Previous in Forum: how can i design the coil for heat transfer   Next in Forum: LM/FM ASME B16.5 Class 150 flanges
14 comments
synthetic bearings
07/21/2008 4:56 AM
I am a designer of winches for maritime service and instead of roller bearings i would like to use extremely low friction syn thetic slide bearings. I did use modified polyacetal copolymer bearings but I'm wondering wether anyone could advise me about other bearing synthetics. It's important:
1 a very low water absorption
2 a very low friction
3 as much as possible self lubricating
4 a reasonable load bearing capacity like polyacetal in general
I look forward to your comment,
Kind regards Willem van Beers, from a cold and rainy Holland
Willem van Beers The Netherlands
Re: synthetic bearings
07/21/2008 7:55 AM
The modern rail industry sometimes uses high-density polyethylene [HDPE] as a slide material at slide chairs/baseplates, where the switch rails at a junction slide from side to side. They need little-to-no grease to operate properly.
Polytetrafluoroethylene [PTFE] is another useful material. It has a low co-efficient of friction, and a high temperature withstand capability. It can be filled with glass beads to extend the upper temperature range, and is sometimes called "polyfill" when in use as the seats in valves that are used in connection with high temperature steam; the polyfill material extends the upper temperature limit.
All the above have excellent water rejection properties.
Good Answers: 266
07/21/2008 8:53 AM
Look at Rulon it is teflon material which has been modified to be rigid. Has a low coefficient friction and is self lubricating.
There is all so hybrid ball bearings. Where the balls are if a cermet material. With the races of steel to thermoplastics.
Good Answers: 97
07/22/2008 2:36 AM
Good Answers: 109
07/22/2008 3:21 AM
Hi Willem46,
if trying to go to sliding bearings I would first try to minimise the shaft diameter by selecting a high strength stainless steel: ? 17-4-PH?
then as recommended by others look to the various Teflon + another material.
From these you need in addition to your list of requirements a high thermal conductivity.
The heat that is generated by the bearing acting with friction has to be dissipated else temperature will rise and load capacity will vanish.
So I think Teflon-Mica, Teflon-MoS2 and Teflon-Bronze will be good candidates.
(From the last two I have samples, If you want some, send your address.)
There is also a variety of Teflon used in machine-tool slide-ways that is said to be very good and there is a castable plastic that very likely incorporates Teflon and Ceramics.
(I have the manufacturer somewhere, to be searched if needed.)
Greetings from the equally cold and rainy Germany.
RHABE
Safety - Hazmat - New Member Engineering Fields - Mining Engineering - New Member Engineering Fields - Construction Engineering - New Member Hobbies - Hunting - New Member
Good Answers: 12
07/22/2008 7:49 AM
You could contact john.p.baker@skf.com
He's been in the bearing industry for over 30 years and will be able to direct you to any one of SKF's engineers.
John J Baker
Good Answers: 58
07/22/2008 8:04 AM
Rulon has already been suggested and is a good candidate. In addition, I would consider a Dupont product called Vespel, and if you prefer a natural product, try Lignum Vitae. I suggest you not use Teflon because of its cold flow characteristics.
Good Answers: 150
07/22/2008 9:25 AM
One problem you will have with plastic bearing materials will be cold flow, all of them do it to some degree. And the PV ratings of them all will be much lower than a sintered and oil impregnated bronze bearing would be. some of the better load bearing ones will be PEEK, PEK, or PPS. All three have very low water absorption/swelling. Rulon is in the PPS family if memory serves. You can increase the load bearing by additions of carbon or glass fiber. 40% glass fiber fill goes a long way to increase bearing capacity and reduce cold flow.
Who is John Galt?
07/22/2008 4:31 PM
Dear All, Thank you very much for your generous and helpfull comments and assistance. I did use in the winches a HDPE modified POM as a bearing material, no coldflow because of the large bearing surfaces but the main problem was/is that the efficiency of the winch compared to roller bearings was much lower and I will test Rulon/Vespel/HDPE/PEEK/etc as specified by you in a number of winches. I cannot use any glass or carbon filled synthetics because the low weight racing winches are made from teflon filled hard anodised aluminium and also copper, carbon or MoS2 filled Teflon can cause galvanic corrosion problems. Lignum Vitae is a problem with the European rulings, I did use it for handgrips and 40% proved to be srcap because of severe cracks, it is very hard to buy top quality L.V. from the Carib which is banned from the market here. One of the problems with the HDPE/POM also was the stick/slip behaviour. The PV value is not so much of a problem, the load is mostly static and the winches ar slow running. Until now I tried the synthetics from within the POM and PETP range and I'm very happy with your suggestions which will be tested. I also have a small photography company where I photograph my customers yachts www.sailingclassics.com here you can check on what type of boats my winch designs are used. But the same bearings have to be used in ultra light racing winches too.
Rhabe we had a sunny day in Holland which you will get by tomorrow.
Again thank you, kind regards Willem
Good Answers: 150
07/22/2008 6:07 PM
Willem, I'm a victim of my own prejudices, when I saw the words "maritime winch" in my mind's eye I envisioned a giant mooring winch for shipboard use or something of that sort. I was not thinking racing yacht sail line winches. You'll NEVER be able to get the efficiency of a roller element bearing out of a plain bearing. Plain bearings are good for high loads and slow speeds, at the cost of higher friction. Might I suggest angular contact ceramic ball bearings instead of roller bearings? You'll get corrosion resistance, low friction, and higher speeds without stick-slip.
Who is John Galt?
08/12/2008 10:48 AM
Dear Rorschach, Sorry for the late reply but I was in the Provence mountains in France and my company was on holiday. Loads on sailboatwinches can be extremely high, we tested a 8,6 Kg. aluminium winch up to a load of 5600 Kg. without any damage to the synthetic bearings or gears. So the load per Kg. of weight is rather high. I will use a few ceramic bearings inside the gearing system but for the main bearing which takes the load from the drum I need I.D's of 180mm up to may be 500mm! I couldn't find any large diameter ceramic bearings on the Internet. I did use smaller stainless steel ball bearings in the past but none of them are seawater resistant. That is the background of trying to find a suitable synthetic bearing material. I have room enough to use a large size bearing in order to reduce the load per sq. cm. but it may never have the efficiency of a ball or rollerbearing. I also will CNC machine some larger diameter roller bearings with PEEK rollers to test.
I will inform you aboat the future bearing system as soon as I made up my mind.
Kind regards and thank you for you assistance. Willem
Good Answers: 150
08/12/2008 11:05 AM
You might check with Kaydon, they make some large diameter thin section roller and ball bearings, many of which are used offshore.
You are making me jealous you do know that right? =D
Back to the salt mines for me...
Who is John Galt?
Good Answers: 150
08/12/2008 12:46 PM
perhaps this can help:
http://www.kaydonbearings.com/catalogs/catalog300.pdf#page=119
Who is John Galt?
Good Answers: 109
08/12/2008 2:21 PM
Hi Willem 46,
there is no chance with plastic rollers in highly loaded bearings!
If you need the low friction of roller bearings then very tough rings are necessary (above 1000N/mm² yield strength).
If you wish to try sliding bearings then contact area has to be much bigger than the very small contact area in a roller bearing - according to the ratio of strengths.
If you want to get ultimate performance you should add spiral-groove structures that drag seawater into the bearing surfaces and minimise friction. (Airbearing example below).
Muijderman, Bootsma and Reinhoudt did the pioneering work with Philips in the 1960ies.
RHABE
Good Answers: 58
09/18/2008 11:38 PM
I have had good success with these products, though not in your proposed application. http://www.vesconite.com/
mvr
Register to Reply 14 comments
bakerjohn (1); bwire (1); ozzb (1); PWSlack (1); RHABE (2); Rorschach (4); The Prof (1); welderman (1); Willem46 (2)
