Previous in Forum: Industrial Electrical Equipment   Next in Forum: Modular Could Mean More Noise
Thermocouple Testing
08/16/2006 3:42 PM
Steve writes:
Can A K-type Thermocouple be tested with only a DVM and test leads? I have no other choice and I'm not able to disassemble the installation. What readings should I expect on the DVM?
Thanks
maybe
08/17/2006 12:20 AM
I'm not sure of the exact value for the K thermocouple but most thermocouples will read around 4 to 5 millivolts with a 100 degree centigrade temperature differential. So if you can heat up the end and see that much of a voltage rise with your meter it won't tell you if it is accurate but could tell you whether it is dead or not. Good Luck!
Feasable but use decent equipment.
08/17/2006 3:40 AM
Depending on the used type of thermocouple you can try to measure the functionality of the thermocouple. A K-style has a typical value of 41 micro Volts per degree Centigrade. With a zero passage at approx 23°C (why it is so easy to connect it wrong) If you doubt on the functionality: try to measure the intrgrity of the system, with an Ohm meter you must find a short circuit (at least a closed) Google around.
Good Answers: 18
08/17/2006 8:49 AM
Check out Omega's web page for testing thermocouples. It even has a table of values for K type T/C's.
Good Answers: 32
Testing thermocouple
08/31/2006 3:34 PM
Yea, you can test type-K or Cr-Al thermocouple by DVM/DMM.
Use lighted candle and heat one end of the thermocouple. It will generate 40uV/C output. For flame temperature of 800C, it will have 3.2mV which is measurable as most DMM have 200mV range.
Change of direction changes polarity. Wires are like battery in thermocouple with hot and cold junctions. Cold junction is actually open end you connect to DMM/DVM
Shyam
Hobbies - Musician - Tube Amps Only Please!
Re: Thermocouple Testing
10/27/2009 10:05 PM
I used thermocouples and they have a chart of voltage to temperature. Use ice & boiling water to test the reading.
Regards, Maveric Manic - 'Knowledge is Power and Wisdom is knowing how to use it'
Bill (1); Gwen.Stouthuysen (1); maveric_manic (1); rcapper (1); Shyam (1)
