Previous in Forum: Effect of harmonics from SCR drive on other components   Next in Forum: relays
Manual for Nokian Power Factor Controller N-12
09/27/2008 4:43 AM
Dears
i need a user manual for Nokian Power Factor Controller N-12. I tried to find through Internet but failed. Please help.
User-tagged by 1 user
Re: Manual for Nokian Power Factor Controller N-12
09/28/2008 2:27 PM
Well, it might help if you used the right nomination of the item which is exactly as you wrote it except NOKIA is without the "n" at the end. The confusion may stem of the fact that tires, previously also manufactured by Nokia use the brand name Nokian.
Hope you find what you need.
Rgs, Olli
olli.eloranta@pp.inet.fi
Good Answers: 230
09/28/2008 5:57 PM
Hello oeloranta
Thank you for your advisory Post above, which is confusing for the Topic Starter.
The website I quoted in my Post above is correct, and there is no confusion with the Topic starter or myself, re Nokia/Nokian, thank you.
http://www.nokiancapacitors.com/
That is the Company which makes the Power Factor Controller in question, and has nothing to do with Nokia, who make Mobile telephones (amongst other things).
I'm certain that http://www.nokiancapacitors.com/ will help.
That should ensure you get the correct Manual, right into your own computer via Download.
A pleasure to assist you.
Kind Regards....
09/28/2008 11:26 PM
Thanks for replying
I tried to look a user manual in the link which you have written but found only a Broacher. I want to program the contact of output relay for Low limit and High Limit of voltage which need a detail user manual. I am surprised why Nokian Capacitors did not put this manual in their web site.
Good Answers: 230
09/29/2008 12:19 AM
Hello again, Signode
Perhaps you could suggest that Nokian do place the .PDF technical Manuals on their Website, so that these could be downloaded easily.
Apologies for that, because I did assume that their .PDF document would have proper technical information included.
Kind Regards....
10/16/2023 7:28 AM
Not everything is on the internet, surprising as it might seem. Sooner or later one has to pick up the telephone and make some calls.
oeloranta (1); PWSlack (1); Signode (1); Sparkstation (2)
