Previous in Forum: Negative building pressure and harmful effects.   Next in Forum: Glue rubber to metal
high viscous pumps
08/26/2008 12:01 PM
which brand of pump will be the best for pumping cocoa masse(liqour)under extreme conditions. i worked in a cocoa processing factory in nigeria and the rate at which the pumps are getting packed up is alarming.we use gear pump (MP14,23,34,43). somebody help me!!!!!
Re: high viscous pumps
08/26/2008 12:12 PM
Try a GlobalSpec search, or a google search for "sludge pump" or "slurry pump".
Talk to some manufacturers/suppliers. If you specify your needs, and what they supply is not fit for purpose, they'll have to come & take it away & give you the money back - possibly with compensation.
08/26/2008 12:39 PM
Positive displacement pump. try AlfaLaval (TriClover) website.
http://www.alfalaval.com/solution-finder/products/Pages/default.aspx?type=industry
Or equivelent.
08/26/2008 4:00 PM
Here is the answer to your problem http://www.globalsourcesolutions.com/pi-50p.htm
08/27/2008 3:43 AM
Lobe pumps are sometimes used to pump strawberry jam, among other highly viscous things. They are positive displacement pumps, and therefore the downstream pipework requires careful consideration during the HazOp Study.
Good Answers: 58
08/27/2008 3:51 AM
Welcome Olorioko, never tried to pump cocoa. what is its viscosity and what is the failure mode of the pumps?
Anonymous Poster (1); JohnDG (1); phoenix911 (1); PWSlack (1); The Prof (1)
