Previous in Forum: Project List?!   Next in Forum: Developmet of Keyless entry project.
project
02/17/2008 11:29 AM
can anyone suggest me design of wheelchair??? or any other mechanical projects??
Good Answers: 97
Re: project
02/17/2008 11:37 AM
Sport or normal use?
Re: project
02/17/2008 11:40 AM
its for normal use...but if u hav design of both give me
Good Answers: 97
Re: project
02/17/2008 12:00 PM
No I haven't got a design for you.
When I eventually have to use a wheelchair I would want to be independent. For example I want to be able to change the light bulb in the roof light.
Go and rent yourselves a chair and use it. Have a look at anything you can improve.
Good Answers: 183
Re: project
02/17/2008 1:14 PM
You ask for a suggestion related to the design of a wheel chair.
Here it is:
First you look at a chair and take all dimensions of it
second you compute the profiles you need considering a dynamic factor of 2..3 and a person weight of up to 1500 N.
third you choose the wheels For it you look in a book about ergonomics where you will find the dimensions of the human body. Do not forget to consider for which part of the world the chair is thought since dimensions are not the same all over the world.
forth you decide if you want the chair motorized or not if yes you make the choice for the batteries and the controls (joy stick aso)
fifth you look at your design and decide if it is good or bad and why and if required you correct it.
sixth you present your project
Those are my suggestions for such a project.
Good Answers: 143
Re: project
02/17/2008 1:19 PM
If you're going to design a wheelchair, don't ask here. Ask people who use wheelchairs. Then rent a wheelchair and use it for a week - really use it. Then go back and ask the other users a second time.
Re: project
02/18/2008 10:50 PM
My WONDERCHAIR - first near- perfect cushionless seat for all humanity=3Kg max.
Adapt that with wheel/brake/controls.
Ask for picture . Can't send here..Shall E-mail attachment.
Register to Reply 6 comments
Hendrik (2); MUKULMAHANT (1); nick name (1); swaroop (1); TVP45 (1)
