM
Yes it dose'nt matter vertical or horizontal.
Re: strainer
01/14/2008 4:56 AM
One of the things to consider is what happens when there is no flow. Does the strained debris fall back down the pipe and mangle the components in a pump the next time it is started, for example?
Just because something could be done doesn't mean that it should be done......
Spain - Member - New Member Engineering Fields - Nuclear Engineering - New Member
Good Answers: 25
Re: strainer
01/14/2008 5:04 AM
I agree with Ducon.
Anyway I think our guest has the minimum amount of common sense to install the Y type strainer in the correct position. Even in horizontal piping you can install it with the non-alineated leg in the upper side!!!!
Ancient romans said "numerus stultorum infinitus est" and transfinite numbers theory wasn't developped by Kantor at that time.
Re: strainer
01/15/2008 1:25 AM
"Even in horizontal piping you can install it with the non-alienated leg in the upper side!!!!"
I agree yours that Y-strainer can be installed in a vertical or horizontal position, but at horizontal position the non-alienated leg can not be oriented in the upper side, it must be at lower side.
Good Answers: 25
Re: strainer
01/15/2008 2:03 AM
Because of that I used the word "can" and not "must". Obviously, you "can" but you must not. And for the same reason I give some credit to the intelligence of our guest. I'm tired of seeing how some CR4 people treat guests as if they were stupid.
Re: strainer
01/14/2008 1:47 PM
Sometimes you can use Tee-type strainer in a vertical line.
Tee>>>wn-flange with blindflange. V-shaped strainer.
Regards Freddy
Re: strainer
01/15/2008 1:41 AM
Thank u very much every body for your positive response.
Re: strainer
01/29/2008 4:38 AM
i give a thought about the position, i think the position is depends to the flow, if the flow is going down, it is applicable. but if a vertical pipe line with upward flow, then the y strainer is not suitable there.is it right?
Abdel Halim Galala (1); Anonymous Poster (3); ducon (1); Kwetz (2); PWSlack (1)
