Previous in Forum: Rigid insulation for small ovens   Next in Forum: which type of Diaphragm valves I should select
Difference between Allen and Hexagonal Bolts
06/14/2008 6:06 PM
What is the diff betwn Allen and Hexagonal bolts???
United States - Member - US Navy Veteran
Location: Nothing sucks more than that moment during an argument when you realize you're wrong.
Good Answers: 22
Re: Difference between Allen and Hexagonal Bolts
06/14/2008 7:00 PM
Application (top/side clearance) and user preference.
I hate hex head bolts almost as much as I hate flat head screws!
I've also found that cheap Allen Head bolts (socket head cap screws) are usually tougher than cheap hex head bolts.
Talk to a fastener supply Rep. for bulk prices and general info.
Look in a copy of the Machinery's Handbook for detailed info.
You never know when it will strike, but there comes a moment when you know that you just aren't going to do anything productive for the rest of the day.
Good Answers: 230
06/14/2008 8:37 PM
Hello Guest,
Is this a Class or Homework Question?
Reply here, with
Kind Regards....
Good Answers: 54
06/14/2008 10:50 PM
Hmmm, yes, the question is too easy to be from someone who's not a student. However, just to comment on details about the things that I didn't get from school and only learned from the school of hard knocks:
  • Hex head bolts have generally bigger heads than allen heads. Makes it unsuitable or difficult to use for small equipment.
  • I can use a number of different tools to move a hex head bolt but am limited to only two for the allen head (an allen key or a small (very small) pipe wrench).
  • Most allen head bolts are recessed or "buried" while hex heads are usually raised. If a hex head is worn (rounded), I can use other tools to get it off. However, a recessed and worn allen head is a very big pain to remove. There's a special tool for this but I usually can't find it (someone else is using it).
  • In tight spaces, hex heads are difficult to remove since a wrench needs space around it to turn. Only option in this case is to use a socket wrench with an extension. Allen heads don't need much space for the allen wrench.
06/15/2008 1:29 AM
Torx (star) bits can be used where the damage to an allen head is not too severe. The slightly tapered design allows for "remodelling" with gentle application of a "Glesga screwdriver" (hammer).
Madness is all in the mind
06/15/2008 8:38 AM
ROFLMAO @ 'Glesga screwdriver'
First time I've heard a hammer called that !!!
Electroman (1); GM1964 (1); markar (1); Sparkstation (1); Vulcan (1)
You might be interested in: Bolts, Captive Screws, Anchors
