Previous in Forum: 3 element boiler drum level control   Next in Forum: Displacer Mounting Details
Thermocouple
05/31/2008 7:16 AM
Frnds,
Pl let me know Thermocouple cold junction compensation technique.
Pl send it to my email id:shalyraju@gmail.com
Pathfinder Tags: thermocouple
Re: Thermocouple
05/31/2008 8:04 AM
There are many types of cold junction compensation techniques...
Most are more than adequately described in data books and on-line basic tutorials.
Good Answers: 54
Re: Thermocouple
06/01/2008 6:38 AM
One technique is to use a semiconductor temperature sensor to measure the temperature at the cold junction and use that data to reference a look-up table or as an input into a temperature compensation equation.
Okay, I've never had any real reason to learn the specific technique used by a temperature controller or transmitter. All I needed to know was that the unit had it. Unless you're actually building the things, there should be no reason, except for self-satisfaction, for you to know how it's done.
If you really want to learn, as Electroman advises, search the 'net or find a good instrumentation handbook.
Re: Thermocouple
06/10/2008 11:17 AM
Hi,
One of thet technique is to keep the Cold Junction in Ice Bath maintain at 0 Deg C & Hot junction at measuring chamber/Line etc.
Good Answers: 54
Re: Thermocouple
06/11/2008 9:39 AM
That technique is only applicable for explaining the concept of Cold Junctions. It is not a practical method for general use. I certainly would not buy a controller or indicator that needs an ice bath for it to function properly.
Register to Reply 4 comments
Electroman (1); pappu (1); Vulcan (2)
