Previous in Forum: Scenes from Antarctica   Next in Forum: hole into space
23 comments
Tool Usage - 101
12/03/2008 10:18 PM
DRILL PRESS: A tall upright machine useful for suddenly snatching flat
> metal bar stock out of your hands so that it smacks you in the chest and
> flings your beer across the room, denting the freshly-painted part which
> you had carefully set in the corner where nothing could get to it.
> WIRE WHEEL: Cleans rust off bolts and then throws them somewhere under
> the workbench near the speed of light. Also removes fingerprints and
> hard-earned calluses from fingers in about the time it takes you to say,
> 'Oh shit!'
> ELECTRIC HAND DRILL: Normally used for spinning pop rivets in their holes
> until you die of old age.
> SKILL SAW: A portable cutting tool used to make studs too short.
> PLIERS: Used to round off bolt heads. Sometimes used in the creation of
> blood-blisters.
> BELT SANDER: An electric sanding tool commonly used to convert minor
> touch-up jobs into major refinishing jobs.
> HACKSAW: One of a family of cutting tools built on the Ouija board
> principle. It transforms human energy into a crooked, unpredictable motion,
> the more you attempt to influence its course, the more dismal your
> future becomes.
> VISE-GRIPS: Generally used after pliers to completely round off bolt
> heads. If nothing else is available, they can also be used to transfer
> intense welding heat to the palm of your hand.
> WELDING GLOVES: Heavy duty leather gloves used to prolong the conduction
> of intense welding heat to the palm of your hand.
> OXYACETYLENE TORCH: Used almost entirely for lighting various flammable
> objects in your shop on fire. Also handy for igniting the grease inside the
> wheel hub out of which you want to remove a bearing race.
> TABLE SAW: A large stationary power tool commonly used to launch wood
> projectiles for testing wall integrity.
> HYDRAULIC FLOOR JACK: Used for lowering an automobile to the ground after
> you have installed your new brake shoes, trapping the jack handle firmly
> under the bumper.
> EIGHT-FOOT LONG YELLOW PINE 4X4: Used for levering an automobile upward
> off of a trapped hydraulic jack handle.
> E-Z OUT BOLT AND STUD EXTRACTOR: A tool ten times harder than any known
> drill bit that snaps neatly off in bolt holes thereby ending any possible
> future use.
> BAND SAW: A large stationary power saw primarily used by most shops to cut
> good aluminum sheet into smaller pieces that more easily fit into the trash
> can after you cut on the inside of the line instead of the outside edge.
> TWO-TON ENGINE HOIST: A tool for testing the maximum tensile strength of
> everything you forgot to disconnect.
> CRAFTSMAN 1/2 x 24-INCH SCREWDRIVER: A very large pry bar that
> inexplicably has an accurately machined screwdriver tip on the end opposite
> the handle.
> AVIATION METAL SNIPS: See hacksaw.
> PHILLIPS SCREWDRIVER: Normally used to puncture the vacuum seals under lids or
> for opening old-style paper-and-tin oil cans and splashing oil on your
> shirt; but can also be used, as the name implies, to strip out Phillips
> screw heads.
> STRAIGHT SCREWDRIVER: A tool for opening paint cans. Sometimes used to
> convert common slotted screws into non-removable screws.
> PRY BAR: A tool used to crumple the metal surrounding a clip or bracket
> you needed to remove in order to replace a 50 cent part.
> HOSE CUTTER: A tool used to make hoses too short.
> HAMMER: Originally employed as a weapon of war, the hammer nowadays is
> used as a kind of divining rod to locate and destroy the most expensive parts adjacent
> the object we are trying to hit.
> UTILITY KNIFE: Used to open and slice through the contents of cardboard
> cartons delivered to your front door; works particularly well on contents
> such as seats, vinyl records, liquids in plastic bottles, collector
> magazines, refund checks, and rubber or plastic parts. Especially useful
> for slicing work clothes, but only while in use.
> DAMMIT TOOL: Any handy tool that you grab and throw across the garage
> while yelling 'DAMMIT' at the top of your lungs. It is also, most likely,
> the next tool that you will need.
Good Answers: 230
Re: Tool Usage - 101
12/03/2008 11:00 PM
Hello DrG
Evidently you are tools-challenged.
Kind Regards....
12/03/2008 11:39 PM
Not really, but tools can sometimes be challenging. Just thought this was sort of humerous.
Regards,
Drg
12/03/2008 11:41 PM
I got a pretty good kick out of it.
Hobbies - HAM Radio - New Member Engineering Fields - Mechanical Engineering - New Member United States - Member - New Member
Good Answers: 22
12/03/2008 11:53 PM
How about..
TUBE BENDER: A device that converts perfectly round tubes into curved, flat ribbons.
I wonder..... Would Schrödinger's cat play with a ball of string theory?
Good Answers: 58
12/04/2008 12:13 AM
Good laugh - thank you
Good Answers: 266
12/04/2008 7:32 AM
drill press see the oblong holes in the table, they are for clamps.
and pliers are nut(not) for the turning of nuts and bolts.
Those that cut corners with tools soon will be hurt.
Good Answers: 143
12/04/2008 7:52 AM
May I add...
Milling machine: A device for demonstrating Newton's 2nd law, F=ma, on the apron when climb-milling soft brass.
Lathe: An instrument for measuring compression strength of lead screws when distracted by pretty women while threading.
Gear-head hand drill: A handy device for removing old power cords when the bit catches.
Electric miter saw: A device for performing power manicures on left thumb +/- 1 knuckle.
Thanks for the laughs. Now for the poll. How many here have had bruises on their bellies from removing the anti-kickback pawls on the table saw.
Good Answers: 38
12/04/2008 10:35 AM
Metric adjustable wrench: To be used only when SAE adjustable wrench is not available. Commonly referred to as knuckle-buster.
The last fight was my fault. My wife asked "What's on the TV?" I said "Dust!"
Good Answers: 74
12/05/2008 2:26 AM
DrG
You must be a very lucky man to still be able and hit the key board. Shit happens even when you think you've done it all, or maybe just then. Bad luck in protection/precaution is like having an unwanted child. Well not really, but very close. I was electrocuted the other day and it dropped off me like water off a ducks back. It helps keeping up with procedure any day. Hope all goes well for you, Ky.
The Twain Has Met
12/05/2008 8:02 AM
Good laugh and all true. I have at one time or another, tested these.
rrnut-2
12/05/2008 8:25 AM
That's like using the tool that students use in the workshop...........when one forgets to lock them away.............these are also on a par with pliers.
If fastener manufacturers wanted round corners on nuts.....they would have manufactured them with round corners.
This tool can cause severe damage to persons using them incorrectly.............I am of course talking about...........adjustable spanners..........cresent spanners...........shifters
Good Answers: 123
12/05/2008 11:59 AM
Now I understand why one should never use an inch sized adjustable wrench on a metric person.
Best laughs I've had in days. Thanks to all.
Computer. Device designed to remove the time remaining between coffee breaks and lunch hour.
Some one told me I was gullible and I believed him.
Bob
12/05/2008 8:54 AM
I thought it was bloody great and so very true. Thanks
United States - Member - I am a Yankee Doodle Boy. Engineering Fields - Manufacturing Engineering - Old School is the best school. Safety - ESD - Safety Mgr that keeps the peace Hobbies - DIY Welding - My Motto:
Good Answers: 26
12/05/2008 8:55 AM
THAT DAMN ______ TOOL: That tool that your looking for, that is the only tool that you can use to do the job at hand. Usually takes about an hour or more to find, and is especially difficult to locate when it is only a 5 minute repair.
If necessity is the mother of invention then is laziness the mother of necessity?
Good Answers: 22
12/05/2008 9:27 AM
I have a few more:
Body Grinder: A tool useful for applying a non-skid finish to nearby painted objects like car hoods. Also useful to take up slack in loose-fitting sweat shirts while in use.
Body Grinder with Wire Wheel: A tool that launches itself when applied to irregular-shaped objects. This phenomenon is especially interesting when the lock is on for the trigger.
Large Hand-Held Electric Drill: A tool that can rearrange your various hand and arm joints when the drill bit finds a spot to dig into unexpectedly, such as when it is about to 'hole through'. Also serves to allow for the operator to have a rest while he recovers from having his wind knocked out.
Wire Stripper: A tool that is especially good at removing at least half of the strands in a braided wire when it is used, requiring repeated attempts at stripping and often resulting in a wire that is then too short to connect.
Electric Solder Gun: A tool that melts any rubber or plastic object that is in contact with the wire/terminal that one wishes to solder, before the solder will melt into the connection. This often results in more wire cuts to maintain the wire jacket.
Impact Wrench: A tool that is very useful to test the tensile strength of the threads in tapped holes that are virtually inaccessible to a drill and tap, or that are designed in such a way that any further drilling and tapping is impossible. This tool is also good for testing the reliability of weld nuts and cage nuts, which are always concealed from further work without removing sections of body panel.
Electric or Pneumatic Screwdrivers: Tools that inevitably test the limits of sheet metal distortion when sheet metal screws are used to fasten predrilled and countersunk trim elements. They are also very good for determining the shear strength of hardened screws that are virtually impossible to remove once they shear. Also, they have an uncanny ability to remove all evidence of the bit socket in the screw head, so that if you ever want to remove the screw, you will drill it out.
Pneumatic Die Grinder with a Carbide Burr: This is a tool that has a mighty knack for catching inside of a hole that one is trying to enlarge in such a way as to make the hole jagged and either remove some of the burrs or shatter the tool.
Good Answers: 75
12/05/2008 9:39 AM
Related by use are:
Bolt Heads - usually used as altars on which to make blood sacrifices to the auto repair god.
Valve Cover flanges - surfaces used to conceal lurking hand slicing knives, which usually only attack when subjected to such tools as scrapers.
Engine Oil - fluid which attacks various body orifices randomly, when liberated by the uninformed mechanic, who takes pity on the fluids, and sets them free. Treacherous things usually go for the eyes, first.
Auto Batteries - unexploded bombs in plastic disguises.
Spark Plugs (and related wires) - Devices used to hide stingers of engines until the unsuspecting hand ventures near.
Cooling Fans - See Spark Plugs (and related wires) - Final digestive devices to which the hand is consigned after being stung into submission.
Exhaust Manifolds - For those times when the fan prefers its food cooked.
Screwdrivers - For the shish-kebob moment. May be used for raw or cooked prey.
Body and Fender hammers - For tenderizing said prey.
Mike
United States - Member - Member Hobbies - DIY Welding - New Member
Good Answers: 50
12/05/2008 11:08 AM
Micrometer: C-clamp used by less highly trained technical personnel.
Welding Helmet: Protective device for eyes designed to allow maximum brightness of welding operation to eyes; also designed to maximum load upon head, causing convenient cramps and other pain.
Hand held electric drill: Convenient tool designed to drill hole through finger(s) while holding sheetmetal in place to rivet.
Hammer: Convenient tool to install fastners.
Bigger Hammer: Convenient tool to install larger fastners.
Air Hose: Helpful item designed to burst at proper time to fling itself about and cause maximum damage and chaos.
Refrigerator: Tool designed to hold the best tools in the shop: the beer.
Speak softly and carry a big stick.
12/05/2008 8:56 PM
Bigger Hammer: Convenient tool to install larger fasteners
.............that's what meets the critters of of the adage, "Never force it, just get a bigger hammer"...............just make sure that your aim is good.
12/06/2008 1:00 AM
I think my ½ inch DeWalt Drill knows Judo because just when I think it is about to get through the thick steel it likes to wrap up my arms and throw me ass over tea kettle.
12/06/2008 3:37 AM
I still reckon that one of the most dangerous hand power tools is:-
The 9" widowmaker...........or better known as the angle grinder.
A slide I use in my OHS&W power point presentation...........this is a common tool used on vessels.
Cause.............wheel exploded..........not wearing adequate PPE.
Good Answers: 230
12/07/2008 1:07 AM
Hello MOBI
After viewing that picture, I feel sick.
Refer: Sound Effects
Kind Regards....
12/07/2008 8:12 AM
Hi Sparky,
Sorry about that.............my students are "most impressed" after I finish my OHS&W presentation...............I have to have a few funny ones in there to take there minds off the other photographs..............not too many though............I don't want them to miss the point.
Cheers
Good Answers: 97
12/11/2008 5:07 AM
DeWoo San Soo
Register to Reply 23 comments
3Doug (1); Anonymous Poster (1); bob c (1); Borrowdale Dan (1); bwire (1); charsley99 (1); Doogleass (1); double_j_b (1); DrG (1); ky (1); micahd02 (1); MOBI (4); ozzb (1); rrnut-2 (1); Sparkstation (2); standarded (1); The Prof (1); TVP45 (1); U V (1)
You might be interested in: Tool Boxes and Tool Storage, Tool Posts, Tool Balancers
