Previous in Forum: proportional,reset explanation   Next in Forum: where can i buy in the philippines a 3 wire rtd splitter?
Water Flow meter for 200 mm pipe
08/26/2008 10:47 PM
Dear Sir,
We want to have a flow meter to measure water flow of a 200 mm distribution line, which will be used to supply portable water to town (project is under construction). Here we prefer to have a inbuilt data logger in this unit, so that flow reading can be stored and later can be downloaded to a PC. Please kindly advise us the most suitable flow meter for this application (cost of instrument has to be below US $ 3000).
Re: Water Flow meter for 200 mm pipe
08/27/2008 3:35 AM
Try magnetic flowmeters. ABB and Krohne (usual disclaimer) come to mind.
08/27/2008 7:49 AM
Magnetic Flow meter not essential for Potable Water Flow measuring application, ordinary Orifice plate type Flow meter suitable one,
08/27/2008 7:56 AM
And how is the 4-20mA signal to be derived from it?
08/28/2008 4:54 AM
We can put Differential Pressure type Transmitter across Orifice plate to derive 4 to 20 mA for remote monitoring
Good Answers: 97
08/27/2008 8:15 AM
There are a wide range available to choose from and you would have to compare advantages and disadvantages. (electro magnetic, electro mechanical. acoustic Doppler or transit time, turbine etc)
You may even have a look at the Coriolis flowmeter. (see my avatar)
To find specks you could Google for Schlumberger , Ott , Kent , Enderss Hauser , Flowmetrix etc)
08/27/2008 11:52 AM
Krone, Magflowmeter, with an external datalogger system should be fine
08/28/2008 2:58 AM
Dear All,
Thanks for all your valuable help.
Register to Reply 7 comments
Asitha (1); Hendrik (1); kalimuthueie (2); martin (1); PWSlack (2)
You might be interested in: Gas Flow Meters, Flow Meters, Paddlewheel Flow Meters
