Previous in Forum: Stimulus Grants - What Funding is Availible and For What?   Next in Forum: C program help
49 comments
Good Answers: 39
Wind Turbine Regulators
04/15/2009 6:07 PM
I contacted SouthWest Wind Products with a technical question about regulators. Solar Panel systems are using a regulator design called MPPT which is a smart switch mode unit that constantly adjust for varying sunlight hitting a fixed panel.
I asked if such a controller could be adapted to a wind gen which has variable wind affecting the turbine.
I have been told that the minimum start speed of any given wind turbine is dependent on how much of a load is placed on the alternator being turned by the propeller. If you disconnected the load ( battery) the prop would turn in the lightest of breezes but it would require a great deal more wind to turn a high capacity generator connected to a battery. And of course this same effect is used as a brake by placing a dead short across the alternator.
In my naivity I assumed a smart MPPT controller could also present a variable load to a wind turbine and thus allow it to start a small charge current at lower wind speed.
Apparently not. According to SW Wind Power its all or nothing in terms of wind gen output. According to the tech you can't regulate these wind gens.
What am I missing? I am used to alternators that can be regulated and even PM type generators have some control. Even if its just altering the air gap between pole pieces and the magnets or using a copper disk.
Elnav
Re: wind turbine regulators
04/15/2009 6:59 PM
It may not be worth it.
For permanent magnet designs one option is to lower the cut-in-speed and install a field weakening coil. However, for direct driven neodymium magnet generators (below 3-500 RPM), the energy consumed in weakening the magnetic field may offset the extra power produced. (slip-rings also require maintenance)
Another option is to increase the cut-in speed and hook up a boost converter to extract the power available below cut-in.
At the heart of the issue is without control, you can only get about half the KHW out that you could be getting due to the cubic relationship between wind speed and power. There is no simple way to match an unregulated generator to a battery. Whether boost or field weakening (or both even) is cheaper than simply installing another turbine will depend on your capabilities to manufacture it and what wind speed data you have.
While a variable air gap sounds easy, building it is another story.
Good Answers: 39
04/15/2009 8:19 PM
At the heart of the issue is without control, you can only get about half the KHW out that you could be getting due to the cubic relationship between wind speed and power. REPLY That is what I thought. With a lower cut-in speed you get energy sooner, and then a controller like an MPPT will prevent the excessive high voltage from boiling the battery. Installations such as mountain top repeaters often have multiple smaller wind turbines instead of one big unit. Whether this is for redundancy or to get more power from light wind conditions I don't know. Maybe both. PM generators have lots of advantages but last year when I was looking for such a generator in the 4kW size I could not find one manufacture (at a reasonable price) with any sort of regulation. One manufacturers claimed they could get me regulation but wanted another $1000 on top of a steep price. Final price was twice what a conventional genset would cost I was looking for a DC genset because the sole reason for the generator was to charge batteries. Why go through a double stage of conversion if a single stage would suffice.
Elnav
Location: Zagreb, Republic of Croatia (native name Hrvatska) ,EU, Europe
Re: Wind Turbine Regulators
04/17/2009 4:34 AM
Well, I am not electric, electronic nor mechanic engineer (because I am Systems Engineer) but if widening gap between pole pieces and magnets would solve problem of wind speed/rotational speed versus electrical output, then I think I have solution for You, provided I understood nature of system and requirements.
I believe that Your intention is to increase load with speed of wind by making gap less while starting with widest possible gap?
Now, is it possible that both rotor with its magnets be made conical in profile and have matching conical cavity inside of stator? I think there should be no problems in producing such alternator.....
If this is so then simple system of levers pulled away from axle by centrifugal force mounted symmetrically in circle on a ring (actually there is two rings and two sets of levers where free ends of levers are joined and on this joint a weight is fixed) and additional rings to lead axle when moving, then ring that would not rotate but be free to slide over axle and spring(s) that would push back rotor into starting position.
There should be a gap between axle of Elise and axle of rotor, that would be smallest when speed is highest or even completely joined when two rings with levers come together if some sort of radial ridges is made on rings (or flanges) that would mesh together like gears and thus provide stronger torque transfer in highest speed of rotation......
I dont know by which mechanism was working those alternators with variable gap You were using before, but perhaps this centrifugal system can be used to change gap in those alternators, so special alternators need not be built..........
I hope this would help, and sorry that I lack proper technical jargon, so even if my description is little clumsy, I think it would still be understandable.......
Per Aspera ad Astra
04/20/2009 12:00 PM
That looks like a good idea. Using a spring opposed fly-ball governor to position the tapered rotor inside the tapered stator should make for an relatively easy automatic rotor to stator gap adjustment. The hard part would be getting the linkage/spring ratios correct but it would use little additional power and that frictional to provide the gross starting load regulation in a system like this. It would allow the generator to spin freely being lightly loaded in light winds, so starting would be easier.
Another shunt regulator could be used to add load to keep from over charging the batteries and prevent overspeed during high winds or when the batteries are fully charged. The shunt regulator would only be active when there is surplus generation so it should not put an unnecessary load on the system when power is low.
If the software can detect, compensate, avoid, or correct an anomalous condition in the system, it is, by definition, a software problem-regardless of the root cause. In the long run, for most classes of problems, it is cheaper to fix it in the SW
Good Answers: 109
04/17/2009 4:42 AM
Multiple generators is the easiest way, switching on and off whenever suitable.
Generators for use in cars or trucks range from 1 to 10 KW - production cost is from 50 to 150 $ a piece, selling price a factor of 10 higher.
Variable magnetic field in a PM generator: not really difficult, coming in some weeks with a tutorial on PM generators I am preparing.
RHABE
Good Answers: 97
04/17/2009 4:55 AM
I'd agree with exception of the wind speed being a major contributor. For example if you configure with the minimum load being about that which the average low wind speed could produce then you're on the platform and that MPPT may be functional. Conceptually your unit may be more effective if designed for the conditions present.
What do you think...
Good Answers: 39
04/17/2009 11:51 AM
I don't follow your logic. The conditions present is variable wind which is why I am wondering about a regulator that can handle variable conditions.
Elnav
04/17/2009 2:58 PM
I believe Elnaw was thinking about optimizing system for speed of wind that is most frequent at site of wind power generator.
My Wind Power stations optimize Wind instead :-))
Still they could be adjusted for stronger wind if such is prevalent, but then in weaker wind they would not work...........
What I would do is to base capacity of particular PS on speed of wind that is most frequent at site, ignoring weaker wind and stronger one (because system regulate wind, stronger is not problematical) but with my system capacity is fixed, and on speed of most frequently occurring strength of wind would depend whether it would be 1, 3, 7 or 10 MW unit installed.
But then if 1 MW units can work 70% of time, 3 MW 50%, 7 MW 30% and 10 MW just 10%, then it is better to install seven 1 MW units than one 7 MW unit, dont You think? It would cost more, but produce nearly twice as much electricity, and if generator could also handle some range of lower and greater speeds, then we would catch almost all there is to catch, no?
Since my Wind Power Stations dont produce much turbulent flows, and turbulent flow dont matter to them at all as they would work anyhow, they could be packed much more closely together, which means more energy would be reaped from same wind period too.......
Anyhow, I hope soon I would be able to reveal my design when I submit Patent applications form, and then you shall understand this riddle I set You about optimizing the Wind :-))
Per Aspera ad Astra
Good Answers: 39
04/18/2009 6:13 PM
Hendrik
Sory, you have it backwards I think. The situation is this. Many people do not fully understand how to size a wind gen. They demand a size equivalent to what is needed for an engine driven generator. Quite often I have people demanding a quote for 10kW wind gen installations. They are living in a single family dwelling, often with no kids. I try and tell them a 2kW wind gen will collect enough energy and store it in a battery bank to power their whole house by way of a 2 or 3 kW inverter. And most of that time the inverter will be running at half power. Meanwhile the wind also blows overnight when they are not using any power. So it still collects energy.
So what happens is, the big 10kW windmill cannot start in light winds. Result zero energy collected from wind. Now they complain the "stupid installation is all wrong".
Yet; if you were to disconnect the big wind gen completely from any load, the light wind would often turn the prop, but slowly. If you were to place a small high impedance load across the output, you would get some voltage and small current. But not enough to charge a battery bank.
Photo voltaic installations have a similar problem during early morning and late night when sun angle is low and light is weak compared to noon.
For PV installs the solution is an MPPT controller. I was asking if a similar kind of controller was available for the wind gens. According to SW Wind Power tech support there is no such thuing.
I am familiar with a number of such failed installations. If I could provide a better controller, some of these installations could be salvaged. Hence the query.
Elnav
04/19/2009 7:50 AM
Dear Elnav,
Nobody is having it backward and we are both right, because we are speaking of different things when use of electricity is in question.
You want to store it to battery while I would send it to Grid as soon as it is produced.
I believe theme was how to optimally use resources at hand, to be able to produce as much electricity as wind speed permit, with aim to eliminate expensive frequency stabilizers and other electronic that should be necessary to compensate for variations in wind speed...
You are talking DC and we discuss AC production, IMHO.....
I agree with You 100% that people dont understand opportunistic electricity production is different than >>on demand<< production where energy is not stored because production is equall to demand.
Yes, higher capacity units have higher minimum wind speed to start. Now, if I did not mix threads, You asked if there could be alternator with variable gap, and I proposed possible solution with conicall rotor and matching stator, where rotor with its magnets can be moved in with higher speed of rotation, which should enlarge load so range of Wind speeds could be utilized.........
I pointed out that if weak wind meet also big gap between magnets and coils, then rule of diminishing returns would show itself in very weak electricity produced.
However, at least there would be no need to start elise by using electricity, so some would be saved.
Now tell me: would it help You if You would have different elise that can use wind more effectively and need not be stopped in strong wind?
What do You think of another idea of serially connected batteries where each should have its system for limiting strenght of electricity received and system to switch it off the line once it is full (just like some are mentioning >>dumping<< of load when battery is full), and last in the line should have usuall system that preclude damage to battery instead of next one? I would say some system with transistors could be made to effect this.....
Regards, Marijan Pollak
Per Aspera ad Astra
Good Answers: 39
04/19/2009 11:29 AM
Hendrik wrote: You are talking DC and we discuss AC production, IMHO..... This the first time you have clearly said your design focus was grid tie application. My application is as you realized, purely OFF GRID. Very different systems with quite different requirements. You speak of avoiding the use of electricity to get the turbine started whereas I was talking about how to overcome the issue of insufficient wind to drive large capacity turbines. Again a whole different situation. I am dealing with customers located where there is no grid to connect to. Diesel powered generators are now becoming so expensive to run, alternatives are being sought. Somehow I don't see how such divergent threads would fit together.
Elnav
04/19/2009 2:10 PM
Hi Elnav,
I have turbines of new design that would work with weaker wind, if this would help You, and my type of WPS could be used also for such places, with DC, of course.
One of turbines is strictly verticall. but has some speed regulation built in. Other can work both Vertical and Horizontal, but has no speed regulation. At least it cannot break from too high speed. It is simple and inexpensive to make also.
That is the way we can cooperate, and I can sell You Productiom Licence cheaply, once I get patent rights....
Now, please, there is Hendrik on CR4, and this is not even my Nickname (Henrik14)...
Per Aspera ad Astra
Good Answers: 39
04/19/2009 4:47 PM
Marijan Pollak, please stop trying to sell me your new wind turbine.
I am trying to fix a problem on an existing unit. The customer is not going to just junk a brand new turbine installed less than 6 months ago.
Elnav
04/20/2009 1:48 AM
It seems that we dont understand each other.......
If You take down Elise and put my turbine instead (NOT whole instalation) it would work with much weaker wind because of greater efficiency in using existing wind.
I guarantee at least double to triple eficiency compared to clasical elise!
Now excuse me since I am sick in last 24 hours......
Per Aspera ad Astra
Good Answers: 39
04/20/2009 10:33 AM
" If You take down Elise and put my turbine instead " What is Elise?
Elnav
04/20/2009 1:50 PM
I am sorry that English is not my native language, so I am at loss for words sometimes. Small airplanes use Elise to propell themselves (and of course now I remember it is called >>propeller<<). Since contemporary windpower stations use something very similar to elise/propeller, I call it that way.
Anyhow, this is head with blades that wind turn, OK?
Turbines are used in waterpower stations (hydrocentrals) and they are quite different from propelers. They cannot (in principle) be used for air since water is 10 times heavier than air.
My turbine is someting between propellers and turbines, so lets call it air turbine...
Per Aspera ad Astra
Good Answers: 39
04/20/2009 2:10 PM
English is not my native language either. And french is a poor third. My german and Italian is even worse.
This "turbine" business still confuses me at times. I originally learned it was a wind mill or wind generator back when I first worked on wind generated power equipment back in the mid seventies.
I suspect the marketing people somehow got their finger into the mix and really confused matters. And of course turbine is a word with sex appeal since turbines is what jet engines use. So in principle turbines can be used for air. At least if you go back to the pre war research of Parsons, et al. But even there terminology soon got mixed up. The early Chrysler turbine powered car had a regenerator but nowadays the favored word seem to be turbo fan. And lets not forget the word turbine is still used when talking about the steam powered turbines used in nuclear plants. (After the nuclear reaction creates high temperatuer steam)
Anyways, although I am not in a position to set up a production facility to fix just one installation when you have something you can publish; I would be interested in looking at it.
Elnav
04/20/2009 2:41 PM
Those in aeroplanes are not air turbines but gas turbines, and steam turbines are alike to water turbines, IMHO.
But, different countries use different names, I.E. >>Elise<< for >>propeller<<.....
My mother used 14 languages, so she teached me English, French, Spanish, Italian, Rusian and German, but only rudimentary and long (half century) ago.......
But I learned and used 26+ computer programming languages, beside Slovenian, Serbian, Macedonian and of course, Croatian that were languages used in former Yugoslavian Republics......... But things were not so simple as even in Croatia there are sublanguages that have problems in understanding each other, so we mostly speak officiall version of Croatian if we want to understand each other. To compound problem, we have around 30 minority groups that speak their own languages, so allmost every bigger village has its own language and folks traditions........
But this is perhaps reason we are usually good in languages, and we should be since many tourists are comming to famous Adriatic Seacoast (Croatian side)........
But I am nearing 60 and perhaps old thinking box hiccup here and there, refusing to supply proper English word.......
Regards,
Marijan Pollak from Zagreb, the capitol of Croatia, Europe!
Per Aspera ad Astra
Good Answers: 39
04/19/2009 4:59 PM
Marijan Pollak wrote:
That is the way we can cooperate, and I can sell You Productiom Licence cheaply, once I get patent rights.....
When you have something I can look at, by all means send me a PM with the details including a landed price for Vancouver, BC, in Canada.
To be honest. There is no manufacturing facility where I am. The company I work for may or may not be keen on setting up a production facility 700 kilometers away. Typically such a deal would require close supervision for the first dozen units and to be honest we would not sell that many in a whole year.
Somehow I doubt you will get very many people interested in handing over money for a piece of paper giving them permission to build a totally unproven design.
You need to demonstrate the worth of your design by building some samples in the first place. Once they have proven themselves in the field for a year or two and proven reliable then you can start to talk about production licences.
Your design has to be compared to existing models and documented as giving a benefit over the norm.
Elnav
04/20/2009 2:01 AM
O.K.
We can have an NDA and I guarantee that this is design that anybody can make even with hand tools and it work provenly.
I designed it with India in mind where there is little technology and tools available.
CR4 ADMIN: This post was edited to remove advertising outside the Commercial Space forum. Please review Section 14 of the CR4 Site FAQ about advertising.
Agree?
Per Aspera ad Astra
Good Answers: 39
04/20/2009 10:45 AM
Henrik14 wrote: " If You would be interested in production, I would ask just one fixed price of 3000 US $, and then You can produce for Canada as many as You want and pay just 10$ per turbine You install.... Agree? " You must be getting daft. I am not interested in production. I was looking to see if a certain kind of regulator method might be retro fitted to an existing wind gen design. Turns out the technical support guy I was talking to must either be new or doesn't know his job. Yesterday I discovered that the new version of wind turbine made by his company actually does use the same technology. Says so in the product literature. But in this case they incorporate the MPPT style regulation onto a circuit board mounted inside the head; not as a separate controller located some place down on the ground.
Elnav
04/20/2009 2:13 PM
Dear Elnav,
If You produce something it is (I believe) called >>production<<, no matter if You produce 3 pieces per year. If You produce hundred(s) that is them called manufacture or serial production, and if You produce thousands, it is called >>Big serial production<< :-))
So, I take it You would not be interested to be able to produce electricity even with much weaker wind, which would enable many new instalations?
Can You then connect me to this company that allready produce windpower stations?
I would say that they would be very much interested to be able to install 4 times more instalations! Only for them price would be 10 times greater than for You.
I tought that You can earn lot of money by remaking their systems, as surely there are many of their customers dissapointed with electricity production, just like those You want to help right now?
Thank You in advance!
Marijan Pollak
Per Aspera ad Astra
Good Answers: 39
04/20/2009 2:48 PM
Last time I checked ( about a week ago) I got over a hundred hits for wind generator manufacturers. Mostly Chinese clone makers. I probably did not see them all or even a majroity. I even found a chinese company selling a product that I thought unique and they used a copy of the product picture from the UK manufacturer for their advertising. Evidently they are copying the UK manufacturer without benefit of patent licence or even permission.
If you go back to my original post you will see I mentioned SouthWest Wind Power as the company I phoned first. This company name was in the very first sentence .
And from what I can see most of their products are now manufactured in china. Like just about everything else. That also explains why you see so many chinese clones.
Based on my own personal experience, there is no such thing as copyright protection or patent protection if you manufacture in China.
Good luck!
Elnav
04/20/2009 4:14 PM
Yes, I saw the name but this would not be enough to contact them.
Even in China they produce devices for foreign companies according to License owner specification, and they must not produce and sell same product for nobody else.
If they steal design from foreign country, then if it is patented there Patent owner can forbid selling their products in this country and any other where his Patent is in force........
Chinese produced devices are cheap because they practically work for food, and this is also production that sells for little more than production price.
If they would be allowed to continue like this, that would wreck World Ecconomy, because same product cost more to produce in countries with higher standard of living. Perhaps they plan it to be so :-((
I can see that their plan is succeeding as Western countries factories must close their productions.
Chinese rely also on simple rule of Ecconomy that more products are made, cheaper they are, so in big seriall production if formerly low price was kept same, lessening production cost per unit create profit that were not there in small seriall production.
But they has to have also some internall system of Patents rights, else they would steal one from another also, and that would preclude big seriall production, IMHO.
Therefore, greed that is >>spiritus movens<< of capitalist world would defeat itself if people seek to make more profit at expense of domestic workers that would lose job and then would not be able to buy products of domestic factories, because of which those factories would sell less and even close production so more people would be without JOB, which is snowballing effect on downward spiral. People should understand this and boycott anything >>Made in China<< or simply buy just domestic products even if they are more expensive. But differences are sometimes drasticall, to factor 1:10 or more, so people think they would save money, while reality is just opposite since they are sawing at branch upon which they sit, and sawing it between themself and tree trunk............
It all started because CocaCola wanted new big market, but for opening their market Chinese mandated opening US market for their products....... Therefore, Coca Cola maybe profited, but America lost jobs :-((
Similar things are happening everywhere, with big countries selling their cheap mass produced products in small countries even if their domestic products like wheat and vegetables are 1000 times more healty than those imported...
Ah, Well.........
That is just point of my Power Stations, as they would be so cheap to produce that it would be uneconomic to transport them from faraway countries, and since they can work with weaker wind, they would produce more electricity, and more they produce, cheaper it is..
Lot of cheap electricity should bring production prices down for any product where it is used in production, so factories would be able to put selling prices down and people would be able to buy more. Cheap electricity would make demand for fosille fuels and gas go down, and so would their prices. With people able to buy more things for their money, more would be produced and sold, so more people would have work and so on.....
So what do You think factories/companies would do if presented with turbine that cost less then one produced in China? You can bet they would rather produce it themself and make profit even selling for China prices!
That is what I am counting on :-))
Regards,
Marijan Pollak, IT SA/SE 1st. Class, Insrtuctor and Team Leader (retired)
Per Aspera ad Astra
Good Answers: 39
04/20/2009 4:56 PM
What? Google doesn't find an answer for Southwest wind power?
It is the first one on my list. Try www.windenergy.com/ Sometimes Google filters separate companies by the country of origin. I always have difficulty finding European companies when searching from a north American server. No such problem if going from a European server.
Having worked for companies that switched production to China I can tell you first hand that your impressions are naive. In China the state owns everything. Even Bill Gates went to China to protest the blatant copyright infringement of his products.
I worked for a company that discovered their best product was being cloned in China and sold here in the US. They sued. Took three years to get to court. Meanwhile both our company and our competitor were bought out by a third company. Big joke! We won; and we ended up paying ourselves the court judgement. But we also ended up paying the lawyers - for both sides as it turned out since now both sides were owned by the third comapny.
Six months later I saw yet another copy of our product but branded with yet another name. Took one apart - identical. What patent protection?
There are countless examples showing the same thing. Even a lot of documented examples in trade journals. Look up FARIA instruments for one such case.
My advice would be to find a company in India. They have a greater demand than the US. Technically they also have a much better world view of alternative energy sources. They have a greater demand due to a less robust national power grid and Stand alone or limited island grids. At this time India makes better batteries than he US or China. From what I have seen, they also have a substantial and technically advanced inverter industry. My favourite brand is made there. Good luck
Elnav
04/20/2009 6:47 PM
Since I married Indian, of course I would offer (in fact, I have offered) my Windpower Stations to their government. But, Embassy officer in charge told me it should go to private companies, and they react very slowly.........
So, China is pirate country lead by their government......?
However, one of Croatian inventors sold them license for production and they financed Patenting his motors and generators Worldwide........
Since I am sure they can sell more Power Stations than generators alone, and trough this they can also sell more motors, I think they would buy Production Licence and then guard it from other Chinese, what do you say?
Anyhow, when I talked with head of delegation which came here to order tankers from our shipyards, he told me that if I suceed to get Patent, they would order 10 thousands instalations just to try how they work......
Well, in regard to Southwest Wind Power, one I got in first place is from US, not from Canada........ That is same as hyperlink You supplied, and they dont answer my mails.
Okay, if You are not interested, this is it.........
Regards,
Marijan Pollak
Per Aspera ad Astra
04/20/2009 6:50 PM
I forgot to ask: If in China all belongs to government, how it happened that third party bought them?
Per Aspera ad Astra
Good Answers: 39
04/20/2009 9:54 PM
What I was told: the builder that got our designs had to submit all production drawings and plans to government for filing. Then later if someone else also wanted to make such stuff, they woudl pay a fee to government and get a copy of the production drawings. That way they are licenced to manufacturer by Government.
I figure that any designs I make for a chinese client, will be the one and only time I get paid for a production. Next time I can go whistle for royalties. This seems to be the way it works over there.
Elnav
04/21/2009 7:30 AM
Well, >>better something than nothing<< as we say in Croatia.
If they steal it and I cannot do much about it, that would be worse then selling one Production License, what do You think?
Per Aspera ad Astra
04/21/2009 2:37 PM
Thats my take too....
Good Answers: 15
04/22/2009 4:49 PM
Hi Elnav,
a tip for finding european sites on a search engine is to use one from the country you are interested in. I have both "Google .co.uk" and "Google .es" on my favorites list.
regards
Chas
04/17/2009 8:12 AM
I installed a video system on an offshore platform. I powered the system via solar panel & installed a wind turbine as a back up for those days when I was not able to fully uitilize the solar panel, generally when the sun don't shine offshore the wind is blowing. Both systems fed a battery bank I installed a voltage regulator on both power sources with out any problems.
Regards
Good Answers: 39
04/17/2009 11:42 AM
I had always heard that regulators were used on wind generators. However I was quite surprised to be told by one manufacturer that regulators for permanent magnet generators do not regulate except to divert to a dump load when battery voltage goes to maximum absorption level. One manufacturer (eCycle) of PM generators said the same thing and wanted to charge extra to engineer a true regulator that would be three stage and switch to float stage if the battery became fully charged.
I subsequently checked out a number of manufacturers and was told by them it was difficult to physically regulate Permanent Magnets alternators.
Elnav
04/17/2009 2:19 PM
What a waste! Dumping energy already produced :-((
Please read my solution and tell me what You think, is it possible?
I started from requirement of having variable gap between magnets and coils.........
No need for any electronic switching and multiple coils!
Unfortunately I have feeling that weak wind would produce still weaker electricity.
Alternatively similar system can be used to switch on and off variable number of coils, by pushing and pulling isolated pipe ( made of Novilon, for instance, which is type of plastic more resilient to wear than steel and self lubricating ) on which copper rings are mounted and isolated by plastic rings from one another, under line of contacts in pairs on opposite sides, where each switch on or off one coil in use, those switches that are in air are off, and those on rings are on, all controlled by speed of rotation itself..... To avoid situation where switches can be parked over plastic isolator between copper bands, switches could be doubled with gap equal to width of isolator band or little greater, so one switch would always be on copper band even if other is on isolator band :-))
Per Aspera ad Astra
04/20/2009 8:39 AM
You wrote:-
I would be interested in such a system, purely to learn more, for no other reason.
The only way I figure such a system could (theoretically) possibly work, would be if coils were added to negate the magnets effect, using of course the output of the Alternator.
Which would usually mean having slip rings to get power to the coils, which negates the reason for having magnets in the first place......(no slip rings needed!).
The only other method would be a possibility to move the coils away from the magnets mechanically......like this?
It would be an engineering nightmare mechanically though, out in all weathers.....but no need for sliprings either.....
Perhaps it could be used for voltage control, but might be a bit slow.....
Good Answers: 39
04/20/2009 10:30 AM
Andy, Snowmobiles have a variable diameter belt drive. this is achieved by using a centrifugal device to move the two angled side plates of the belt drive pulley in or out to vary the diameter of the contact circle . At first glance this kind of mechanism appears to be promising for doing the variable air gap. But what do I know, I'm not a certified mechanical engineer.
Elnav
04/20/2009 3:31 PM
Sounds promising.
Do you "need" to be an Engineer?
"Engineers" are those with common sense, not necessarily ones who visited a University or similar!! I have known several Non-Engineers who could "lose" good Engineers with both theory and practise!
Some people simply could not afford the University for one reason or another......does that make them stupid? I think not.
Have a great day.
Good Answers: 109
04/20/2009 4:05 PM
Hi,
not to move the coils away but the magnet assemblies.
These have to be located at both sides of the coils (else not at all sufficient flux density).
Take apart an old hard-disk-drive, there is one triangular coil (moving) with two sides magnets (each side one north one south oriented magnet).
So if you complete this arrangements by adding coils and magnets so that a full circular construction is resulting, this is near optimum for motor and generator use (1 phase).
Any even number of coils (minimum 6 but better 8 or 10 or 12) is necessary for optimum use of available magnetic flux.
Two and three-phase versions need two sets (three sets) of coils, magnet assembly is the same.
Moving magnets apart is difficult to realise. So think about switching of coils. If the coils are series connected then using half the coils will generate half the voltage. If the coils are connected in parallel then the current is changed by changing coil count.
More will be available as a tutorial on permanent magnet generator and motor design - pancake style.
RHABE
04/21/2009 2:18 AM
True, but the design I saw on the web (finished and working) used two sets of fixed coils with a moving plate with magnets on both sides, placed between the coils. In fact it was the disk of a Volvo disk brake front axle.....
But either method should work if a suitable system is worked out, excewpt that leaving coils "open" could result in exceedingly high voltages being developed on them.......some thought needs to be given there as well......feeding into a dummy load is just wasting energy, maybe a method to turn a HAWT out of wind or feather the props might be better.....
04/17/2009 11:37 AM
Here is a web site that has a generator that has variable resistance to wind loading.
http://www.technologyreview.com/energy/21666/?a=f
Your assumption of variable load to wind is correct.
Good Answers: 39
04/18/2009 6:21 PM
Silvcrow I saw that announcement and phoned the company since they are not that far away in Vancouver. ( only 700 miles) Apparently this is not yet a production item. They are stil field testing ONE unit. And no; they are not interested in more field testers.
For a new install this is certainly the way to go. However I was looking for a way to salvage existing installations that are not living up to owner's expectations.
The new Air-X Breeze model apparently does something similar to what I wanted with an internal controller. But so far no one has an external bolt-on controller. Pity
Elnav
Good Answers: 15
04/18/2009 8:15 PM
Hi Elnav,
I think I have a simple answer to your problem, well, half an answer!
If you add a series resistor in the output line of a fractional ohm value you will get a voltage drop across it which will "devalue" your alternator without disabling it. Since you would wish this to be variable to be part of a MPPT control I would suggest a bank of mosfets (I bet you have quite a few of them laying around). We see this on poor installations of chargers or alternators which have too much resistance in the battery cables (too long &/or too thin).
While this is a "losser" type circuit it will not generate too much heat as at full power the mosfets will be hard on and thus dissipating little power.
How will you go about doing the MPPT control? I have no experience in this area but, If I understand it correctly the MPPT is matching the impedance of the load to that of the source. With the relatively slow changes in source output of a solar installation the MPPT can vary the load presented and detect the best point on a periodic basis but with wind it would seem rather more difficult as the variability is on a much faster time frame.
I like Henrik14's idea of the conical rotor/stator pair where an axial displacement will produce a change in the air gap. There are already motors out with this sort of arrangement.
Kind Regards
Chas
Good Answers: 39
04/18/2009 10:26 PM
I agree Henrik's idea is good for when you have the option of starting from scratch.
In the case where a customer has already invested considerable money into a wind gen and tower installation, it becomes a case of convincing him to spend even more money in the hopes of getting something but less than full rated output. Except during sustained high winds.
Regarding your idea of a voltage dropping series resistor, I'm having a little difficulty figuring out how the whole system will react. I likely need to think about it more.
None of the MPPT regulator descriptions give details. It doesn't sound like it actually places an impedance across the output of a solar panel, but rather uses a lower voltage due to low light level and a variable DC -DC converter to juggle this into a higher voltage above 13.8V but at much less current. At least this way you get some charge curent at a voltage suitable for the battery. Then as output increases both voltage and current also increases. Now the DC-DC converter regulator adjusts to keep the voltage down to 13.8V but increases the output current as much as possible.
My example was of necessity simple and crude. A totally unburdened propeller will still have some torque resistance. If nothing else, the mass of the blades come into play. Presumably the larger air foil shape will have enough force to move the larger mass and still start the rotation. But the slowness also means very little generation.
Compare this with a situation where a much smaller turbine with correspondingly smaller mass is seeing the same light wind condition. It will have a much lower wind velocity start point and will reach its maximum output sooner. This is lilely one reason why I have seen many installations with multiple smaller turbines. The other reson being that multiple generators are cummulative in terms of total charging current.
In applications with a round the clock demand such as communications towers, the connected loads will often drag down the battery voltage below the critical level where the battery starts to boil off electrolyte. This would be equally true for solar and wind.
Elnav
Good Answers: 15
04/19/2009 8:04 PM
Hi Elnav,
Your problem, if I've understood the theme correctly, is the effort to start a 10kW wind generator when there is only say 2kW worth of wind.
There is no resistance to the rotor electrically until it is turning fast enough to generate a emf > VNOM of the system.
As the rotor spins up and the open circuit voltage increases above VNOM the current developed will be (VOC – Vbatt)/ R, where R is the total series resistance of the circuit. However this current puts a brake force on the turbine and it is this matching that the MPPT has to accomplish. It would seem logical that the best designs would be variable dc/dc converters controlled so as to adjust the current flow to avoid the blades stalling. The MPPT's job is not to limit the voltage as a regulator, although it may well incorporate that function, it is to get the best out of a non linear generation system. ( this could be related to the way an automatic gear box draws power from an engine with a non-linear power curve).
If we look at the extremes, O/C (no current, blades turn freely) and S/C (no voltage, blades are braked) we will obviously be drawing no power from the wind. If now we vary the load between the extremes we will find a point where the max power con be drawn from the system. My idea of using a simple variable (mosfet) resistor is simply to vary the braking effect on the rotor. This could also be achieved by a chopper circuit but the system loads other than the battery may not like it.
I don't see any reason why a 10kW system should be more reluctant to start turning than a 2kW system since it is only a question of accelerating the rotor mass to the required speed. In all of this I have been assuming that the generators are optimised for the same wind speed, with their rotor blades suitably scaled.
Kind Regards
Chas
04/20/2009 12:24 PM
What about using a small, very simple, low power PLC to monitor the frequency of the output from the PMG and have it drive a series switching regulator which adjusts the duty cycle of the output from the generator by switching the output with a transistor or FET switch. Even SCRs can be used if they are applied to the AC output of the PMG. The program for the PLC could set the maximum power extracted from the generator based on speed (determined by the generator frequency). Low power extraction for low speeds, more power to the load when the generator is turning at higher speeds. Switch in the load dump when the batteries are fully charged and the speed is approaching a dangerously high speed.
The PLC could be in sleep mode for most of the time when the generator is not turning to minimize power drain and only "wake up" when the generator output reaches a pre determined level. If the generator is disconnected from the batteries and house load, except for the regulator when the regulator is off, there will be no additional drain on the batteries when the wind is calm.
Good Answers: 204
04/22/2009 8:59 PM
for interest, here is a page I came across, where the author seems knowledgeable about the basics of wind power, and is a DIY guy. I don't know if this link has been posted anywere else here on CR4. I haven't seen it before anyway.
Chris
12/28/2012 10:29 AM
Dear Mr.chrisg288,
You have provided a page "here" without web link. If you click it opens. What should be done for this.? How to provide with out web-link.? pl. inform.
Many CR4 Members also posting like this, I want to know about this.
DHAYANANDHAN.S
Good Answers: 204
12/28/2012 5:44 PM
you can insert your web link by highlighting some text in your message,
then hit the LINK button, and add your URL to the dialog box.
I had also added a link to my image at the bottom to my personal page.
so it is the same procedure, just select the image instead of highlighting.
Cheers,
Chris
12/29/2012 3:48 AM
Dear Mr. chrissg288,
Thank you very much,for your guidance, and I will try.
DHAYANANDHAN.S
Register to Reply 49 comments
Andy Germany (4); Anonymous Poster (1); bwire (1); capblanc (3); chrisg288 (2); dhayanandhan (2); elnav (16); Henrik14 (14); RHABE (2); silvCrow (1); tet228 (1); Turbotroll3 (2)
