Previous in Forum: TIG welding puicture   Next in Forum: NPSH on Vertical Multistage Type Pump
15 comments
Pantographing Hinge
04/03/2008 7:13 AM
Hi, does anyone have any useful hints or resources to help with the design of a pantographing hinge?
Thanks
Pathfinder Tags: hinge pantograph
Good Answers: 15
Re: pantographing hinge
04/03/2008 7:33 AM
Did you try a google search for pantograph hinge?
downhill slide to 112 (damn memor.)
04/03/2008 7:39 AM
yup. I am actually in the final stages of the design and prototyping of a 'one-off' hinge for a specific application. I am curious about how other people have solved some of the issues.
Re: Pantographing Hinge
04/03/2008 9:09 AM
I'd go for a CAD solution... that's Cardboard Aided Design .
The lever mechanism on this device was done that way...
04/03/2008 9:26 AM
Yeah, mock up is your friend! I attached a few screenshots of what I have. This part has been run through collision detection and motion prediction programs. Just curious if anyone has come up with more elegant solutions, interesting solutions, etc.
04/03/2008 9:28 AM
Hey That looks fun...
Cargo door for a space ship?
Time diplacement absorber for time machine?
04/03/2008 9:36 AM
Hahah, I could use some time displacement or absorption at the moment. Maybe that should be the next project.
This is part of a system for making a small yachts bow open up, fold out, and extend a ramp so that the owner doesn't have to get wet while exiting onto a beach. . Need I say more...
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
04/06/2008 2:30 AM
Hi, Del the cat!
One of the bowmen in the nearby SCA groups uses a repeating crossbow patterned on the Chinese one.
Mark
04/06/2008 3:18 AM
Hey cool.
I'd love to see a pic of that.
Hobbies - Car Customizing - Dances with Trees Canada - Member - because I can Hobbies - CNC - too much fun Hobbies - Target Shooting - paper shreader
04/03/2008 10:29 AM
Globalspec and search on; hinge ?
Kevin "Dances with Trees" Willey
Good Answers: 128
04/04/2008 12:17 AM
Try Soss. They make concealed hinges which are invisible from either side of a door when it is closed, yet pantograph to give the effect of an exposed hinge barrel. They may have what you want (even have spring closers for them).
--JMM
04/04/2008 1:24 AM
Please refer to the following sites (there are a lot of sites from Google, just write Pantograph):
- Pantographs
- Pantographs
- Pantograph - Wikipedia, the free encyclopedia
- Pantograph (rail) - Wikipedia, the free encyclopedia
04/04/2008 7:17 AM
Good Morning,
(well, it is here), and thank you to all of you who have taken the time to respond and share these resources. As you have probably noticed, most of the pantographs shown, are just that pantographs. They maintain the geometric relationship between the two ends. A pantographing hinge in the sense that I am building, maintains that relationship, while also rotating one end around the fixed pivot point. That way a door, for example, can open and move to the side without swinging out into a passage, or if the space is lacking. I have a short animation of this hinge, but I am not sure if I can post it here. Here is a link to a hinge which would have met our needs except for the 5 figure price tag http://www.freemanmarine.com/Doors1400 PHinge.htm.
Good Answers: 183
04/04/2008 2:54 PM
I do not know if I understood all your problem but if you are concerned with an only translation you can use 2 equal arms placed at equal distances as the left sketch shows it and if you want to combine with an angular movement you can use the approach in the right sketch. Your problem is the deformation of a quadrilater which either a parallelogram (ie the sides are parallel by pairs) or a general quadrilater. Playing with the values of Y, L and the ration of the 2 radiuses you can get the movement you want. It is easy to make an XLS programme to compute the positions considering that L is constant and its ends move on 2 circles.
I hope it will help. Sorry for the response delay but I hope it is not too late.
04/04/2008 3:01 PM
Hi Nick,
Thanks for putting a mathematical spin on this. The hinge pictured is what I came up with. It works quite well. The hinge unit weighs 32#. The bearings are 316ss shoulder bolts, the shoulder bushings are oil impregnated UHMW. The whole system is working quite well.
Its always fun to see how other people's minds approach the same problem.
04/04/2008 3:43 PM
It's getting that quite to a very that is the darndest trouble...
Register to Reply 15 comments
Abdel Halim Galala (1); Dances with Trees (1); ddk (1); jmueller (1); MarkTheHandyman (1); nick name (1); pashbe1 (5); user-deleted-1105 (4)
