Previous in Forum: lux calculation   Next in Forum: How to reduce electric consumption
converting current signal to voltage
02/10/2008 6:11 AM
Hi, i need to convert a current signal that ranges from 200mA to 700mA into a voltage signal, Running it through a 3.3 Ohm resistor will do the job giving me a voltage range of 0.66V to 2.31V. Now the problem im facing is the current signal is intended to run a VFS solenoid with a resistance of approx 24 Ohms and i've found using the 3.3 ohm resistor brings up an error on the controller thinking the solenoid is damaged, so i then have put a 3.3 Ohm/10 watt, 6.8 Ohm/10 watt and 18 Ohm/10 watt ceramic resistors (mainly because they were at hand) in series and taken my voltage signal from across the 3.3 ohm and this works fine for a few minutes until the resistors heat up more than i would like for where they are going to be mounted (on plastic). so my question - is there a better way that i am overlooking? or is the answer simply look at resistors with heatsink though i would like something that takes up minimal room preferably to be mounted on the PCB with the IC's using the signal thanks - scott
P.S. I've quit my full-time job to pursue University studying Electrical Engineering, These little side projects have got me interested enough to pursue a career.
Re: converting current signal to voltage
02/10/2008 7:51 AM
As you have a current source and you wish to drive a solenoid, which is basically a current operated device, working on the number of ampere turns etc...
Why bother with resistors? Just rewind the solenoid coil to run at the current available 200 mA to 700 mA
John.
02/10/2008 2:25 PM
i dont want to drive a solenoid, im using an output meant to drive one but i want to use it to drive an IC, hence why i need to change it to a voltage signal thanks - scott
02/13/2008 8:13 AM
Vague questions are hard to answer because we have no idea what your end goal is but...
The sense resistor is the easiest way to convert current to voltage, as said before the current will be coming from some power source and that voltage times the current is the power that will be dissipated somewhere. If you use a smaller resistor then you will dissipate more power in the current source but less in the resistor. If that is acceptable you can use a very small sense resistor and gain the current signal back up with a simple op-amp circuit. If you use the larger sense resistor then you will dissipate less power in the current source but more in the resistor and you are back to square one; a hot resistor that needs heat sinking may end up your best choice. Other options are Hall device for DC current, We have assumed DC current based on the initial question but if that is wrong and you are switching the current rapidly or it is AC then current transformer may do the trick.
02/10/2008 6:09 PM
Basically if the controller insists on driving that current (because it reports an error otherwise) then you must run that current and it will generate that much heat...so you'll have to get rid of it.
I'd suggest seeing how high a resistance you can get away with while still fooling the controller. It doesn't matter what you use, solenoid, resistor, transistor as a load it will still have to dissipate the heat.
So in sumary... use the highest total value of resistors which will still work reliably (one of which will be your 3.3ohm sensing resistor) and mount 'em on long legs or a heat sink..
It's simple and effective... go with it.
(Check the controller manual too, the output may be adjustable... if all else fails, read the instructions)
Have fun
02/10/2008 6:30 PM
You might want to go talk to some of the Electrical Terninal distributors, like Phoenix Contact, Weidmeuller, Carlo Gavattzi. These guys make and sell devices to do elactly what you are looking for. They are not that cheap, but if you want it to work reliably in an industrial environment they might be worth the cost.
02/10/2008 10:59 PM
Change over to a VLSI Chip:
Part number: LM2904W
Category:
Analog & Mixed-Signal Processing
-> Amplifiers
-> Operational Amplifiers
Description:
Low power dual operational amplifier
Packaging information:
Part numberPackage
LM2904W
Datasheet: Download
Company: ST Microelectronics, Inc.
02/11/2008 11:25 AM
I guess you are working in dc, have you looked at a hall effect pick up?
We use one on an output sensor unit in a portable generator (which has dc & ac outputs) We have a 0-5V output and sum this with a circuit for the ac output [ct based to give 0-5V] to show the total load on the gen.set
Register to Reply 7 comments
Anonymous Poster (1); Electroman (1); JohnBob (1); MUKULMAHANT (1); OleTechGuy (1); sco77ie (1); user-deleted-1105 (1)
