Previous in Forum: copper busbars   Next in Forum: Difference between single pole with neutral and double pole MCBs
knee point voltage
11/26/2008 10:47 PM
what is mean by knee point voltage?
Thanks and Regards,Krishnapillai.
Re: knee point voltage
11/27/2008 2:01 AM
Hi,
Knee point volatge is checked in Current Transformers. Beyond this volatge core gets saturated.
Best Wishes,
N.Suresh
11/27/2008 7:07 AM
hai,
thanks for your reply
regards,
kp
11/27/2008 2:30 AM
lots of devices have knee point, which device do you want to know?
11/28/2008 5:41 AM
Hi Keerhti
The knee point voltage is that point on the magnetizing curve where an increase of 10% in the flux density (voltage) causes an increase of 50% in the magnetizing force (current). It is a prime indicator of the characteristic of a particular current transformer (CT) because the voltage level reflects the structural integrity of the CT. Any decrease in the knee-point voltage can indicate a deterioration in the core material (delamination, crack, etc.) or a defect in the winding (inter-turn shorting). Any incipient defect in a CT can therefore be detected by conducting a trend analysis on the knee-point voltages measured over a period of time. To support the reliability of trend analysis, the measurement of knee-point voltage must be consistently accurate.
Kind regards
Roman
Canada - Member - Toronto, Ontario (South Parkdale On The Lakeshore) Engineering Fields - Marine Engineering - Great Lakes School Of Marine Technology (Owen Sound and Port Colbourne) Technical Fields - Architecture - Private Practice 1976-1990 Technical Fields - Education - Toronto Teachers' College 1971 Technical Fields - Marketing/Advertising - Founding Member Hobbies - Hunting - Founding Member Hobbies - Target Shooting - Founding Member
11/29/2008 5:29 AM
Hi, keerthi!
Look it up.
Just type "knee point voltage" into a search engine's address line; and YOU'LL GET YOUR ANSWER IN EASY TO UNDERSTAND TERMS IMMEDIATELY. Then, if you have additional questions, ask.
Sorry to be impatient with you. However, you just asked a lot of people to do something for you that you could --apparently-- have done for yourself. If you have some physical restriction that prevents you from checking this out on your own, please breifly explain why you are asking others to do it for you so grouches like me will not get on your case unfairly.
Mark
12/01/2008 3:10 PM
keerthi; it also relates to the zener diode conduction curves. perry
Register to Reply 6 comments
Anonymous Poster (1); cnpower (1); keerthi (1); MarkTheHandyman (1); perry (1); Roman (1)
