Previous in Forum: Looking for a Hand-Cranked Vacuum Pump   Next in Forum: Interfacing SCADA and tank gauging software
Pressure in a Parallel Pipe System
02/13/2009 4:59 AM
hi all,
I'd like to ask about the pressure in parallel pipe system:
when a single pipe with diameter D1 and flow rate Q1 branch into two pipe with diameter D2 & D3 and the same length, their flow rate are Q2 & Q3, bellow statement are true or not? :
Q1 = Q2 + Q3; ( i believe this relation is absolutely true)
and how about this?
P1.V1 = P2.V2 = P3.V3 (consider that there are no head loss)
is there any possibility that P1 < P2 + P3?
please response in account of pressure.
Thanks guys..
Good Answers: 97
Re: Pressure in a Parallel Pipe System
02/13/2009 9:43 AM
Hi mikexp
If the 2 pipes deliver to a common destination the pressure loss in the 2 pipes will be equal.
Go to http:\\www.gwis.co.za and download a demo version. You can then play around with pipe sizes etc.
02/13/2009 10:17 PM
Hi Hendrik,
Thanks for the response, I already knew that in the parallel pipe system with same destination, the pressure drop will be the same, however I still not sure about the pressure characteristic in each branch pipe,
let's say consider that there are no pressure drop, the pressure source is P1 which is in main pipe, so could be bellow relation is true? :
P1. V1 = P2. V2 = P3.V3 or P1.V1 = P2.V2 + P3.V3
where P2 & P3 are the pressure of branch pipe from main pipe.
Which one is rite? the 1st statement or the 2nd statement?
(D1 (diameter main pipe) not equal with D2, D2 not equal with D3)
Good Answers: 103
02/14/2009 9:05 AM
is it not already discussed in
http://cr4.globalspec.com/thread/3407
where you too have participated ?
South Africa - Member -
Good Answers: 12
02/16/2009 1:02 AM
Hi all,
The pressure drop accross the two parralell pipes will not be exactly the same - take your pipe friction factor into account. :) It will be close - but not exactly the same.
Have a look at Bernoulli and the ANSI/ISA-75.01.01-2002 (IEC60534-2-1) standards for valve sizing.
You should bear in mind that no two pipes are exactly the same.
Now that we have covered the semantics - for all design intents and purposes - yes the delta P would be the same if as stated above they flow into the same process stream.
Would you ever end up with a situation where P1 < P2 < P3 - this will depend on your process medium. Perhaps you might have uneven scaling (someting similar perhaps) on one line and this line might start chocking/blocking up. This will give you the situation where the pressures are different.
If you look at the pipe friction factor P1<>P2<>P3 all the time. :)
Regards,
Craig
Register to Reply 4 comments
craigza (1); Hendrik (1); mikexp (1); sb (1)
