Previous in Forum: Grounding Outdoor TV Antenna   Next in Forum: What are the origins of the "Odd Man Theory" and it's influence on probability.
pringles potato chips
07/27/2008 6:00 PM
why doesn't the lid fit on the bottom of a pringles can?
Re: pringles potato chips
07/27/2008 6:29 PM
D = h*Λ2 ..................... (1)
Λ-D = √((1-h)λ** ) ....... (2)
Also X = ΛΛ***Λ ........... (3)
If you do the substitutions, it's obvious.
* This one (wherever it appears) should have a plank through it. Strikethrough's too low, and incorrectly aligned. Just imagine.
** This one's a small version of the other one (i.e. Λ that one).
*** This one's an operator (to avoid confusion).
Good Answers: 143
07/27/2008 8:01 PM
I see your mistake. In step (2), ζ should be raised to the minus seventh power (unless, of course there is an imaginary domain; in that case skips steps (2) through (16).
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
07/27/2008 8:29 PM
Because the bottom doesn't need a lid!
I wonder..... Would Schrödinger's cat play with a ball of string theory?
Good Answers: 97
07/28/2008 1:36 AM
Why?
1) They taper the box to cater for the over and under sized potatoes.
2) If they have to make it fit they will have to invest in a pringle sleeve-box puller.
3) Don't worry just eat and enjoy.
The slightly tapered pipe idea was stolen from magicians. (where the feathers are hidden in an empty pipe)
Good Answers: 54
07/28/2008 8:37 AM
Well, (munch, munch) I thnk ish (crunch) becosh (crackle) thuh thop nheedsh (munch, yum yum yum) thoo vee thiker (drink to clear mouth...ahhh) to allow them to glue the tear-off seal onto it (gets another one from the cylinder...crack!). Fersonaly, ah don care mush about ith (munch munch, yum!)
Good Answers: 22
07/28/2008 2:15 PM
You really sunk your teeth into this question!
Good Answers: 68
08/05/2008 7:10 AM
Hello guest,
why would you want to put the lid on the bottom?
stay safe
babybear
3Doug (2); Anonymous Poster (1); babybear (1); Hendrik (1); TVP45 (1); Vulcan (1)
You might be interested in: Amplifier and Comparator Chips, CPU Chips
