Molded Delrin halves are stuffed with electronics weighed and submerged in 1:1 ratio of glycerin and water. Subjected to 150PSI for 4 hours.
When the units come out they are weighed to see if they have taken on water. If there is a weight gain of greater than 2 oz they are taken apart to see if water is on the inside.
Those with no indication of water are left to sit for several days and re-examined. They are showing glycerin on the inside of the cases.
What would be the cause of this anomoly? The Delrin is molded and approximately 1/2" thick. Can the glycerin be pushed into the delrin by the pressure and show up later?
What harm can glycerin cause electronic PC Board and 9V battery?
