I am about to prototype a new design of turbine blades.
My idea is to have 2 or 3 aerofoil shape blades with a constant chord dim from root to tip. The root of the blade would be fixed to the hub in a way that allows it to change pitch. The fixing pin on the blade would be offset from the centre of the chord towards the tapered end. The blade would be spring loaded to keep it pitched at around 45 degrees to catch low wind. As the wind gets stronger , its force should start to feather the blade to a lesser angle. The turbine would increase in speed and now start using the lift from the aerofoil blade shape. If the wind got too strong the blade pitch would go past maximum feather and start reducing speed.
My reasoning for a non tapered and non twisted blade is that when it is pitched to a shallow angle , there would be no drag area on the blade and the full length of the blade would be generating lift, allbeit differing from root to tip.
I dare say there are lots of holes to be picked in this, so fire away.
