Previous in Forum: Questions about pressure rating for Valves.   Next in Forum: Reference Vertical Datum for NAD 83
51 comments
Journey through the Earth?
07/18/2008 4:17 AM
Silly question we have going in the office: dont know if it's been asked before? But should be able to trust my peers to come up with some really goods answers.
Say I drilled a large hole straight down to the other side of the earth. Ignoring any molten lava and whatever else might be down there, including ice, water and the devil and his cronies, and we have big enough drilling rigs et al et al. Once drilled and the hole stayed open and someone jumped into a custom designed "Soap Box cart" kitted out similar to the latest space craft with ceramic tiles, breathing equipment etc and headed down the hole without hitting the sides and ignoring the earths rotation, what would happen?
We assume that the Soap box would reach terminal velocity quickly and reach the centre of the earth. Once there, would it speed up or slow down or stop at that point? And then or if, it exits the earth on the other side would it come speeding out or just gently flop down onto the earths surface?
Insanity is not running into a brick wall over and over again. Insanity is expecting a different result each time.
Re: Journey through the Earth?
07/18/2008 4:24 AM
There's an awful lot of invalid assumptions in that question.
07/18/2008 4:27 AM
I'm sure this has been asked before...maybe even as a challenge question.
I think the answer was it would overshoot the centre, then come back, overshoot etc.
e.g it would oscillate.
You can simulate this with a piece of string and a weight...I believe this is called a pendulum
United States - US - Statue of Liberty - Sworn to preserve and protect Engineering Fields - Nanoengineering - How tiny is it? APIX Pilot Plant Design Project - Member - Good idea. Engineering Fields - Engineering Physics - Engineering Fields - Energy Engineering - Energy in Transition
Good Answers: 15
07/18/2008 5:40 AM
GA Del. You hit the nail on the head.
A small extension - if friction is assumed away then the craft will shoot to the center of the earth, always accelerating (initially at 32 ft/s/s) at a decaying rate until the acceleration reaches zero (and speed maximum) at the center, and continue through the hole. Acceleration will increase as you move away from the center, slowing the craft at increasing rates and bring it to a stop at a distance from the center that is equal to the distance where you started but on the opposite side of the globe. Then you craft will reverse course and do it all over in the opposite direction. And then reverse, and reverse, etc., and continue back and forth in a non-decaying oscillation. You will need a lot of supplies. And then, assuming perfect health, you will die of old age, still in the oscillation. .
But, actually, with even this set of assumptions it won't happen this way. If you enter the Earth in South Africa (your stated location) you will exit it at a point Northeast of the Hawaii Islands in the bottom of the Pacific Ocean - a really deep part. As soon as you break through on that side the ocean will pour in, almost instantly flashing to steam and quickly becoming VERY superheated. It will expand as it heats travelling through the earth and exit as a hypersonic (well, certainly supersonic) stream (driven by expansion, rather than gravity) over South Africa. From there it will spread out across the planet to (I assume) catastrophic consequences for all life. Sadly, you won't get a chance to launch your craft.
Maybe that is why people don't usually drill those holes.....
Best Regards
“Truth is stranger than fiction, but it is because Fiction is obliged to stick to possibilities. Truth isn't.” – Samuel Clemens in Following the Equator, Pudd'nhead Wilson's New Calendar
07/18/2008 5:51 AM
Can't type or even see the screen-have tears of laughter streaming down my face......ta great reply
Re: Journey through the Earth? No way . . . out.
07/21/2008 6:30 AM
Oscillations would diminish such that you would eventually by stranded at the center.
07/21/2008 6:58 AM
Indeed...the pendulum demonstrates this admirably.
07/22/2008 2:16 AM
I'm not so sure about the oscilation theory. I agree about the decay in the acceleration rate, however Gravity, which is your fuel, is sourced from the material the earth is made of not its central point, consequently as you decend further not only does the acceleration rate decrease but the material behind you is accelerating you backward. which may lead to your ship to be actually travelling at a constant velocity from a point halfway to the middle.
having said all that the crush force at the centre would is equal to the entire mass of the earth, less your billy cart and contents. consequently the hydrodynamic effects cannot be discounted
Good Answers: 50
07/22/2008 2:24 AM
Nor can the alignment of the instantiator.
07/22/2008 5:51 PM
Think again, Guest#38, because you might have overlooked the mass component of gravitational acceleration. As the intrepid explorer "falls" core-ward in the tunnel, the mass in opposite directions around him (laterally) will offset, so that his weight remains constant with respect to the tunnel walls. However, the density (and with it, the mass) of earth increases core-ward, which would offset to some degree the anti-acceleration you propose; additionally, as he approaches the densest part of earth, the core, even though there is ever increasing over-head (virtual gravitational attraction), there would also be greater under-foot virtual gravitational attraction imparted by the mass beyond the core (between the core and China ). So, it would be the net of these over-head and under-foot attractions which, but for his core-ward momentum, would condemn him immediately to eternal perdition at the center of the core; but because of that momentum, which must decrease with each passage through the core, he will be granted, for a time, the boon of pondering his ultimate fate while in a state of oscillatory purgatory. It will be a very cruel purgatory at best . . . and very unkind in the end.
Guest#33
Good Answers: 97
07/18/2008 7:25 AM
Hi Ryan
I have a better one for you. (a combination with another previous post (straw))
While tunneling the hole should be lined. After surfacing near Haiti and watching the girls go by the lining should be extended right up to space.
If one now jump into the hole one will be sucked into space on the other side.
Zim may be a better starting point - Imagine selling rides at Z$1,000,000,000 and solving some problems at the same time.
07/18/2008 7:59 AM
Lets do it! After reaching Haiti we could jump out, supervise the extension from the beach whilst sippling pinacoladas and enjoying the sites. But we give "old Bob" the first "first class ride" ultimatley giving him what he wants-his name in lights-we just wont tell him how far away they actually are!
07/18/2008 9:50 AM
I couldn't help but notice that you didn't stipulate that snacks and alcoholic beverages would be served on the trip. Frankly, I find such items to be of absolutely critical importance in relation to this journey and their omisson completely invalidates your questions.
And this is not because the trip duration would be nearly a day. Even if it only takes 10 minutes such ammenities simply must be factored into any scientific endevour. Please do more research on proper hors D'oeuvre and drink fabrication then re-post your question.
07/18/2008 10:09 AM
Whatever you do don't pee out of the window of the capsule 'cos you will meet it on the way back
07/18/2008 12:27 PM
Of course not! I would NEVER do such a thing. I can't believe you'd even for one moment entertain that I might be so foolish!
Doing so would run the unthinkable risk of accidentally extinguishing the secret sun that burns at the center of our hollow Earth. What? You didn't know about that? Of course not...it's a secret.
Good Answers: 97
07/18/2008 10:50 AM
If it take a day to pass through the tunnel must follow a curved path to prevent hitting the sides as the earth rotates.
I suppose the tunnel could end up spiraling towards the centre.
Good Answers: 96
07/18/2008 11:17 PM
I can't recall if it was from some SF reading or some less-than-practical 'Mechanic's Illustrated' from years ago ... but this was actually proposed. Not through the CENTER of the Earth, but through the mantle. Del is right (catty of him ) ... in an unaided environment, the mass would oscillate, finally stopping (how long would THAT take) in the center.
BUT, the premise of the less-than-practical idea was that the trip would take very little energy, because the ride is 'free' except for a little 'push' at the end.
Okay, some QUICK and BROAD BRUSH STROKE numbers (I'm no geologist ): The Earth's diameter is about 12,750 km. The upper and lower mantle is about 2900 km thick, so, assuming all that was a clear path, the tunnel would be about 10,700 km long. (I haven't checked Google Earth to see from where to where that might take you on this water-planet, but, it IS interesting, and would be one hell of a ride. The angle of entry would be nearly 60 degrees (think about it ... who needs straight down ... OMG).
SO, here is MY question within this post:
Assuming my crude numeric assumptions, assuming such a tunnel could be dug, assuming one could find a suitable place to 'start' and 'end', assuming, assuming, assuming ...
How quickly would one accelerate, what would be the maximum velocity (assume frictionless), and how long would the trip take?
"Just when I had all the answers, they changed all the questions"
07/19/2008 3:41 AM
And how much are the tickets for the ride? and are Cats allowed too?
Good Answers: 96
07/19/2008 3:59 AM
Cats are always allowed in my book ... especially COOL CATS
Engineering Fields - Mechanical Engineering - Member
Jney through the Earth?
07/19/2008 12:13 AM
You will oscillate. The tunnel need not pass thro' the centre of earth. It can be a long chord. The effect will be the same. All tunnels are parellal to the earth's surface i.e., curved. You can refer to "Physics for entertainment", a russian publication in 3 volumes. This question has been analyzed in depth
Good Answers: 70
Re: Jney through the Earth?
07/19/2008 1:27 PM
This was also dealt with on a recent Discovery TV show. As venkat points out the tunnel doesn't need to go through the center. The result is the same for a chord. But only in a world with no friction at all would you reach the surface again at the other end. With friction you will very quickly become a trog, stuck forever in the center of your tunnel. (This has been dealt with in the recent 'If you drop a stone in a deep body of water' discussion.) Bring your own girls and 'coladas.
Good Answers: 50
07/19/2008 2:42 AM
Ryan?! Cousin, Ryan?! Is that you?!!! Where the hell you been! Do you know how worried aunt Francine is! You bastard!!! And wipe that damn smile of your smug-ass face!!!
07/19/2008 3:49 AM
You drill the hole in a curve around the center of the earth. (distance from center might take a bit of math) The centripetal/centrifical ??? force will speed it up enough to get it back up to the surface and it can be caught when it emerges. Then you set up air locks and remove the atmosphere, provide a mag-lev type track, and use a sphere that is heavier at the bottom. This will allow it to rotate so that it will be facing right side up when it reaches the other side.
Just like doing a "slingshot" around a planet to gain speed for a deep space mission, but in this case its likely to turn into a Disney ride. Or a way to get products from China into Wal-Mart without overseas shipping costs.
Good Answers: 50
07/19/2008 3:58 AM
Your "space-shot" slingshot analogy is inherently flawed.
07/19/2008 4:50 AM
"Inherently Flawed"
Nice.
Dismissal by cliche.
Strangely enough, it takes less thought to criticize than it does to create. That's like sitting down to a 50 dollar dinner paid for by somebody else and then tipping the waitress a five so you look like the big shot.
Good Answers: 50
07/19/2008 6:30 AM
I'm pooped, and the morphine drip is kicking in. I'll explain tomorrow... With graphics.
Good Answers: 46
07/19/2008 5:11 AM
Ok everyone, the earth is not quite round or even. Put the start point on a tall mountain say Everest I think that the highest mtn. Then you could avoid the pendulum effect if you had a way to stop from falling back in.
metalSmith's
Metal is the material, The forge is life, The anvil and hammer bring character and soul.
07/19/2008 5:14 AM
Employ a good catcher with a BIG mitt .
07/19/2008 2:03 PM
A center that pulls you to it, needs accleeration on the other side of it. Avoiding the confusion of spherical to look at, a straight line is easier. I would find an active mass from the center for the journey back out, to pop vehicle out the other side like a ripe lava zit...on land of course. the bottom of the ocean is not a good place, no doubt. It would be dark. Unless a giant squid wants to grab you and take you to the top...crap outta luck there, more than not.
Be sure to use an 87 subaru. nothing else will survive. and be it dual range, carbed and a 5 speed.
Good Answers: 68
07/19/2008 8:58 PM
Hello Ryan,
great idea but, you would not be doing this to save on air fairs by any chance?
And what is the best start/destination point so you will pay the least Tax? Because you know they will 'chase' you everywhere! Can I have the drinks and snack concessions? Though I would imagine you would just a little more than a snack
Don't take chocolate, it may melt..................
babybear.
Good Answers: 50
07/20/2008 11:47 PM
Just have a guy at the other end of the hole to quickly yell, "Get out and jump now!!!"
Good Answers: 68
07/21/2008 3:13 AM
Hello vermin,
hope you are OK?...........This is an interesting if illogical question don't you think?
I think they should pay taxes before they go 'cos' they are never coming out , from the sounds of things anyway.
What would you actually 'catch' them with? A stronger magnet than the earths mantle? I doubt you could make one. It would cost too much and take too much power.
take care
babybear
Good Answers: 50
07/22/2008 2:06 AM
Actually, the Earth's magnetic field is rather weak with regard to area. I'm thinking a good sized neodymium magnet could drag them out or at least keep them from falling back!
It's fun to pretend, but taking all "Real World" aspects into account, I'd be much more frightened with the chain of events that would be released on the surface of the Earth just by digging the hole!!!
07/21/2008 3:07 AM
Some prick would stick his finger in the hole at the other end and stuff you up.
Good Answers: 137
07/21/2008 4:22 AM
Hello Ryan
When I first looked at this thread I thought you were vermin. (not being personal, I'm sure you're a perfectly nice bloke, I mistook your avatar for Vermin's )
This one came up a couple of years back, and the ideal case (no air, no friction, non-rotating Earth etc) was discussed at length. Roger Pink and Physicist contributed, along with plenty others.
A quick calc shows that it takes ~ 42.3 minutes to reach the other side, and at centre of Earth the speed ~ 40000 km/h.
An interesting thing that came out of earlier discussion is that the vehicle sees a compressive tidal force, whereas in space between gravitating bodies tidal force is tensile.
Cheers...Codey
United Kingdom - Member - New Member Engineering Fields - Transportation Engineering - New Member Technical Fields - Marketing/Advertising - New Member Hobbies - Target Shooting - New Member
07/21/2008 4:26 AM
You could use it for exporting cooked meat products. Throw raw meat in one end and retrieve the very well cooked meat from the other.
07/21/2008 4:46 AM
Throw politicians in one end...and retrieve the very well cooked meat from the other.
Good Answers: 68
07/21/2008 4:52 AM
Hello Del the cat:
are you OK?
Brilliant idea! Put some Mosquito attractant on them to take Malaria down there and away from decent life.
stay safe
babybear
07/23/2008 6:24 AM
Very well cooked indeed, but still highly unpalatable...
Why did it take this far into the thread to remember the heat factor from the molten mantle I wonder?
07/23/2008 9:03 AM
OK...If you insist on being sensible about the whole thing...
I can counter that by saying...let's transfer the question to the Moon!
Ok it'll be a slower ride but doubtless a bit cooler...hey man it will be soooo cool!
Hmmm how hot is it in the centre of the moon? idunno...
07/23/2008 11:50 AM
All I was trying to do was to point out that no matter HOW you cook a politician, they're still impossible to swallow! Fried, fricasseed, casseroled, boiled, broiled, grilled, baked, roasted on the spit - all inedible material! FEH!
07/23/2008 3:13 PM
Whoops, yes indeed...but how hot is it in the centre of the moon? Or do I have to ask on a new thread...just don't make me do it.....
On the moon you could probably whoosh through whilst sitting in Kris' old bath .
07/23/2008 3:23 PM
I reckon his old bath is over the moon all right - but it would've got there quicker had he followed my recommendation to use liquid oxygen and C4 on it. The center of MY moon is 98.6°F, as if it's any of your affair...
Good Answers: 50
07/23/2008 11:34 PM
Because the premise was we could forget about all the real world stuff... And come where I live, as a matter of fact!
Good Answers: 68
07/21/2008 4:54 AM
Hello Chankley:
NICE ONE!
stay safe
babybear
Good Answers: 50
07/22/2008 2:11 AM
And not cannibalistic!
Good Answers: 68
07/22/2008 8:49 AM
Hello vermin
shorter words please! Can't take those long words while I am eating.........................Or should that be long worms?
babybear
07/21/2008 7:06 AM
07/25/2008 9:33 AM
ASUMING YOU COULD DRILL TO THE OTHER SIDE . THEN IT WOULD TAKE A PRETTY CRAZY PERSON TO JUMP INTO THE HOLE AND RIDE A SOAP BOX TO THE CENTER. BUT IF YOU DID DO YOU THINK THE SPACE SHIP DOWN THERE WOULD GIVE YOU A RIDE OUT? HA HA
JOHN DORN
07/25/2008 9:40 AM
If you couldn't make it out, do you suppose Pat Boone would serenade for an eternity? Heaven? Or hell?
07/25/2008 11:29 AM
"Heaven? Or hell?"
Either way, unpalatable!
Good Answers: 50
07/26/2008 12:10 AM
What's the money for? To buy some of his zit cream so he'll just shut up?
Register to Reply 51 comments
Anonymous Poster (7); babybear (5); blisterbill (2); Chankley (1); cnc man (1); Codemaster (1); DCaD (2); EnviroMan (4); Hendrik (2); johnfotl (1); metalSmiths (1); PWSlack (1); Randall (1); Ryan (2); solarbuster (1); user-deleted-1105 (8); v1sor (1); venkat (1); vermin (9)
