I want to measure push & pull forces using Strain Gauge. I am assuming there will be slight misalignment between the two plates between which the forces are to be measured. So, I was thinking of using Rod End bearing between the plates & strain gauge so as to remove any angular & lateral misalignment.
But, now there is a doubt in my mind. If there is a misalignment & rod end bearing is taking care of it, then the forces actually acting on the strain gauge will be components of forces rather than the vetical forces itself, this might give wrong readings.
Pls correct me if I am wrong.
Otherwise I'll have to go for accurate machining to prevent use of Rod end bearing.
