Previous in Forum: The Scientific Consensus on Climate Change   Next in Forum: Accountants
11 comments
The Engineer
Good Answers: 129
2007-One of the Warmest Years on Record - NASA
03/30/2008 3:43 PM
NASA indicates that 2007 was one of the warmest years on record.
Here is the link and the story is below:
http://data.giss.nasa.gov/gistemp/2007/
GISS Surface Temperature Analysis Global Temperature Trends: 2007 Summation
The year 2007 tied for second warmest in the period of instrumental data, behind the record warmth of 2005, in the Goddard Institute for Space Studies (GISS) analysis. 2007 tied 1998, which had leapt a remarkable 0.2°C above the prior record with the help of the "El Niño of the century". The unusual warmth in 2007 is noteworthy because it occurs at a time when solar irradiance is at a minimum and the equatorial Pacific Ocean is in the cool phase of its natural El Niño-La Niña cycle.
Figure 1 shows 2007 temperature anomalies relative to the 1951-1980 base period mean. The global mean temperature anomaly, 0.57°C (about 1°F) warmer than the 1951-1980 mean, continues the strong warming trend of the past thirty years that has been confidently attributed to the effect of increasing human-made greenhouse gases (GHGs) (Hansen et al. 2007). The eight warmest years in the GISS record have all occurred since 1998, and the 14 warmest years in the record have all occurred since 1990.
Figure 1, above. (a) Annual surface temperature anomaly relative to 1951-1980 mean, based on surface air measurements at meteorological stations and ship and satellite measurements of sea surface temperature. (b) Global map of surface temperature anomalies for 2007. (Figure also available as large GIF or PDF.)
Arctic Warmth
The map reveals that the greatest warming has been in the Arctic and neighboring high latitude regions. Polar amplification is an expected characteristic of global warming, as the loss of ice and snow engenders a positive feedback via increased absorption of sunlight. The large Arctic warm anomaly of 2007 is consistent with observed record low Arctic sea ice cover in September 2007.
El Niño-La Niña Cycle
Figure 2, at right. Surface temperature anomalies for July-December 2007. (Figure also available as large GIF or PDF.)
The cooler than normal equatorial region just to the west of South America is a reflection of the ongoing La Niña phase of a phenomenon dubbed the Southern Oscillation. In the La Niña phase of the El Niño-La Niña cycle the equatorial winds in the Pacific Ocean blow with stronger than average force from the east, driving warm surface waters toward the Western Pacific. This induces upwelling of cold deep water near Peru, which then spreads westward along the equator.
Figure 2, the surface temperature anomaly for July-December, shows that the La Niña equatorial cooling is strong in the second half of the year. The La Niña should thus continue to affect global temperatures into 2008.
Solar Variability
The sun is another source of natural global temperature variability. Figure 3, based on an analysis of satellite measurements by Richard Willson, shows that 2007 is at the minimum of the current 10-11 year solar cycle. Another analysis of the satellite data (not illustrated here) by Judith Lean has the 2007 solar irradiance minimum slightly lower than the two prior minima in the satellite era. The differences between the two analyses are a result primarily of the lack of accurate absolute calibrations and inadequate overlap of measurements by successive satellites.
This cyclic solar variability yields a climate forcing change of about 0.3 W/m2 between solar maxima and solar minima. (Although solar irradiance of an area perpendicular to the solar beam is about 1366 W/m2, the absorption of solar energy averaged over day and night and the Earth's surface is about 240 W/m2.) Several analyses have extracted empirical global temperature variations of amplitude about 0.1°C associated with the 10-11 year solar cycle, a magnitude consistent with climate model simulations, but this signal is difficult to disentangle from other causes of global temperature change, including unforced chaotic fluctuations.
Figure 3, at right. Solar irradiance from analysis of satellite measurements by Willson and Mordvinov 2003 and subsequent ACRIM updates. (Figure also available as large GIF or PDF.)
The solar minimum forcing is thus about 0.15 W/m2 relative to the mean solar forcing. For comparison, the human-made GHG climate forcing is now increasing at a rate of about 0.3 W/m2 per decade (Hansen & Sato 2004). If the sun were to remain "stuck" in its present minimum for several decades, as has been suggested (e.g., Independent story) in analogy to the solar Maunder Minimum of the seventeenth century, that negative forcing would be balanced by a 5-year increase of GHGs. Thus, in the current era of rapidly increasing GHGs, such solar variations cannot have a substantial impact on long-term global warming trends. Furthermore, recent sighting of the first sunspot of reversed polarity (reported Jan. 4 by, e.g., SpaceWeather.com and NOAA) signifies that the ~ 4-year period of increasing solar irradiance is about to get underway.
Summary
The Southern Oscillation and the solar cycle have significant effects on year-to-year global temperature change. Because both of these natural effects were in their cool phases in 2007, the unusual warmth of 2007 is all the more notable. It is apparent that there is no letup in the steep global warming trend of the past 30 years (see 5-year mean curve in Figure 1a).
"Global warming stopped in 1998," has become a recent mantra of those who wish to deny the reality of human-caused global warming. The continued rapid increase of the five-year running mean temperature exposes this assertion as nonsense. In reality, global temperature jumped two standard deviations above the trend line in 1998 because the "El Niño of the century" coincided with the calendar year, but there has been no lessening of the underlying warming trend.
Global Predictions
The quasi-regularity of some natural climate forcing mechanisms, combined with knowledge of human-made forcings, allows projection of near-term global temperature trends with reasonably high confidence. Prediction for a specific year is a bit hazardous, as evidenced by an incorrect prediction of record global warmth made by the British climate analysis group for 2007. Such speculations are useful, as they draw attention to the mechanisms, and allow testing of understanding. Presumably part of the basis for their prediction was an assumption of a continued warming contribution from the 2006 El Niño. However, evidence of El Niño warmth disappeared very early in 2007.
Solar irradiance will still be on or near its flat-bottomed minimum in 2008. Temperature tendency associated with the solar cycle, because of the Earth's thermal inertia, has its minimum delayed by almost a quarter cycle, i.e., about two years. Thus solar change should not contribute significantly to temperature change in 2008.
La Niña cooling in the second half of 2007 (Figure 2) is about as intense as the regional cooling associated with any La Niña of the past half century, as shown by comparison to Plate 9 in Hansen et al. (Hansen et al. 1999) and updates to Plate 9 on the GISS web site. Effect of the current La Niña on global surface temperature is likely to continue for at least the first several months of 2008. Based on sequences of Pacific Ocean surface temperature patterns in Plate 9, a next El Niño in 2009 or 2010 is perhaps the most likely timing. But whatever year it occurs, it is a pretty safe bet that the next El Niño will help carry global temperature to a significantly higher level.
Competing with the short-term solar and La Niña cooling effects is the long-term global warming effect of human-made GHGs. The latter includes the trend toward less Arctic sea ice that markedly increases high latitude Northern Hemisphere temperatures. Although sea ice cover fluctuates from year to year, the large recent loss of thick multi-year ice implies that this warming effect at high latitudes should persist.
Based on these considerations, it is unlikely that 2008 will be a year with truly exceptional global mean temperature. These considerations also suggest that, barring the unlikely event of a large volcanic eruption, a record global temperature clearly exceeding that of 2005 can be expected within the next 2-3 years.
Data Flaw
Finally, we note that a minor data processing error found in the GISS temperature analysis in early 2007 does not affect the present analysis. The data processing flaw was failure to apply NOAA adjustments to United States Historical Climatology Network stations in 2000-2006, as the records for those years were taken from a different data base (Global Historical Climatology Network). This flaw affected only 1.6% of the Earth's surface (contiguous 48 states) and only the several years in the 21st century. As shown in Figure 4 and discussed elsewhere, the effect of this flaw was immeasurable globally (~0.003°C) and small even in its limited area. Contrary to reports in certain portions of the media, the data processing flaw did not alter the ordering of the warmest years on record. Obviously the global ranks were unaffected. In the contiguous 48 states the statistical tie among 1934, 1998 and 2005 as the warmest year(s) was unchanged. In the current analysis, in the flawed analysis, and in the published GISS analysis (Hansen et al. 2001), 1934 is the warmest year in the contiguous states (not globally) but by an amount (magnitude of the order of 0.01°C) that is an order of magnitude smaller than the uncertainty.
Figure 4, above. Global and U.S. temperature anomalies with and without the data processing flaw. (Figure also available as large GIF or PDF)
Further Information
GISS Surface Temperature Analysis (GISTEMP)
Related NASA news releases: 2007 2006, 2005, 2004.
Past global temperature annual summations: 2005, 2004, 2003, 2002, 2001.
United States - Member - Charter Member Engineering Fields - Instrumentation Engineering - Charter Member
Good Answers: 73
Re: 2007-One of the Warmest Years on Record - NASA
03/30/2008 3:53 PM
http://www.climate-skeptic.com/
That map is crap, and so are the charts. Read all about it here.
I go into every human encounter expecting to be framed for a crime I didn't commit. Dilbert, 2013
The Engineer
Good Answers: 129
03/30/2008 4:00 PM
So you're saying NASA is incorrect?
Good Answers: 73
03/30/2008 4:17 PM
a recent post of mine on this forum:
I'm sick of the hypocrisy of guys like Al Gore, with his 60 room estate, (one of), and private jet. He uses more energy in one hour than I use in a whole year. It's a lefty thing, do as I say, not as I do.
Look, don't get me wrong, I'm all for new technology, we really should be looking for ways to replace our dependence on fossil fuels, from other sometimes unstable countries.
And I'm not saying that we haven't effected the world in some way, but it's not all our fault, this is just what the world does from time to time. I don't think, no matter how many trillions of dollars, of my money, they want to throw at this, is going to make any difference at all.
NASA has an agenda too. I have an open mind, and can weigh the rhetoric from both sides. Data can be interpreted any way you want. Just call me the perennial skeptic. The truth probably lies somewhere in the middle.
03/30/2008 5:41 PM
All I know is it has not frozen here in years. I have hybiscus 20 feet tall. Fifteen years ago I replanted every year. Forty years ago it snowed every few years, not lately. I am going to plant some alvacados. Texas Gulf Coast, I'm on a 20 foot bluff so the rising seas maybe won't get them.
Support your local Shriners, they have provided FREE medical assistance for over 800,000 kids so far.
Good Answers: 918
03/30/2008 7:52 PM
Somebody is not telling the truth. GISS said the opposite along with three other sources.
LINK
They state 2007 saw a very sudden drop in temperatures.
The Engineer
Good Answers: 129
03/30/2008 10:58 PM
AH,
Hows it going. I looked up the sources you listed. I found three of the four sources listed. Here's the facts from the sources themselves.
GISS- Goddard Institute for Space Studies
2007 Was Tied as Earth's Second-Warmest Year (From their own page)
UAH- University of Alabama Huntsville
http://www.uah.edu/news/newsread.php?newsID=999 (The article is about climate modeling of the atmosphere, specifically the troposphere, give it a read and decide for yourself if it is saying what "Watts up with that" is saying its saying)
RSS-Remote Sensing System
http://www.remss.com/support/publications.html (Can't find anything published about January on their site, I'm sure the data exists, I just can't find it (the link is to their publications). The do have some papers regarding global warming though.
HadCRUT-Hadley Climate Research Unit Temperature
http://www.metoffice.gov.uk/research/hadleycentre/news/cc_global_variability.html (the hadley press release regarding the January 2008 drop)
http://www.metoffice.gov.uk/corporate/pressoffice/myths/ (Hadley home page "common climate myths")
See you around on easier posts where we can joke around. I've got to go back and read all the comments calling me a "true believer" (thanks for not calling me a "true believer").
Good Answers: 918
03/31/2008 12:29 AM
Roger,
Thanks for the links. I have a hard time getting my arms around this because there is so much conflicting data and a strong dose of politics woven in for good or bad measure.
I still think that we really don't have a strong enough understanding of all the important variables and the interactions between them to make a definitive statement. So, I sort of stand back on the sidelines and wait.
That doesn't mean we need not be thinking of being better stewards on this mote of dust. However, we also need to be prudent in our application of our medicine so that we do not cause other undesired social effects.
The other thing to consider is the money trail. It is wise to look and se where the money comes from and where it goes for the various institutions involved in this. I have found that the money trail can quite revealing.
The Engineer
Good Answers: 129
03/31/2008 12:56 AM
No doubt about it, the money trail says a lot. Actually, you've hit on the root of the problem. Just too much damn money related on both sides that you can't see for all the dust kicked up. That's just how it is. See ya around CR4.
Good Answers: 97
03/31/2008 7:02 AM
Hi Roger - I think it is about time that a CR4 stamp of approval must be obtained before the release and publication of any GW or related information.
The "incorrect" information found its way into an official publication by government. I think it was also introduced in parliament.
How are we poor souls without access to the truth or time to search for it to know what truth is better than the other?
Knowing that a lot of our measuring and gauging stations are out of order I am now doubtful of the other data as well. (Did some or other civil servant not enter random data just to get his work done).
Poor poor us
Hobbies - Car Customizing - Dances with Trees Canada - Member - because I can Hobbies - CNC - too much fun Hobbies - Target Shooting - paper shreader
03/31/2008 5:55 PM
Call me jaded, but I for one am very skeptical of ANYTHING the government says, with so many 'special' interest groups about it's hard to tell what is real and what isn't.
The green thing is only working because there is a political up side to appearing green.
If it is indeed warming, maybe next year we will not have 11 foot snowbanks, personally I think I am going to burn a tire and do my part
Kevin "Dances with Trees" Willey
04/09/2008 8:10 AM
What can I say - I know that most of the places I have direct experience with have earlier spring, warmer summer, later autumn, and easier winter than was the case 20 to 30 years ago. Not by a day or two or a snowflake or so, I'm talking about spring arriving as much as two weeks earlier. Summer being 10+degF hotter, leaf-fall ocurring two weeks later, and snow accumulation or frequency lessened by feet deep or half the snowfalls.
I also am well aware of historic climate change - ice ages, sunspot minima/maxima, cyclic weather like el Niño/la Niña, etc. Sure, there are times when the world grows colder or goes hotter, and all without anthropogenic influence. But we have demonstrably affected the atmospheric composition, and some of our work has affected the planetary albedo. Did we do it all? Probably not. Is some of it to be laid at our doorstep? Almost certainly. You don't need a weatherman to know which way the wind blows...
Register to Reply 11 comments
Anonymous Hero (2); Bayes (3); Bricktop (2); Dances with Trees (1); EnviroMan (1); Hendrik (1); JasBond (1)
