Previous in Forum: motor   Next in Forum: Does anyone have experience with semiconductor and MEMS gyroscopes?
12 comments
Fuel Tank capacity cal
08/04/2008 7:24 AM
Hi,
Can anyone tell me , how to calculate fuel tank capacity for DG set? Is there any formula available?
Regards,
Baskar.R
Re: Fuel Tank capacity cal
08/04/2008 7:57 AM
Do you want to know the capacity of an existing tank, or calculate the required capacity for operation?
08/04/2008 8:54 AM
I want calculate new tank capacity
09/23/2008 2:22 AM
If it is the arithmetic that has you stumped, you could enlist the services of any 4th grade child.
Good Answers: 97
08/04/2008 7:57 AM
If you need to calculate the volume of an existing tank you would require detailed measurements. Filling with known volumes or a flow/volume meter will be better for irregular shaped tanks.
Sizing the tank would require the maximum consumption rate x the length of time required plus some allowance for additional fuel for aging etc.
The fuel consumption will vary in relation to the load. An exact estimate can be made but unless you have a space problem it will always be better to have some reserve capacity available.
08/04/2008 8:06 AM
<...Sizing the tank would require the maximum consumption rate x the length of time required plus some allowance for additional fuel for aging etc....>
An allowance also needs to be made for the vagiaries of the fuel delivery services and transport difficulties.
A water pumping station in the UK with a standby diesel generator set of 50kVA would have, typically, a fuel tank of 1500L upwards. Then, the electricity supply is generally good here, with minimal interruptions. Were the tank to be located in South Africa, for example, then given the reported level of electricity interruptions, it may well need to be bigger so as to provide uninterrupted service.
Good Answers: 97
08/04/2008 8:58 AM
Hi PWSlack - Rubbing it in ?
08/05/2008 3:30 AM
08/05/2008 3:32 AM
Good Answers: 97
08/05/2008 9:04 AM
A wordless guest at #6 and #7?
08/05/2008 4:27 PM
08/05/2008 6:32 PM
I'm assumin' you're a 'regular' bein' a smart-a**e, and #6 & #7 are idiot posts.
I may have it the wrong way round ....
02/04/2011 6:37 AM
Assuming the generator require to run 24 hours, non-stop for 10 days.
The D G Set's fuel tank consumption (capacity) calculation:
Fuel consumption at 100% load X 24 hours X 10 days = Fuel Capacity Tank
Hope that would help :)
Register to Reply 12 comments
abasins (1); Anonymous Poster (4); baseee (1); Hendrik (3); JohnDG (2); PWSlack (1)
You might be interested in: Fuel Cells, Fuel Testers, Fuel Dispensing Equipment
