Hey Guys and Gals,
I am working on a project here at work and am having a difficult time with it.
I have a small printer with a rewind motor on it and I am having a difficult time trying to figure out if I can make the motor variable speed. Now normally this would not be a problem...but...
I cant tell if the motor is a cap start or PSC type motor.
Is there a simple way to tell the difference? I have an AC drive and it is an AC motor however it does have to small capacitors set off to the side that feed it. Of course the other thing that I am curious about is whether or not you hook up before or after the capacitors.
The drive is rated for a PSC motor but is not usable on a Cap start motor.
I can get you any spec you need but have found the motor data plate is of no help thus far when I look it up on the web and I even look at the manufacturers website and they didn't say what type of motor it was.
I have worked with a lot of motors but this is a first for me.
Ha 25 years at it and still find something new!!
Any help would be appreciated
