Previous in Forum: Is This Due to Catachrestic Cretins?   Next in Forum: Field Service Engineer
15 comments
Actuators/Hydraulics
08/01/2008 6:46 AM
Can someone help me? I'm trying to make a working prototype of an invention I've created. I'm new to this type of site. I'm looking for non-electric dual actuator/hydraulic set that would be able to be installed in 2 side by side steel pipes/tubes approximately 20" apart from each other, and about 1 1/2"- 2 1/2" diameter, and starting height would be approximately 10" tall and when actuators are extended (able to stop at any height within given range) could extend up to 20" give or take. Also, both move together from maybe a tiny "hand-pump-up" style handle. and when they are needed to be brought back to lowest height, turn a small knob to release and lower.
Also, the setup wouldn't have to hoist anymore weight than the original strength of metal tube/pipe would be as a whole. (Before cutting pipes and inserting actuators in center.
Good Answers: 230
Re: actuators/hydraulics
08/01/2008 6:53 AM
Hello wheels always turning
What you require appears to be a modified pair of car hydraulic jacks.
These could do what you are asking, unless I have misunderstood your situation.
A picture is worth a thousand words, but if you intend patenting your invention, you would not be able to publish any part of it, because then no patent would apply, due to "Prior Publication".
Kind Regards....
08/01/2008 7:19 AM
Sparkstation,
What does this mean?
thank-you
Good Answers: 266
08/01/2008 8:00 AM
It means that it is very hard to make reccomendations on a device if we can not conceve how its to be used. All we can suggest is you Google hydraulic cylinders. Locate manufactures see what they have to offer. What your looking for may have to be specially made. Then it will be up to you to design it. Thats part of protecting your forth coming patent.
Good Answers: 230
08/06/2008 8:38 PM
Hello again, wheels always turning
Common Saying:
"A picture is worth a thousand words" is a phrase or saying which describes easily a situation.
So....you could describe something in words, but the more complicated the thing you are describing, the greater number of words are used in that description.
So....A picture of the article is far better, along with a few words.
Then all can look at the picture, and the few added words finish off the description.
Thus, to properly describe a motor-car, in words that included all specifics, would take millions of words, right down to details such as the characteristics of the tip of a sparkplug and more.
But if you showed a picture of that car, most viewers would know straight-away what sort of a car it was.
Patents and Publishing:
If parts of an article or thing are publicly published (such as in Newspaper, TV, Radio, Internet, CR4 Forum, etc.), then later if the inventor tries to patent that article or thing, and actually obtains a Patent, if another person or Company uses that part of the design which has already been published before the Patent Application was made, there is no redress or recourse against that person or Company who uses the design part which was Published prior to the Patent Application.
Example:
I design a new sort of light bulb, which includes using metallic glass as the filament.
I unwisely tell a friend and show him a picture of it, or the lamp itself.
The friend decides to place a picture and/or a description of my design on a public Internet site - for example, the CR4 Forum, which is a public site.
I get advice and assistance from others on that site, improve my design, and obtain a Patent.
I start a Company which makes those new lamps by the millions,. and for a short time, become wealthy.
Then I discover that other Companies start up, making the same lamp I invented.
I foolishly put myself into the hands of lawyers, try to sue those other Companies for "Patent Infringement".
I lose the case, because of "Prior Publishment" of my design, or part thereof.
I become bankrupt, my wife leaves me, I become an alcoholic, and even the family dog goes elsewhere to live, after I try to move into a new home
OK....Now do you see.
Trust that assists you
08/01/2008 7:46 AM
Hey Sparky,
It seems to me that you genuinely and honestly could and probably would help me if able to. So, I'm going to hope you're a good influence.
Anyway cut to the chase right? I still want to know about the last reply. Although, I got to thinking......I do have a "poor-man's patent" on my invention. Don't know if you've ever heard of the term. I learned it in art college years ago. If you know of it, would that over-ride the rule you told me of?
O.K., now to the main chase. To better describe my earlier explaination without totally submitting idea............Imagine you have a standard '''push" lawnmower or rotertiller that just hurts for you to operate due to being extremely taller than the average human. Then cutting both side tubes of "push"handle and putting dual hydraulics there, and then returning the original upper half of "push" handle back on.
Then, adding (within reach) an approx. 3" lever or handle to pump when tall person is operating to match a height for comfort. Then when a family member of short or average height wanted to operate, they'd just turn the knob (approx 1" diameter 1/2" height) to release and lower back to original height.
Good Answers: 18
08/01/2008 8:00 AM
Why not use the pushbutton style of extending telescoping tubing like one finds on lots of things such as adjustable metal crutches, walkers, table legs, etc?
08/01/2008 10:39 AM
Well, that thought crossed my mind when I first came up w/ my idea. But, for the application I'll actually apply my idea has to be hydraulic. I just used the handle of a pushmower for a close visual comparison for what I'm actually making.
Good Answers: 18
08/01/2008 11:06 AM
O. K.
You state: "Also, the setup wouldn't have to hoist anymore weight than the original strength of metal tube/pipe would be as a whole. (Before cutting pipes and inserting actuators in center."
Did you mean weight instead of "strength?" In that case, the hydraulic pressure would not have to be very high and would not necessarily need to be metal. Have you considered making your own cylinders with the telescoping tubing you intend to use?
08/01/2008 6:59 AM
<...new to this type of site...>
Newcomers are made welcome here. Please 'chime in' and help others too.
08/01/2008 7:56 AM
I learned long ago that the only dumb question is the one you don't ask.
Why write to me as if I'm ignorant. I'm only trying to get some help.
And I'll not be sorry for any inconvenience you feel was made.
Good-day.
Good Answers: 247
08/02/2008 1:56 AM
I'm afraid you completely misunderstood PW's remark. He was simply saying welcome to the site, and if you feel like chiming in on a discussion in which you have some expertise, or comments of any sort, to feel free to do so.
Good Answers: 15
08/01/2008 7:44 AM
Have you tried web searches at sites like globalspec.com or mcmaster.com or thomasnet.com?
Doing searches for hydraulic jacks could yield good results.
downhill slide to 112 (damn memor.)
Good Answers: 68
Re: Actuators/Hydraulics
08/02/2008 4:30 AM
Hello wheels always turning:
and welcome. Is this the first time you have been here?
Can I just refer to PWSlack's remark in post '2', and your reply............
I think you saw an insult where there was none. It was a friendly remark.
If you have a special talent or interest and, think you could help by giving your own advice, please do so and become a helpful member where and when you can.........and, of course, only if you want to?
Everyone is hear to help or be helpful. That is why this great site exists, OK?
stay safe
babybear
08/02/2008 4:37 PM
Wheels,
What you describe is essentially what you also ask for as potential actuator.
Just visualize your too tubes as hydraulic cylinders or at least the ends of them as hydraulic cylinders.
Somebody here suggested you do just that, turn your tubes into hydraulic cylinders. With very little load on them you should be able to do that with simple "O" rings, cups like the type that go in automobile brake cylinders, etc.
Except for the fact that you wanted this to be manual, no power, my first thought was something else that looks like, and acts like, a hydraulic cylinder, i.e., a linear motor.
Seems you solved your problem in the stating of it and may not be able to see that for the trees.
Simply put, and your lawn motor handle simile was very clear, you want something like that that can be actuated with hydraulics. Think about it. You have really solved your own problem.
j.
08/03/2008 12:43 PM
Using the tubes is a good suggestion. The lower tube would be the body of the cylinder; the top tube would fit inside it and be the rod. Add seals, and Bob's your uncle.
Register to Reply 15 comments
Anonymous Poster (1); babybear (1); Bill (2); Blink (1); ddk (1); Jack Jersawitz (1); ozzb (1); PWSlack (1); Sparkstation (2); wheels always turning (4)
