Previous in Forum: First Gear All the Way   Next in Forum: Standard for Sizing Rivets to Hole Diameters
74 comments
Quieting Small Cars with Loud Exhausts
05/06/2008 1:57 AM
Out here, we have a problem with people who install loud exhausts on their cars. These are usually small cars like Hondas, Toyotas, Subaru's, etc. and are typically driven by young, male, runts. Typically the car exhausts have a very large diameter exhaust pipe. They are loud and when they put the petal to the metal you can hear them 1/2 mile away while you are inside your home with the windows closed. They are very irritating.
I'm looking for suggestions for something I can put inside the exhaust pipe that will shut 'em down. I'm thinking something like a liquid that will expand inside the exhaust system and harden. Maybe like spray foam insulation.
Obviously it would need to be applied while they were not in the car and while it was parked.
What would you suggest? Any ideas would be appreciated. I would rely on the local police to give them tickets but they do not seem to be interested. I think there are state laws against such noises but obviously they are not enforced since there are thousands of them on the roads locally.
Good Answers: 230
Re: How to quieten those small cars with loud exhausts
05/06/2008 3:57 AM
Hello Guest,
Use a common tuberiferous vegetable.
The one I have discovered is most suitable, which arrives in various sizes, to suit most exhaust pipes, is the:
Scientific classification
Kingdom:
Plantae
Division:
Magnoliophyta
Class:
Magnoliopsida
Subclass:
Asteridae
Order:
Solanales
Family:
Solanaceae
Genus:
Solanum
Species:
S. tuberosum
Binomial name
Solanum tuberosum
Obtain a supply of Solanum tuberosum of the Solanaceae family, and a suitably sized one works very well up the offending
Lay in a good supply of the tasty tubers.
You can always eat the surplus, once the offending car exhausts have been dealt with.
WARNING:
Because such an action would be classified as "Unlawful interference with a Motor Vehicle", and if the owner/s or their friends ever discovered who had fed their car/s with the vegetables, they will be very unhappy, so it's important to take great care and thought, before performing such action.
Advise further, with
Kind Regards....
Good Answers: 61
05/06/2008 11:13 AM
Great answer, Sparks!
Having applied S. Tuberosum several times in my misbegotten youth, I can personally attest to the efficacy of its sound dampening characteristics.
NOTE: If properly applied with a wooden or rubber mallet to an overpowered vehicle, there will be a loud noise (once), resulting from either a ruptured exhaust tube (for the rolled steel seam-welded type) or a blown head gasket.
Good Answers: 94
05/07/2008 4:41 AM
Just remember to buy a large sack!
Good Answers: 12
05/09/2008 2:46 AM
Thought I had was "Large Exhausts?? Use Baker potatoes!!"
Bill
Good Answers: 266
Re: Quieting Small Cars with Loud Exhausts
05/06/2008 12:51 PM
Instead of a complaint about the noise call and complain about the pollution they are causing. Modification of the exhausts system will defeat some of the pollution device installed by the OEM. Where I live it's against the law to modify pollution devices. Noise is a type of pollution. Just changing the words may get some one attention in todays world of going green.
05/06/2008 5:48 PM
I suggest you go up to them at the traffic lights and explain that if you had a small penis you too would find it necessary to own a noisy car. (And then make a smart withdrawl).
Urinating on their wheels may help get the message across too.
Good Answers: 18
05/07/2008 9:48 AM
I like the way you think, Del!
I bought a boat horn (the kind with the self-contained air cylinder) that I use for loud radios as well as loud mufflers.
And now, I'll have to pee on someone's tires before I die . . . Thanks for putting that plan in my head!
Good Answers: 12
05/09/2008 2:50 AM
Kitty's might get away with that Del... but how do you bury it afterwards?
Good Answers: 50
05/09/2008 2:58 AM
Christ! Just dump sugar in their gas tank no more sound ever!
Good Answers: 230
05/09/2008 4:17 AM
Hello vermin
I'm keeping well away from the likes of ye.
Kind Regards....
Good Answers: 123
05/06/2008 11:15 PM
Well, if a little is good more must be better,right. That can of spray foam insulation would probably stick reasonably well to the inside of that oversized tail pipe. Once the foam hardens there should be no escape for the exhaust when that wonderful person starts that annoying rice burner. The backup of exhaust gases will eventually dilute the intake manifold with exhaust gas causing the engine to have insufficient oxygen to run. Thus stalling the engine.....Unless the exhaust pipe has leaks. In that case the engine will idle fine, but have no power as the limits of the exhaust leak are reached.
BUT. as long as you are buying that foam. Did you notice that straw-like device that comes with it? Just the right size to fit between the door window and window frame.
Now I can't be the only one that has ever wondered how many cans it would take to fill up a Honda. Come on now.
PS. I never tried transplanting Mr. Potato head, but I have installed two drops of crazy glue into a keyhole. The key was inserted about a half hour later. Key went in about half way, then the glue set up and froze the key right there. The door knob had to be broken off with a big pipe wrench. The spud might give you satisfaction, but the crazy glue is very quick and easy. If you can't get it started, it will be quiet.
All of these things are illegal. No not do it! You do not need to stoop to breaking the law. You are too valuable here to get your butt in trouble over this. Lets all think of ways that do not violate the law that will allow revenge for this frustrated poster.
Bob
Good Answers: 50
05/07/2008 1:52 AM
My advice is to petition for a city ordnance or just learn to live with it. If they see you messing about their cars (assuming they're out on the street), you're likely to earn a bullet for your troubles... Some kids today do pack!!!
05/07/2008 2:20 AM
Very true.. didn't we all rev our machines when we were wet behind the ears???
Some of our esteemed members still like their noisy motorbikes...ah...but we like that sound!...Back to Spary's 'potato potato'
05/08/2008 10:57 AM
Hello Vermin, A good answer and I gave you a GA for it. Vandalism against anyone's property is a crime.
According to the Los Angeles Times, one out of every four drivers are armed in Los Angeles. Provoking one of these drivers may result in our erstwhile vandalizing contributor's permanent removal from contributing to this forum again.
Here in middle America almost everyone is armed. Carrying a weapon is as natural as wearing a cowboy hat of which you will see plenty of both. Messing with thse "good 'ol boys" will get you shot so quickly "you won't even have time to holler" as they say.
An Easy Rider rifle rack is the most prevelent adornment any self respecting pickup truck owner buys. And you don't need to look closely to see several shotguns and perhaps a high powered rifle or two resting in these racks. In Texas, "he needed killin,' is a viable defense against fence cutters, cattle rustling, horse stealing and perpetrators of vandalism.
Vandalizing someone's car will probably get you killed in such pleasant places as Detroit, New York, New Orleans, Dallas/Ft.Worth, and anywhere in Los Angeles. There are probably easier ways to die but those of you avocating vandalism will find death interesting as you look into the the barrel of a .44 magnum held by a gangbanger or a 12 gauge shotgun held by an angry cowboy.
The best and most obvious solution is to complain to the local authorities starting with the Chief of Police and working your way up to the Mayor and City Council. If a car is louder than the decible limits allowed by law then it becomes a police issue which should be enforced. If there are no noise limiting statutes in the area then a citizens petition becomes the most effective method to institute such a decible limit.
Engaging in vandalism for any reason exposes one to direct confrontation with people who may have little regard for the law or have the tacit approval by the "law" to execute what ever punishment they see fit for the crime.
"Stupid is what stupid does" to quote a line from the movie "Forrest Gump" and vandalism is stupid.
intellectuals solve problems, geniuses prevent them ~ Einstein
Good Answers: 97
05/17/2008 3:16 AM
Totally agree with using the system, honoring the social compact is the issue indeed.
On the issue of guns:
A Man Who Knows His Math
I was riding to work yesterday when I observed a female driver, who cut right in front of a pickup truck, causing the driver to drive onto the shoulder to avoid hitting her.
This evidently angered the driver enough that he hung his arm out is window and gave the woman the finger.
" Man, that guy is stupid," I thought to myself. I ALWAYS smile nicely and wave in a sheepish manner whenever a female does anything to me in traffic, and here's why:
I drive 48 miles each way every day to work.
That's 96 miles each day.
Of these, 16 miles each way is bumper-to-bumper.
Most of the bumper-to-bumper is on an 8 lane highway.
There are 7 cars every 40 feet for 32 miles.
That works out to 982 cars every mile, or 31,424 cars.
Even though the res t of the 32 miles is not bumper-to-bumper, I figure I pass at least another 4000 cars.
That brings the number to something like 36,000 cars that I pass every day.
Statistically, females drive half of these.
That's 18,000 women drivers!
In any given group of females, 1 in 28 has PMS.
That's 642.
According to Cosmopolitan, 70% describe their love life as dissatisfying or unrewarding.
That's 449.
According to the National Institute of Health, 22% of all females have seriously considered suicide or homicide.
That's 98.
And 34% describe men as their biggest problem.
That's 33.
According to the National Rifle Association, 5% of all females carry weapons and this number is increasing.
That means that EVERY SINGLE DAY, I drive past at least one female that ha s a lousy love life, thinks men are her biggest problem, has seriously considered suicide or homicide, has PMS, and is armed.
Good Answers: 50
05/17/2008 3:31 AM
Hmmm. You mean they actually have traffic jams in the upper Mid-West? I didn't think there were that many Conestoga wagons around!
Good Answers: 97
05/17/2008 3:36 AM
I believe it was written for Sunset or New Jersey...and the point is "better to let sleeping lions lay."
Good Answers: 50
05/17/2008 3:41 AM
What? Sunset the magazine or New Jersy the state?
Good Answers: 97
05/17/2008 4:09 AM
Sunset the area , IE Malibu. OR COULD BE Dallas, Houston (MY FIRST PICK), Atlanta or even Miami.
Good Answers: 50
05/17/2008 4:23 AM
Sooo. I'm guessing you mean rather than pushing a potato up their butt. Correct?
Good Answers: 97
05/17/2008 11:33 AM
Correct-a-mundo
05/17/2008 9:12 AM
Can't be the Lehigh Velley. I think they all always have PMS with a tongue sharp enough to ...
Nothing exceeds like excess.
05/19/2008 9:42 AM
Hello bwire, An excellent response and I gave you a GA for it. The number of armed drivers is increasing in the heavily populated areas such as Los Angeles, Detroit, and Dallas/Ft.Worth where the Mexican mafia is the dominant criminal organization.
At one time biker gangs such as the Hells Angels, similar collections of 'motorcycle enthusiasts" were about the only armed motorists besides the police and an occassional cowboy you'd be likely to meet on the highways. Now, according to our local Highway Patrol, many unassuming citizens carry significant firepower and have participated in weapons handling and marksmanship classes. Regarding the latter, the shooting accuracy of the average armed citizen is far more lethal than the random fulisades of ill aimed bullets from automatic wepons in the hands of gangbangers.
Regarding female drivers with PMS and other distractions, I too am wary of inattentive drivers especially those using cell phones whose animated conversations often result in otherwise very avoidable collisions. Women who use the car mirrors to continue morning rituals such as applying makeup, hair styling, and other distractions which take their attention away from driving are 'ticket bait' according to a friend in the Highway Patrol. He says" like fishing, we always catch some but not all' of these accident prone drivers.
Unfortunately as we continue to accumulate time on the highways our chances increase in becoming victims of inattentive drivers or worse, caught in the crossfire of road raging motorists or gangbangers. Perhaps Kevlar armor and bullet resistant glass in strategic locations would offer some protection against gangbangers and road rage but how do we defend ourselves (other than hyper awareness) from the ladies and gentlemen lost in their diversions?
Good Answers: 97
In reply to #64
05/19/2008 10:47 AM
taejonkwando thank you for kind words.
according to our local Highway Patrol, many unassuming citizens carry significant firepower and have participated in weapons handling and marksmanship classes. Regarding the latter, the shooting accuracy of the average armed citizen is far more lethal than the random fusillades of ill aimed bullets from automatic weapons in the hands of gang-bangers.
A friend in central California said some folks there use floor to ceiling bookcases filled with used and throw away books or bundled paper as house armor.
Encouraging, I remember well the many weapons firing drills when in the service. Well trained armed citizens will not panic but follow their training if in peril.
In our cars we may need to protect ourselves by eliminating the opportunity. By contrast the level of engagement just south of the border is scary indeed should that migrate north. Knowledge of self protection may be of great comfort but I would sooner seek a rural home site. You can see 'em coming.
Many jobs can be done from home office situations even when employed and we should encourage working from home. On the other hand a few large employers in the area have setup busing for their workers. Is like unto car pooling allowing a freedom from motoring expense and parking at the business location, not to mention alleviating traffic.
Reply Off Topic (Score 6)
05/07/2008 8:09 AM
I somewhat agree with you.Altering exhaust and emmisions systems are not good for the environment.What about all the Harleys with the thunderous noise.Busses,trucks,lawnmowers,construction equipment.Could I recomend earplugs?
05/07/2008 8:13 AM
learn to deal or petition to change the laws, most places have laws that limit the noise level to 95db. Aftermarket manufacturers know of these laws and make exhausts accordingly.
I personally have a high quality catback exhaust (DC sports). It doesn't replace the catalytic converter and even at 8000 rpm's it is just below 95 db. I replaced the stock exhaust when it rusted out. The piping is routed in a more straight path with piping that is about 1/2" larger in diameter. My mpg increased after this mod by 3-4%. The ones that you guys are probably referring to are the universal mufflers that cost $30 at Pep Boys and sound more like a dirtbike exhaust than a car exhaust.
It is funny how the people that complain about noise while there are 18 wheelers making more noise idling at a light and they are probably the same ones that grew up with loud exhausts on their cars (whether it was a GTO, Mustang or even an Austin Healy) when they were young and have removed the baffles from their Harley's but when a young kid drives by with an import car they suddenly turn into a curmudgeon.
There are people walking around on the street that are annoying when they talk, maybe we can jam foam down their throats so they don't talk anymore, because when I don't like something no one should be allowed to do it.
Hobbies - Musician - New Member Hobbies - Car Customizing - New Member Hobbies - Target Shooting - New Member Engineering Fields - Power Engineering - New Member
05/07/2008 9:33 AM
"There are people walking around on the street that are annoying when they talk, maybe we can...."
If only we could. jk
Good Answers: 97
05/17/2008 11:41 AM
Careful, and put the foam in your ears then smile and nod often...please don't restrict them some may become great comics if let be (:
Good Answers: 94
05/07/2008 8:17 AM
The noisiest vehicles seem to be those little 50cc mopeds that have to be revved like crazy to get anywhere.
05/07/2008 9:56 AM
Relax, take ten deep breaths and hold the last one, put on another Glenn Miller album and crank it up.
05/07/2008 10:21 AM
Deal with it!
It "sounds" like some of you spent to much time in your mothers basement playing dungeons and dragons. A loud car or bike is a right of passage for a young man. To this day, when I here a loud (sweet sounding) car pass by my house it reminds me of my irresponsible, care free, girl chasing youth. Between you and me, I find that there are more annoying people out there then there are loud exhausts. Is it just as illegal to stuff a vegetable in someones mouth as it is in a tail pipe? I am just poking fun, but you have to admit that the exhaust coming from a vintage AC Cobra just kills.
"I had not anticipated that the work would present any great difficulites" SHACKLETON
Good Answers: 94
05/07/2008 10:29 AM
Very true, I've had several V8 engined cars with large bore single silencer exhausts. I would claim the excuse of youth but it's only about 4 years since I gave up the last one.
05/07/2008 10:29 AM
I'm sorry, but I am annoyed by whiners who forgot what it's like to be young. I'm not a fan of these vehicles either, but I put Cherry Bombs on my "66 Chevelle SS396 Sport Coupe when I was young. Still got the car but not the Cherry Bombs.
I can just about bet, that in a few years those kids will be complaining about 'kids nowadays'. Meanwhile, if they found spray-foam in their exhaust pipes, I don't think they will just lie down and take it. You may start something you can't win.
Cherry Bombs; Disturbing the peace since 1968.
OpMan
05/07/2008 10:44 AM
I too am guilty. Allthough for me it's a matter of presonal taste. I can't stand the way a 4 cyl with a fart pipe sounds, but I love the sound of an unmuffled V8. My Z28 (5.7l V8 mind you) has 3" exhaust with race mufflers. So, I am sure I piss off more than a few curmudgeons myself. When am I going to grow up? Do I have to?
United States - Member - New Member Popular Science - Weaponology - New Member Technical Fields - Technical Writing - New Member
05/07/2008 11:11 AM
For me it is selective. I appreciate the sound of a big V8 with proper high performance exhaust, such as Borla or Flowmaster. I like that deep throaty rumble! What I do not like are the little 4 cylinders running around with 4" exhaust echo tips and tiny mufflers that make them sound like amplified gas powered weed whackers! The sound is irritating to me and I have a hard time understanding how anyone could possibly think that it sounds good. It's just a goofy bolt on attempt to customize a car on the cheap. It's like people who install massive hood scoops on their cars, but don't have a super charger under the hood, or people who have massive wings or tail valences on their cars and they don't have enough hp or torque from their 4 banger to even remotely justify needing that much down force. It's just silly! These are situations where I turn to my wife and inform her that "hey, that guy over there is cool in case you didn't know!"
05/07/2008 11:55 AM
have massive wings or tail valences on their cars .
I thought they were beer trays on the back
Good Answers: 94
05/07/2008 12:03 PM
05/07/2008 12:14 PM
Yep, all show, no go!
05/07/2008 12:35 PM
But they say that those wings are worth at least a hundered HP!
05/07/2008 12:41 PM
Yeah and you get at least another 50hp if you install curb feelers.
05/07/2008 6:05 PM
No, it's so their 'homeys' can push 'em when they suffer 'spud constipation'
If you always do what you've always done, You'll always get what you've always had!
Good Answers: 50
05/07/2008 11:44 PM
Ya work with what you can afford!!!
05/08/2008 2:46 PM
Guilty as charged, I'd owned a Toyota trueno (corrolla gts) with a loud exhaust, my pathfinder (v6) has a loud exhaust, and my wishlist for the future include a yamaha v-max with loud pipes and a ford f250 with the 5.4 v8 and guess what? loud pipes.
Did i mention that i'm 34 years old with wife and kids?
Sese
05/08/2008 3:13 PM
the ae86's were(still are) sweet cars. I owned one but I crashed it. it is hard to find ones that fairly rust free. Mine was loud as hell too.
05/07/2008 6:00 PM
I would not suggest messing with someones car, with potatoes or foam or anything else. I'm sure you wouldn't want someone else damaging your personal property. However, if in the process of making all the noise they speed their car over a legally installed speed bump of the correct height and steepness on your street, it can be a very effective oversized tailpipe removal tool. They will slow down, which will quiet it down or just stay off your street. Of course that means you have to go slow on your street too. So, talk to the neighbors. Would they rather listen to the kids or deal with a speed bump?
05/08/2008 6:17 PM
if there are any of the old time paint manufacturing plants in your are ask if your can get a few pounds of the old grinding mill stone pellets.
slip a few on the roadway as the idiots pass walk away very quickly, hear the crunch of stone as the tires pass over them followed by rapid air loss as the tire ruptures. works better than any spike belt. doesnt injure people or the environment, sure ticks off the yahoos whose treads are avge. of $200./
'da ber
Good Answers: 123
05/09/2008 7:48 AM
"doesn't injure people or the environment"
Did you see the thread on repairing motorcycle tires? Some of the people responding there seemed to feel that a sudden loss of air in a tire could lead to an ill handling vehicle. Would that apply to these vehicles also?
Bob
Good Answers: 50
05/10/2008 1:25 AM
Yes, but not quite so lethal.
05/13/2008 9:42 AM
While not suggesting you do this, rammed potatoes work temporarily; yellow stuff more permanent. Beware, big noise = small brains and possibly guns.
Eschew obfuscation.
Good Answers: 50
05/14/2008 1:32 AM
"Gosh, Larry. I sure do hate those loud-car guys!"
"That's easy, Bev. Just kill them."
"Ya think so, Larry?!"
"Sure, Bev. It's easy. Here, take this guy!"
"Golly! Thanks, Larry!"
05/14/2008 10:46 AM
Just tell Eddie to do it.
Good Answers: 50
05/15/2008 1:50 AM
That's a plan, but it will probably cost... And would you really want to owe Eddie anything?!
05/15/2008 2:01 AM
Then the Bev takes out Eddie. The trail is broken. Everybody wins.
Good Answers: 97
05/14/2008 12:44 AM
Spraying insulating foam into the radiator fins sounds like a good idea to me. Or a fine mist of silver lacquer on the headlight lens. Maybe a thin bead of silicon grease upon the edge of wiper blade. A huge banner decal across the windshield may get attention. Could wrap a string with two washers around the axle so can contact when speed is slow, thunk-thunk is the Pitts. Or add a couple indiscriminate wheel weights for fun.
All this passive aggressiveness, ugh!
Introduce yourself and take em for a ride in a real hot rod or to the track or just ask em not to disturb ya! Stop being a chump...
05/24/2008 10:36 AM
ok that first part was scary man!! what have you been doing?
pineapples hate me.its ok i dont fancy thm that much anyway.
Good Answers: 97
In reply to #71
05/24/2008 4:01 PM
Growing up in general
Good Answers: 97
05/17/2008 12:02 PM
The police have priorities that do not include annoyance themes such as loud exhaust unless coupled with V8 which then can be identified as "exhibition of speed" but the 4banger does not equate.
If the police did get involved in annoyance type restrictions seriously then ticketing for failure to dim hi-beam lites in the presence of on coming traffic would be first on my list.
You can adjust your precept to eliminate the scenario from those things which irritate.
Remember many youngsters have been listening to 112db + audio systems producing low frequency bursts down to 32Hz and they think the exhaust sounds cool. You should pity them they will never regain the ability to distinguish nuances.
Try a different tact:
Educate young folks about the consequences of unprotected exposure to high decibel audio, and the debilitating physical effects of low frequency sound upon the organs and tissue of their body.
05/17/2008 4:06 PM
We didn't care when we came home with serious ringing for three days after a rock concert, what makes you think they will pay attention?
Good Answers: 97
05/17/2008 4:23 PM
They are prepared for reality, they learn from our mistakes; weird eh?
Good Answers: 50
05/18/2008 3:14 AM
"They learn form our mistakes?!"
What the hell have you been smokin'?!
"Oh, daddy! Please don't make me go to the rock concert with Billy! I ever so want to keep my hearing intact!!! As well as my virginity!!!"
Good Answers: 50
05/18/2008 3:09 AM
Every kid in the World has heard that time-and-again, but they still go to concerts... Do you remember coming out of one and noticing how quiet everything was?
Good Answers: 97
05/18/2008 10:29 AM
Yeah I remember but the audio systems today are far more accurate and the bass tones we listened to were of higher frequency 80Hz-250Hz. We had loud music but they can have damage at lower volumes due the capability of newer systems to produce the low frequencies accurately 18Hz-125Hz.
The kids I've talked to respond well if given actual detail instead of colloquialisms.
Their are low frequency audio devices used in weaponry ya know...
Good Answers: 123
05/19/2008 7:27 AM
" respond well if given actual detail instead of colloquialisms"
My children do the same. Then they mutter under their breaths, "Ignore him he is too old to make any sense> He has no idea."
Bob
Good Answers: 97
In reply to #60
05/19/2008 9:29 AM
Slips right through the defense system doesn't it...
Ironic though it seems kids 10 and under idolize their parents, 11-13 are in general flux, 14-23 wish they had never known their parents. Sometime afterward end being just like them it does wear off in some delayed manner.
Good Answers: 94
05/19/2008 5:13 AM
"... Do you remember coming out of one and noticing how quiet everything was?"
Do I remember??? recently I've been to see Gary Moore, Wishbone Ash, Albert Lee & Motorhead. This weekend is the local music festival & I expect to be there. I'm always surprised to see how many of the audience at these events are of similar age to me.
Good Answers: 50
In reply to #59
05/19/2008 11:37 PM
Christ! Is Motorhead still around?!
Good Answers: 94
In reply to #66
05/20/2008 4:16 AM
Still alive, still touring, still the loudest band you will ever hear live.
Good Answers: 50
In reply to #67
05/21/2008 2:32 AM
Can Lemmie still make a squeak?
Good Answers: 94
In reply to #68
05/21/2008 4:38 AM
Still loud & proud. I saw him interviewed a little while back & he claimed to be off the booze and into quiet nights in with a good book, seems hard to believe.
Have a look at this YouTube video to see a few guitarists from the past, it made me laugh.
In reply to #69
05/21/2008 12:32 PM
The evils of drugs.
05/19/2008 7:54 AM
"themes such as loud exhaust unless coupled with V8 which then can be identified as "exhibition of speed"
So true, I have personally been sited for "exhibition of speed" in my Z28 and I wasn't going that fast. Not as fast as those fartpipers, at least. A V8 just sounds faster.
Pesonally, I think that "Exhibition Speed" is a Bull$#it citation anyway. But, that's a rant for another time ;)
Good Answers: 97
05/19/2008 9:31 AM
Okay, yeah it's a catch all...
05/29/2008 4:27 PM
Loud pipes save lives!
Good Answers: 97
In reply to #73
05/29/2008 9:00 PM
Amen!
Reply to Forum Thread 74 comments
Anonymous Poster (2); Bill (1); bob c (3); bwire (14); IanR (4); Jaguar (6); Kyoto (1); Moto (1); NiCrMoNoMore (1); Nigh (7); OpMan (1); ozzb (1); PhysicsProf (1); pwr2thepeople (1); Sciesis2 (2); sese_norville (1); shanky1367 (1); sidevalveguru (1); skeptical guy (2); Sparkstation (2); taejonkwando (2); user-deleted-1105 (3); Vandarye (3); vermin (13)
