Previous in Forum: Solar and Wind Systems   Next in Forum: Web Page Development for Office Use
12 comments
Void Pointer
02/06/2008 4:06 AM
whats different between void *p and void q;
Re: void pointer
02/06/2008 4:22 AM
In what context?
United Kingdom - Member - Member
Re: void pointer
02/06/2008 4:24 AM
Its been some time since I did any C programming but as I remember void *p declares a void pointer which can be used to point to the address of any other type of variable with appropriate casting. void q would declare a variable of the type void but as void is used to indicate that no variable is to be passed to/from a function then I doubt this would be a legal declaration and I can't think of any purpose for doing it.
I could be wrong on the second point
Al
If you remain calm while all those around you are losing their heads, then you haven't realised the seriousness of the situation
Engineering Fields - Instrumentation Engineering - New Member Hobbies - Fishing - New Member
Re: void pointer
02/06/2008 6:44 AM
It seems it's homework.
Incorrectly formulated question in any case.
(1) You have forgotten a brackets ( ).
(2) you should use either p, *p or q, *q. Otherwise every one can say you that p looks different of q.
Owing to (1) what's a point to find difference when both notations are wrong initially?
Study a textbook.
Re: void pointer
02/06/2008 6:57 AM
Brackets are not required when declaring a variable or a pointer. You seem to be suggesting that p or q is a function name
Re: void pointer
02/06/2008 7:15 AM
Hello Botton Alan!
VOID can declare only function with nothing to return. So brackets are needed there in any case for getting meaningful C statement and therefore question.
Other way it's nonsense at all. Are we discuss about C?
Try to declare variable this way void q; and look at compiler response.
Seems ours guest had got all tips for his/her question .
Re: void pointer
02/06/2008 8:06 AM
Caramba,
I no longer program in C or C++ but I distinctly remember declaring a pointer as type void
i.e. void *p
in order to pointer and access varying data types in a recordset returned by a sql database. Now that particular project was in C++ so maybe it was just a C++ thing
Al
Re: void pointer
02/06/2008 8:10 AM
Al,
You're right void *p will be passed by compiler I didn't write that it can't. Yes it may be cast any kind of integer or char variable at its address, though I use never this trick.
But I emphasize that we have here incorrect question.
All my kind regards and respect to you.
Re: void pointer
02/06/2008 8:42 AM
You stated:
This is not true, as void can also be used to declare a void pointer. The fact that your compilere allows you to do that but not declare a variable of type void confirms both parts of my first post (feel free to rate it as a good answer).
Thanks for the feed back about your compiler
regards
Al
Re: void pointer
02/06/2008 8:49 AM
Ok, ok you won
Reply Off Topic (Score 3)
Re: void pointer
02/06/2008 9:46 AM
WTF is a void pointer????
This discussion all seems a bit empty to me
Re: void pointer
02/06/2008 9:51 AM
Electro,
A void pointer is a pointer capable of pointing to any area of memory occupied by a variable of any type as long as it is cast to that type when assigning it an address
Clear as mud?
Al
Re: void pointer
02/06/2008 9:58 AM
Hi,Electroman,
Very good said!
Bolton_Alan (5); caramba (5); Electroman (1); PWSlack (1)
You might be interested in: Protective Packaging, Pressure Gauges, Control Knobs
