Previous in Forum: LCD Monitor Repair??   Next in Forum: Kempe's Yearbook
19 comments
DSDynamics
08/24/2008 2:50 PM
My son defaced the couch with an ink pen.(regular ball point pen, not fountain). Isn't that cute. Although not new for the world, this is new for me.
any advice on removing ball point pen ink? The substrate is a synthetic suede like material. Kinda' like microfiber.
Good Answers: 243
Re: DSDynamics
08/24/2008 5:59 PM
I would turn it inside out and try to blot from the backside using nail polish remover, or hairspray, Rubbing alcohol (isopropyl) also works and in my experience is less likely to damage fabric; also less likely to remove stain.Test to make sure that whichever wouldn't also stain/damage the fabric.
Having a couple of daughters around teaches one which are the useful chemicals around.
Then I would pretreat and throw in the washer; in your case, i'd then hit it with upholstery cleaner...
I've also had gd luck using engine starting fluid...
BTW, unless he's older than age 6, its not defacing, its experiential learning.
After 6, it could be willful defacing.
I'll send you the t-shirt...
milo
Good Answers: 19
Re: DSDynamics
08/25/2008 4:10 AM
Isopropanol in high concentrations (like 99%) behaves very much like a non-polar solvent. Think lighter fluid or gasoline. It is pretty good at removing what's left when you peel off a sticky label. Ordinary isopropyl rubbing alcohol is 70% isopropanol, 30% water. It behaves mostly like a polar solvent (think water), and is very good for cleaning glass.
Orange oil (like De-Solv-It) is an excellent cleaner for things you might otherwise clean up with mineral spirits. It's non-toxic, won't hurt your skin, and washes off with water, but it dissolves latex and some adhesives.
Blotting is a good way to remove dissolved stains, because it wicks the dissolved stain away from the material you are treating. Facial tissue and good quality paper towels work well; finely powdered diatomaceous earth, such as that used in swimming pool filters, works better but leaves a residue that must then be removed.
It's always a good idea before you begin in earnest, to check the effect your cleaning materials will have on an inconspicuous area. Some fabrics and some finishes react very badly to anything stronger than water, and some of them won't even tolerate that!
If you can identify the manufacturer of the offending material, you might ask them for recommendations on cleanup. Good success!
Good Answers: 123
Re: DSDynamics
08/24/2008 6:20 PM
I have had very good luck with the older formula of brake cleaner. My says hairspray, but I am concerned about it hardening. Mineral spirits, acetone and carberator cleaner have all been used after experiments by my children and my children's children.
Texise K2R was good at time. The drug and food stores have many new products that I have not tried (yet).
With all products test on an nonvisable area. If the cleaner changes the color, or softens the couch material, it will only be worst.
But the #1 way to remove the stain from the seat of the couch..................................Turn the cushion over.
Bob
Re: DSDynamics
08/25/2008 5:49 AM
I recall industrial alcohol (methylated spirit), which is mostly ethanol, being adequate, but the ink dissolves rather slowly. Has anyone compared the effectiveness of different alcohols or other organic solvents?
Elroch
Good Answers: 123
Re: DSDynamics
08/25/2008 7:36 AM
My preference is rum. If I consume sufficient rum, I don't see the stains.
Bob
Re: DSDynamics
08/25/2008 12:55 PM
Holyyyy! Probably a little steam gun and some 'Oxy Clean' Spray stuff with a nice vacumm will do it. I don't know. Otherwise check it out with an upholtery shop tech around they will know about it as well. So far so good. The answers here at CR-4 make a bunch of sense to me too. Nice deal!
Clean Time,
MC
Good Answers: 145
Re: DSDynamics
08/25/2008 1:29 PM
If the covering is permanent then I don't have anything to add to the helpful comments you already have gotten.
If, by chance, the covering is removable (zippers?) then there is also the option of taking it down to a dry cleaning shop and letting an expert give it his/her best try.
Re: DSDynamics
08/25/2008 2:52 PM
If not "snow white fabric...#2's post says hairspray, works a my house.
Mr. Guy
If you are looking for a positive answer..it's YUP......
Re: DSDynamics
08/25/2008 5:48 PM
Hi: Have you tried WD-40, I've tried WD-40 to remove many different substances from a few different cloth & other fabrics, I ussually try a test patch in an unconspicuos place like the edge of the material where folded under the frame, even if you have to make a spot under there with the same ballpoint pen. I Know you'll be amazed at how well WD-40 works. P.S. I'm Not A Salesman for WD-40. Just an Old Retired Troubleshooter, Carl.
Re: DSDynamics
08/25/2008 8:27 PM
I have used one of the citrus fruit based cleaners - such as Simple Green and water to remove ball point ink from clothing - it worked well and is non toxic,non flammable and won't damage fabric. Ed K
Re: DSDynamics
08/26/2008 12:11 AM
If the chemical methods fail or are too harsh, and you are in the mood to experiment then you might want to explore some light treatments. I have noticed that art restorers use lasers for cleaning artworks. A small laser might selectively bleach the ink marks. The UV fiber optic probes used for hardening epoxy might also work. Still, I hope the chemicals work.
Re: DSDynamics
08/26/2008 12:27 AM
Here is a trick which works for sure.
Take the toy which he like most, preferably a soft toy. Take a ball point pen and pretend defacing it. If still he does not get the message you may actually try doing it.
Preferably do this while inspecting the defaced couch so that he may compare.
Another point why not preserve it as a memento. We have several such items at our home. Both our boys are now grown up, both abroad one working and one just joining uni. What they did when they were small (when they were naughty!) is what is left in our house for we two (old couple- 51& 49 years) to remember.
I am sure you will understand what I mean in probably another 15-20 years!
sisira
Re: DSDynamics
08/26/2008 1:16 PM
Do not wash in hot water (if you decide to wash at all!) it may "set" the ink.
I find "Quik 'n Brite" to be the best cleaner I have ever used for problem stains.....I bought mine off a TV advertising show, fantastic stuff!!!!!
If the stain is still visible, skin child, have skin tanned, repair settee with the new leather.....
Re: DSDynamics
08/28/2008 6:24 AM
Are you related Rold Dahl?
sisira
Re: DSDynamics
08/28/2008 5:05 PM
I have no idea why you ask, but I do believe that you meant RoAld Dahl, you should learn to spell.
No I am not. He is a very clever Guy and I would be quite happy to be related to him....
I am remotely related to Alan Turing if you are looking for some connection with me to someone famous and highly intelligent!
Why the obtuse question?
Re: DSDynamics
08/29/2008 2:26 AM
Yes Andy what I meant was Roald Dahl. Sorry about spelling mistake, spell checker tried to prompt me to change it to Rolf Dahl but i would not listen! (just joking). I should have done better. By the way English is my second language and I am happy as long as I can convey my message, which in this case I have been able to.
There is a great short story about a painting (tatoo) done on skin titled SKIN by Roald Dahl. Very interesting. Try to get a hold on the book. I dare not tell you the story less it may spoil the suspense!
sisira
Re: DSDynamics
08/29/2008 9:07 AM
OK, will do....
Re: DSDynamics
08/28/2008 1:10 AM
workin' on it
Re: DSDynamics
11/05/2008 6:22 PM
try a magic eraser. or try using PowerGreens H2Pro Cleaner/Degreaser. It's a green cleaner that actually breaks down grease and oils into their base fatty acids and allows for a better cleaning with no residue. Place parts in aqueous solution, agitate or scrub, then rinse clean. I would also recommend blowing off the part to remove all excess water. This will get oils and grease off in a safe manner without the worry of solvents, voc's or other toxic chemicals in the mix. it seams to work on everything I try it on. Check it out at www.thepowergreen.com
Register to Reply 19 comments
Andy Germany (3); Anonymous Poster (2); bob c (2); BruceFlorida (1); bubbapebi (1); dsdynamics (1); Elroch (1); LG_Dave (1); Milo (1); Mr. Guy (1); PG1 (1); Sisira (3)
