Previous in Forum: Screw Threads and Multi-Start Heads   Next in Forum: Press Specs: Ram Stroke and Daylight
9 comments
How to Calculate Plate Weights in Kilograms
04/16/2009 6:33 AM
size of MS-Plate - L-5000, W-2000, Thick-80mm
pls. suggest the formula to calculate weight of the above plate in Kgs.
Re: to calculate the weight of ms plate in Kgs
04/16/2009 8:00 AM
Easy. Calculate the volume, then refer to Kempe's Engineers' Handbook, any edition, for the density.
04/23/2009 1:40 PM
W x L x T x density
5000mm x 2000mm x 80mm x 7860kg/m3= 6288 kg
Good Answers: 19
04/23/2009 5:14 PM
Guest that's a great formula. Normally i do my way add add 5%.
Questionl Where do i get the density of all sizes of ms plates?
Does the same formula calculate also angle Iron in various sizes?
05/04/2010 6:04 AM
please help to find wiwght
10/01/2009 7:53 AM
please note
5000mmX2000mX80mmX7860kg/M3=6288
or
0.5X0.2X0.8X7.85=6.280 Mt
Good Answers: 19
Re: How to Calculate Plate Weights in Kilograms
04/16/2009 1:05 PM
AN MS PLATE 1" THICK , SIZE 8 FT X 4 FT = 600 KG WEIGHT.
SAME PLATE SIZE 3"(80MM) = 1800 KG.
NOW 3" (80MM)THICK PLATE = 1800 KG/32 SFT = 56.25 KG/SFT.
YOUR SIZE = 16.4 FT (5000 MM)X 6.6 FT (2000 MM)= 107.6 SFT X 56.25 KG/SFT
= 6053.15 KG/6.O METRIC TON
06/16/2010 8:04 AM
5X2X80X8
10/25/2010 12:41 PM
lenth*width*thikness*7.85
01/08/2012 12:08 PM
VOLUME in CUBIC INCHES x 0.28 = Weight in Pounds.
DHAYANANDHAN.S
Anonymous Poster (5); dhayanandhan (1); ducon (2); PWSlack (1)
