I have recently installed a small wood burning stove in my lower level of a small split entry home. The heat is trapped in this area and because of the air flow of a split entry, the cold air sucks down the stairs and into the living space of the lower level, but not alot of the hot are is able to travel up the stair well. I was thinking about putting two air vents in the ceiling at both ends of the upstair level. I have read about the fire codes in previous mails and totally understand them. A friend suggested putting a ceiling fan in the entry way in reverse mode to try to suck up the hot air from the lower level. I still believe that a ton of hot air is trapped in my ceiling on the lower level that I some how need to release into the next level of my home.
