Previous in Forum: about electrical basic   Next in Forum: Variable Frequency Control of Induction Motors
8 comments
Scanner Tube?
02/07/2008 9:31 PM
Hi Everyone,
I just took a scanner apart - irresistable curiosity I guess. Among the many parts I could identify, I found this (that I could not identify):
It is ~10" long x 0.1" Dia. with a wire from each end as you can see. I'd bet my bottom dollar that someone at CR4 knows what this is.
I appreciate any info.
Mike
Australia - Member - New Member Hobbies - Target Shooting - New Member Popular Science - Weaponology - New Member
Re: Scanner Tube?
02/07/2008 9:44 PM
It is a Very bright light.
To allow for High resolution colour images.
Sapper
It's all about the Boom! - MythBusters
Re: Scanner Tube?
02/07/2008 9:49 PM
Thanks Sapper for replying so quickly. Do you have any idea of the voltage and maybe frequency this operates at? Does it need a "starter" like fluorescent tubes?
Mike
Re: Scanner Tube?
02/07/2008 11:25 PM
Not sure about power or type of light, might be worth putting meter on the supply...If it's still in one piece ???
My Avatar is a Massey Self Contained Power Hammer (150wt).
It lives at Ultimo Tafe N.S.W Australia.
Regards,
Sapper.
Re: Scanner Tube?
02/07/2008 9:55 PM
What is your avatar a picture of? Can't really make it out other than it's equipment of some sort - which gets me to thinking that CR4 ought to have an enlarge picture function. Hmmm....
Mike
Re: Scanner Tube?
02/08/2008 10:52 AM
Mike, its the CCFL (Cold Cathode Flourescent Light) that is used to illuminate the object being scanned.
Its very fragile and operates with out heaters just a high starting voltage to kick it into life around 600 volts I think.
I'm looking at several at the moment through my LCD monitor.
John.
Re: Scanner Tube?
02/09/2008 2:58 PM
I agree.
I haven't checked the ones in scanners. The ones I have checked (laptop screen backlights) ran on around 300V from an inverter. I've never paid attention to whether they have a diode or bridge on the output, so it may be AC or DC... If it is AC its high frequency.
The one shown is pretty long, so you may well be right on the higher voltage.
Re: Scanner Tube?
02/09/2008 12:04 AM
Seems to me, it is the light source for the scanner
Re: Scanner Tube?
02/09/2008 10:42 PM
I'm not trying to take apart a scanner ,but for 2 days trying to reinstall a scanmaker x6EL. It stopped working when I changed from Microsoft home to Microsoft xp. Fallowed every page of instruction I found on the computer and the original and CD that came with it. I bought it with the computer , had to copy long paper old European documents, now I need it again .
Any help out there , if not I will take a screwdriver to it too.
Register to Reply 8 comments
dkwarner (1); Electroman (1); jitasan (1); Johann Vondrus (1); Mikerho (2); Sapper (2)
