Previous in Forum: co2 removal   Next in Forum: CO2 Laser
Welder Feedback
01/16/2008 2:23 AM
when welding with a MIG welder and the earth lead comes of the welder will sometimes keep welding and the earth wire in the 3 phase power lead will over heat and melt causing a short circuit.Given the welder uses a rectified transformer how is the path for the current to flow being established through the earth lead on the power side of the transformer. their are approximately 60 welders in the factory and this happens about 4 times a year
Pathfinder Tags: Welding
Good Answers: 18
Re: Welder Feedback
01/16/2008 2:56 PM
The transformer's rectified output ground lead is probably connected to the welder chassis, which is also probably connected to the 3-ph neutral/ground.
Good Answers: 15
Re: Welder Feedback
01/17/2008 12:39 AM
Agreed, some welders have the -ve terminal on the chassis of the welder, some don't, those are able to have the polarity of the output swapped.
You'd find that some times, it isn't just the welder that drops the Earth lead, but could also be 1 or more welders that will have the Earth wire heating problem, as they are acting as the earth return point for the one who dropped their Earth.
Check your power outlet too for heating, as you'd find that the weld currents are more than the Current design spec of the power outlet ;o(
Qn, Whats the differance between a Snake and a Onion? Ans, No one cries when you chop up a Snake
Re: Welder Feedback
01/17/2008 4:13 AM
Deleted....by myself, answers were already made!!
Re: Welder Feedback
01/17/2008 10:16 AM
You a silly man Andy.
Eschew obfuscation.
Re: Welder Feedback
01/17/2008 1:30 PM
I know, but I am honest......I read the other posts and mine was not needed....I do not know a way to delete it completely, or I would have done that!!
Re: Welder Feedback
01/17/2008 7:49 AM
The output connections of any welder should not be connected to the chassis this is a total no no.
What usually happens in large factory's there is a bad habit of connecting the work leads to the metalwork of the building, this is to save running work leads to whatever is being welded,they usually tack a piece of steel rod or cable and clamp from the nearest piece of building structure to the welding table, as the mains supply ground is also connected to the building when a work lead connection goes bad [high resistance]and the welder happens to be touching any part of the object to be welded it will try to feed a couple of hundred amps through a 30 amp earth wire and any or all supply wiring which can prove to be an expensive mistake.
Also with MIG welders the wire can sometimes over run and un spool this will short this can short to the chassis and given above scenario will do the same thing.
Register to Reply 6 comments
Andy Germany (2); Bill (1); garth (1); Kyoto (1); Snaketails (1)
