Previous in Forum: Compressor Lubricating Oil   Next in Forum: Locking Arrangements
12 comments
Request on Infrared Heating Lamps
09/28/2006 12:48 PM
I would like to construct a food oven thats works with infrared heating lamps. What type should I use and how many KW s do I need to heat a 60 cm3 to 300 C ?
Pathfinder Tags: infrared heating lamps
Re: Request on Infrared Heating Lamps
09/28/2006 2:17 PM
Infra-red quartz halogen elements are quite commonly used for just this purpose, as well as for other heating purposes....
I think the ones in my oven / grill are rated at 2 kW they would easily fulfill your requirements.
But! you're not having my oven / grill
John.
Good Answers: 18
09/28/2006 3:00 PM
The watt density ain't there for quartz heaters for a 60 CC cavity, if it's a cube. If it's long and skinny, then a significant portion of the volume is taken up by the tube.
You might also check on glow bars; a ceramic/metallic element which will heat up to the temp you want, and they're not as fragile or expensive as quartz elements.
What are the dimensions of the cavity?
09/29/2006 3:01 AM
Bill,
I think he meant 60 cm cubed, not, 60 cubic cemtimetres. Unless it's a specialist hot dog oven!
09/29/2006 7:09 AM
eh?
cc = cubic centimetres = cm^3
60 cc is only a small volume?
I can't see the original question now.... but I thought the question was about a volume of 60 cc's ?
John
Good Answers: 75
09/29/2006 7:58 AM
I think the 60cc 60mL volume is a bit small. In the old units that's an oven 1.5in x 1.5in x 1.5in. I suppose it would work if you were cooking rice grain by grain.
Popular Science - Weaponology - New Member Hobbies - Musician - New Member
09/29/2006 9:45 AM
According to my ruler-scale, 30cm=approx. 1 ft; so this oven would be about 2 ft X 2 ft square, right? I'd say (4) 250watt infrared heatlamps aimed at a flat black heat absorbing exterior (sealed) would heat the box (aluminum or copper) to pretty hot on the inside in a short amount of time..
Some trial and error research would have to be done to get the exact temperature I would imagine
09/29/2006 10:09 AM
Have to disagree Steve-o....
The query is for a volume of 60 cubic centimetres.
By your measurements of 2 ft by 2 ft the area is 4 sq ft
or 30 cm x 30cm = 900 cm^2
60 cc = 60 cm^3 = 4 x 4 x 4 cm assuming the space is a cube shape.
As near as makes no difference.... I think we have a problem with which units the questioner is using?
John.
Good Answers: 75
09/29/2006 10:35 AM
I think what the original question meant to say was
603 cm meaning a box 60 x 60 x 60 cm
which is a volume of 216,000 cm3 or 216 Liters
instead of 60 cm3 which is 60 mL
Maybe a.kandil can verify this?
09/29/2006 12:27 PM
Okay, I meant to say 2ft X 2ft X 2ft .
He said FOOD OVEN which by common sense would have to be larger than 60 mL volume. Any comments a.kandil? Are you still there?
09/29/2006 6:56 PM
Yeah im sorry i meant 60 cm * 60 cm * 60 cm a volume of 216000 cm^3 my apologies for the mess i made
09/30/2006 4:17 PM
While you are clarifying the question:
*What is the desired time/temp. curve for the process?
*How well is the cavity insulated?
*What is the specific heat, & mass of your product?
10/03/2006 10:56 AM
Hi ,
- I would like to reach a 300 c in 5~8 min.
- As for the the Cp and the M ( kg/s) i'm not so sure ( food like chicken and stuff )
- Its well insulated
Register to Reply 12 comments
a.kandil (2); Anonymous Poster (1); Bill (1); Electroman (3); masu (2); Randall (1); steve-o (2)
You might be interested in: Lamps, Heat Lamps
